Motordyne - Tony
Old Jul 23, 2008 | 11:12 AM
  #376
Hydrazine's Avatar
did you see a difference in flow between the 2.75in and the 3in?
I tested 2.5" and 3". 2.75 is a oddball diameter tubing that would be a lot harder to source and would unfavorably affect cost.
Also do you have any plans to make a properly matched set of long tube headers to boost lower rpm power and also start the pressure wave benefit closer to the exhaust ports?
Headers may come later. For the most part headers don't do much on this engine but... if good results are possible, I'll find it.
Old Jul 23, 2008 | 01:39 PM
  #377
SteveBlake's Avatar
Sorry for posting about this again but will getting the XYZ pipe for my JIC show noticeable gains over my custom y-pipe?
Old Jul 23, 2008 | 01:56 PM
  #378
Hydrazine's Avatar
You would need to dyno it to know.
Old Jul 23, 2008 | 03:54 PM
  #379
Jeff92se's Avatar
Red Card Crew
Tony, I know you are offering single and dual exhausts but which config showed the best overall gains? (given the same tube dia)
Your conclusions mirror mine in terms of what the Borla sedan true dual is lacking for maximum power/torque. ie.. x-pipe at the Y collector. Would also be one reason why Klubb had great success with his custom. TD with resonated X at the Y collector and another as a muffler at the end. (power and quiet sound)
Old Jul 23, 2008 | 04:11 PM
  #380
Hydrazine's Avatar
Single or Dual - In all of my testing, they yeild pretty much the same gain if done properly.
Old Jul 23, 2008 | 04:13 PM
  #381
Jeff92se's Avatar
Red Card Crew
Is my thinking in the right ball park?
Old Jul 23, 2008 | 04:17 PM
  #382
Hydrazine's Avatar
I'm not really clear on what you are thinking so its hard to say.
Old Jul 23, 2008 | 04:22 PM
  #383
Jeff92se's Avatar
Red Card Crew
In studying the Stillen TD and Bora TD (for the sedans), the Stillen unit seemed to dyno a tad better. My theory is that the Stillen featured an X pipe where the two downpipes normally collect (Y collector). I always thought this was probably what made the hp/torque diff inbetween the two. I also think any TD should use some type of X collector if possible (resonated or not). For good power/torque and sound, a TD featuring a resonated X at the Y collection point and one out back as a muffler could very well be wise choice.
Thoughts?
Old Jul 23, 2008 | 04:49 PM
  #384
OCG35's Avatar
^^^ thoughts on what?... all you did is describe a typical X pipe exhaust... basciall there is H, X and Y (and straight)... what are you asking? or giving?
Old Jul 25, 2008 | 08:51 AM
  #385
twin001's Avatar
TOOOOOOOOO
THEEEEEEEEEE
TOOOOOOOOOOOOOOP
How could we let this thread go untouched for over 24 hours!
Old Jul 25, 2008 | 12:32 PM
  #386
SteveBlake's Avatar
Tony i read that you can have a catalytic y-pipe and that will help us test pipe guys but the only problem is how pricey will it be? Because when i was choosing HFC's or TP's, the biggest reason why i got resonated test pipes and not HFC's was because of the huge price difference.
Old Jul 25, 2008 | 05:30 PM
  #387
Hydrazine's Avatar
I havn't fully worked out pricing yet. What are typical cats going for these days? Or at least the range?
EDIT:
Metallic cats.
Old Jul 25, 2008 | 07:04 PM
  #388
Jeff92se's Avatar
Red Card Crew
Thoughts?
Thinking of adding the magnaflow resonated X to the Borla TD (sedan). Aft of the cats but before the resonators. I'm hoping this will improve sound and more importantly low end torque.
Good move Tony?
Old Jul 25, 2008 | 08:05 PM
  #389
Hydrazine's Avatar
Good move Tony?
What diameter inlets will be on the X muffler and how far back will it be from the cats?
As for sound, it will certaintly smooth out any rasp, but there is an increased risk for drone.
Drone is unlikely but possible.
You won't know untill you try.
Tony
Old Jul 25, 2008 | 09:33 PM
  #390
Jeff92se's Avatar
Red Card Crew
Tony
According to Borla, their systems feature a 2.25" pipes. here's a picture:
I'd replace their non-X pre-muffler (cats back section) with a resonated X from Magnaflow. In a matching 2.25" size.
