NEW Motordyne Exhaust, Titanium and Dual Setups!
Old Nov 20, 2009 | 03:01 AM
  #916
Silencer_0's Avatar
Went for a ride in my buddy's G coupe with test pipes to see how the smell of fumes is. Wasn't as bad as I thought it'd be. Now I'm looking forward to your new TP's to switch out my HFC's .
Old Nov 23, 2009 | 03:59 PM
  #917
Beebo's Avatar
Tony im guessing since the shockwave is straight pipe it will NOT pass emissions?
Old Nov 23, 2009 | 04:43 PM
  #918
jayk's Avatar
I passed 2 weeks ago np.
Old Nov 23, 2009 | 08:48 PM
  #919
gabe3d's Avatar
Do you have TPs or HFCs?
Old Nov 23, 2009 | 09:05 PM
  #920
Hydrazine's Avatar
All "catback" exhausts by definition are CARB and smog legal.
Test pipes and aftermarket HFC's are the ones that can cause problems.
Tony
Old Nov 23, 2009 | 09:45 PM
  #921
jayk's Avatar
Tony
Neither. Stock OEM cats.
waiting for MD HFC
Old Nov 23, 2009 | 09:56 PM
  #922
Beebo's Avatar
Tony
Sweet, will your HFC cause problems?
Old Nov 23, 2009 | 10:07 PM
  #923
Silencer_0's Avatar
^ Depends on your state laws. Everything's illegal here in Cali
Old Nov 24, 2009 | 12:49 PM
  #924
OCG35's Avatar
^^^ passing sniffer with HFC shouldn't be a problem (even in CA)... passing visual will be.
I don't know how people with HFC are passing smog in CA unless they are paying under the table... I have never had a smog inspection where they did not look under the car for altered cats (and I've had lots of smog inspections). Unless your cats look OEM (like Crawford) there's a good chance they will not pass you when they see it (yes I speak/type from experience).
Your best bet (to be on the safe side) is to re-install OEM cats before smog. Lets face it, that's only after 6 years (if you buy new) and every other year after that... no biggie.
Old Nov 24, 2009 | 08:59 PM
  #925
Beebo's Avatar
Im in Texas so i will not have to worry
Old Nov 25, 2009 | 11:06 AM
  #926
Ray@OCInfiniti's Avatar
Tony
Correct, the exhaust is not an emissions device. The only parts that would factor into smog control are the cats/headers/02 sensors etc... (on our cars)
Old Dec 2, 2009 | 01:01 AM
  #927
Yosef's Avatar
So is there going to be a deal for those who already have the shockwave but just want get the "drone eliminator" things? I already have the entire shockwave system but just want to kill the drone.
Old Dec 2, 2009 | 09:27 AM
  #928
Hydrazine's Avatar
Absolutely.
Old Dec 2, 2009 | 04:12 PM
  #929
jayk's Avatar
Absolutely.
how much would this add-on piece be?
and.... How would these be installed? Drill holes and weld?????
Old Dec 2, 2009 | 04:48 PM
  #930
Silencer_0's Avatar
^ I'm pretty sure you have to replace the straight pipe in between the mid pipe and the tip to the new one.
Or in my case, the new pipes will replace my gamma mufflers.
