Hit a curb....
Old Jun 5, 2010 | 08:44 PM
  #61
Inversed's Avatar
gross misjudgment on your part. Oh well, we live and learn. I understand your curiosity though with no good experience behind the wheel in such a situation you should try to be more careful. Besides the obvious new rim looks like you'll need some suspension work.
Old Jun 7, 2010 | 10:43 AM
  #62
Scooby24's Avatar
Wow, old thread. You guys should really get some driving experience under your belt with RWD cars. The G is one of the easiest I've found to drive in a controlled slide. If you want to test out the capabilities relatively safely, I highly recommend trying it out at an autocross event. I've done a few in the G and with VDC off, all you have to do to keep the car controlled is counter steer and feather the throttle. If you want to break loose, you can mash it but as soon as you break the traction, feather the throttle to keep the rear in check. If you keep it mashed, you will lose control. If you start to get a little too aggressive of an angle, hit the brakes lightly. Even with VDC off, if you tap the brakes, it turns itself back on momentarily to help straighten you out.
Slamming on the brakes mid rotation will only make things worse BTW. Tap. It's all about right foot control.
Old Aug 28, 2010 | 06:52 PM
  #63
jerrymoen's Avatar
Ouch man that is a pretty wrecked up wheel!!!
wheel repair orlando
Old Aug 28, 2010 | 07:28 PM
  #64
rpm&my_G35's Avatar
I'll go out on a limb and bet the 08g35s got his wheel fixed in March 2009 when he posted this.
I can't believe tis one is still going.
Old Aug 29, 2010 | 09:35 AM
  #65
Rollo's Avatar
hehe...I posted without noticing the date on the original post...
Never mind...
Old Aug 29, 2010 | 11:01 AM
  #66
G35Now!'s Avatar
Moderation-free
Originally Posted by EnviedG35
Ouch man. I did the same thing once coming around a corner that was wet from the sprinklers. The whole rear end kicked out....i countersteered and was able to save the side of the car and wound up sliding into the curb and hitting the front passenger side bumper at the bottom. Scuffed it up pretty nicely but thank god i didnt hit the front wheel. Needless to say i will never do that again haha
+1 Ended up with a whole new set of wheels and tires from eBay, and turned a profit on the whole thing
Old Aug 29, 2010 | 11:03 AM
  #67
G35Now!'s Avatar
Moderation-free
Not knocking you, but I completely disagree with this. The G rear end comes out unexpectedly, and way fast if you're not really careful. Car mags have commented on this too - it's easy to get to the wrong angle very quickly.
And no, that's not what happened to me, I had a different driver error
Old Sep 6, 2010 | 11:28 AM
  #68
johnbanks2's Avatar
If the back end is coming out unexpectedly you are either one:
not smooth with steering wheel
2)coming in to turn to shallow and and over correcting
3)have tires that are not sticky enough
4)if it isn't in manual matic mode then you may upshift going in to turn and then when you power out the transmission downshifts two gears for you and then boom, there you spin, pick your gear before entering turn.
It is a fairly neutral car.
Old Sep 7, 2010 | 07:37 PM
  #69
JoshLee89's Avatar
that sucks.. is that fixable?
Old Jan 28, 2011 | 12:14 AM
  #70
jerrymoen's Avatar
i used www.kwicksilverusa.com last time and I was really satisfied
Old May 26, 2011 | 12:36 AM
  #71
fastlane45's Avatar
Hmm if I press this button my girlfriends clothes might fall off
Old May 26, 2011 | 12:57 AM
  #72
bluedevils95's Avatar
Originally Posted by 08g35s
I got to replace my rear tires as I damaged one rear tire too. Can any one tell me if Falken 452 is good choice?
Thanks,
Harsha
I hope it's not too late. Only on pg 2 still. Do not get these tires!!! Not good! Not ever!!! Now i am going back to pg 2 to read on.
Old May 26, 2011 | 01:04 AM
  #73
I think i am a few years late on this. lol
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
KruZZe
Feb 27, 2023 05:04 PM
06g35
Feb 14, 2022 05:59 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
G2B35AGN
Sep 25, 2015 10:49 PM
