Drive Sport problem
Old Oct 5, 2011 | 09:44 AM
arok5's Avatar
Drive Sport problem
Hey Guys,
Been having an issue lately with the Drive Sport (DS Mode) in my 07 G35. I'll be driving it in DS mode and be shifting gears and then randomly (there really is NO ryhme or reason) it will change to "D" mode (automatic) and not let me shift the gears although the shifter is still fully engaged into DS mode.
Anyone else had this problem? Any suggestions?
Thanks!!!
Old Oct 5, 2011 | 10:58 AM
vqsmile's Avatar
Never had the problem before, but it seems like it's losing the sense of where which position the shifter is in. I'd be considering/checking for linkage, switches, or possibly even an ECU reflash. Beyond that, it's gonna get into $$ and professional help.
Old Oct 5, 2011 | 05:34 PM
E-Ticket Ride's Avatar
If you did a search on that problem, you'd find it was related to the shifter mechanism.
https://g35driver.com/forums/g35-sed...wont-work.html
https://g35driver.com/forums/v36-eng...t-up-down.html
https://g35driver.com/forums/g35-sed...going-out.html
Old Oct 5, 2011 | 05:44 PM
vqsmile's Avatar
^^ Ouch! Looks like they run about $300 for the part alone.
Old Oct 5, 2011 | 05:55 PM
bluedevils95's Avatar
I never had that problem before. Try this when you have time. Clean the contacts. Who knows, it could be dirty.
Old Oct 5, 2011 | 06:49 PM
It's not the contacts, because you can still feel/hear the tactile response from the shifter mechanism while in DS mode (using the lever).
Old Mar 27, 2012 | 03:56 PM
Holmes35's Avatar
stealership just quoted me $ 645- to get this fixed..what a load of ****!
Old Mar 27, 2012 | 06:48 PM
G3065's Avatar
That's about right...I had the same issue but fortunately they fixed it out of goodwill even with my warranty expiring. Try to work with your dealer on this because this is probably quite common. Contact corporate!
Old Mar 27, 2012 | 06:53 PM
pattyballs's Avatar
I Just posted about this problem too. I had this problem about 2 years ago and had it fixed under warranty. I went back to the paperwork and it said that the micro switches needed to be replaced. Im trying to do the repair myself but have no clue where to buy these micro switches lol
Old Mar 27, 2012 | 09:53 PM
Unless you find a diagram that says otherwise, I would assume that the switches are incorporated into the solenoid unit they replace to fix the problem. If that's the case, I doubt you could only change the switches.
chinee
Jun 10, 2024 07:48 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
bjo16
Aug 4, 2015 09:52 AM
EasySausage
Jul 14, 2015 11:17 PM
