2nd Gen Random Little Question Thread!
Old Nov 19, 2020 | 12:19 AM
  #256
08g35s 925's Avatar
G35s
Throttle bodies
Anyone know if the VQ35de style throttle bodies work on the VQ35hr motor? Looking at upgrading but don’t know if they will fit/work. The most concerning thing about it for me is the wiring harness from the throttle bodies(not sure if it’s the same plugs).I’m lookin at the czp or z1 Motorsports types but they all say there for the 06 models, hence de. If anyone knows PLEASE RESPOND!
Old Nov 22, 2020 | 10:49 AM
  #257
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
No it won't fit, if you're looking for an upgraded throttle body for the HR they make a 70mm one. Should be able to google it, search specifically for "vq35hr throttle body".
Old Sep 8, 2021 | 08:02 PM
  #258
No Boost's Avatar
G35x/Cayman S 3.8L
Is the HR port or direct fuel injected?
Old Sep 10, 2021 | 03:47 PM
  #259
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Port. The "DD" series VQs are direct injected.
Old Sep 10, 2021 | 07:52 PM
  #260
cleric670's Avatar
BANNED!!!
Thank god these things aren't direct injection. I've had nothing but problems with the high pressure pumps on nearly all direction injections gas engines.
Plus they absolutely DESTROY their valves unless they have some kind of trickery like Toyota does on some models by adding a single port injector upstream just to spray gas in the plenum to wash all the **** off the valves.
Not a fan of direct injection at all, unless it's a diesel.
Old Sep 11, 2021 | 07:05 AM
  #261
No Boost's Avatar
G35x/Cayman S 3.8L
The reason I asked was because of a product called Valve Clean by Liqui Moly which is only effective with port injected engines. I'm a huge advocate of using only top tier fuels and am currently doing my best to cleanse the fuel system. It sucks not knowing how much the previous owners actually cared for this car. For the most part, it idles evenly with an occasional rise and drop. I'll be using a few different products when filling up. Some might call it snake oils but at least they don't harm anything.
Old Sep 11, 2021 | 11:01 AM
  #262
cleric670's Avatar
BANNED!!!
I would just stick to Sea Foam, long reputable history of being an excellent fuel system treatment.
Old Sep 11, 2021 | 12:13 PM
  #263
No Boost's Avatar
G35x/Cayman S 3.8L
^ yep, got a case of the stuff here. Just haven't used it yet because I thought there might be "better" products. Many people, including my P engine builder, swear by it...that and Marvel Mystery.
Modern fuels suck these days with everything being E10 which is hygroscopic.
Old Sep 11, 2021 | 03:56 PM
  #264
cleric670's Avatar
BANNED!!!
It being hygroscopic isn't typically an issue since the gas tank doesn't allow for hardly any transfer of air. Plus only the surface molecules are going to absorb moisture.
EDIT: Unless the car is being driven so infrequently that you are using a tank of fuel in less than 3 months.
The bigger issue with any ethanol content fuel is it's more corrosive, this is unavoidable for vehicles that are not flex fuel, newer flex fuel vehicles use different metallurgy and plastic-urgy ( )and have special alloys that resist ethanol corrosion.
However, any additional ethanol reduces predetonation which the VQ is pretty notorious for so there ARE benefits to using E blend fuel.
Old Oct 24, 2021 | 10:13 AM
  #265
Ketchup83se01's Avatar
So I have bought the Powerstop/Akebono calipers front and rear also have the Z1 kit for the front calipers and stainless brake lines. My questions is will the oem 18 rims still work?
Edit: Found the answer https://g35driver.com/forums/v36-bra...35s-sedan.html
Old Jun 30, 2022 | 04:32 PM
  #266
Boanz's Avatar
G35X sedan
Suspension help need confirmation
I have tried searching with no luck for my answers I have a 2007 g35x struts are gone I found a set of new Megan racing ez2 series coilovers for cheap new unopened on Facebook the box says 03-06 awd when I search them up on the net they come up for 03-08 I was at junkyard last weekend looking for a set of struts with no luck but while there I did look at a 06 g35x and from what I can tell the only difference was the mounting brackets for the sensor wire and brake line they look the same size I didn’t have a micrometer to verify same tube size can someone help I’d really like to get these for the price if they work Ty for any help
Old Jul 2, 2022 | 12:30 PM
  #267
cleric670's Avatar
BANNED!!!
Replied to your other thread, go to a parts house and have them pull a strut for 2006 and one for 2007. Compare them side by side and see if they'll work, if it's just things like brake line brackets, ABS wire brackets, you can usually just modify the bracket to make them work.
Old Oct 8, 2022 | 09:49 AM
  #268
No Boost's Avatar
G35x/Cayman S 3.8L
Any downside to removing this insulation piece?
Old Oct 8, 2022 | 12:04 PM
  #269
cleric670's Avatar
BANNED!!!
More noise from the engine bay.
Old Oct 9, 2022 | 11:49 AM
  #270
No Boost's Avatar
G35x/Cayman S 3.8L
^^ so there's upside, good deal!
G's_all_day
Sep 2, 2011 05:42 AM
My G Spot
Aug 9, 2010 01:23 AM
bluizzo
Dec 9, 2008 10:02 PM
Garnet Canuck
Media Share G35 Sedan V35
134
Apr 3, 2008 11:42 AM
