Advanced Resonance Tuning (ART Pipes)
Old Nov 27, 2012 | 08:32 PM
  #1081
MaDMaXX's Avatar
Originally Posted by Algy
When you say "its not getting enough fuel" are you referring to my car running too lean? If so, that might be true bc I have not gotten a tune with the ART pipes + TDX2 exhaust + JWT intake.
Also I have the Version 2 ART pipes that had the ceramic paint on them. Do those ART pipes come with gaskets built on them? Or was I suppose to install gaskets on them?
My car was running lean with those parts before my tune, so quite possibly.
Old Nov 27, 2012 | 10:53 PM
  #1082
canehdian_guy's Avatar
I would appreciate any Motordyne ART pipes installation tips
One major tip that I have heard is that the bolt on the drivers side of the heat shield is cut off to eliminate a buzzing sound that occurs. I've done quite a bit of searching but it would be great to here any other installation tips.
Thanks
Old Nov 27, 2012 | 11:50 PM
  #1083
Algy's Avatar
Well I already had a custom tune with my prior mods which were
Z-tube
5/16th spacer
Berk HFC
Nismo Catback
The only new thing that would lean it out more would be the JWT pop charger and the ART pipes.
Old Nov 27, 2012 | 11:51 PM
  #1084
Algy's Avatar
If you have the non revup DE, i believe you should be using the factory gaskets, i re-used mine and so far as i can tell, they're sealed perfectly.
Crap I dont remember using those bc I remember seeing it already having seals on the ARTs
Old Nov 28, 2012 | 09:48 AM
  #1085
spinna001's Avatar
I get a code for my art pipes as well... I do not know the exact code put i know its the sensor on the driver side exhaust manifold
Old Nov 28, 2012 | 10:19 AM
  #1086
gary c's Avatar
With all your breather mods installed:
Spacer
Intake
High flow exhaust
ART pipes or HFCs
You will have a lean situation which can easily be solved with a Osirus tune. You have two choices either get a tune or reinstall your OE cats before you hurt the engine!
Gary
Old Nov 28, 2012 | 09:44 PM
  #1087
Algy's Avatar
Just replaced the passenger side A/F sensor and I did reuse the stock gaskets and the ones that came with the ART pipes. Data logged after install and it reads better. Hopefully this will solve the issue. Keep yall posted.
Old Nov 29, 2012 | 07:45 PM
  #1088
Algy's Avatar
Ok so the check engine light just came back.... this is already going to be a nightmare I know it. I already replaced the a/f sensor (bank 1 sensor 1) but the light camw back on. I have yet to check what code it is this time but Im pretty sure its the same code. I checked for leaks this time and I didnt have any around the manifold and cats. I also used the gaskets from the arts and the oem ones.
Old Nov 29, 2012 | 07:47 PM
  #1089
Algy's Avatar
What can it be?!?!?
Old Feb 27, 2013 | 06:03 PM
  #1090
hockeyg35's Avatar
Anybody have an installation guide for these on an 04 g35 coupe
Old Feb 27, 2013 | 10:40 PM
  #1091
MaDMaXX's Avatar
They're dead easy, just remember they can rotate to give better connections to the Y-pipe. I think there is a very basic set of instructions (not possible to have complicated ones) on Motordynes site.
Old Mar 14, 2013 | 11:58 AM
  #1092
Marcusmfmatilla's Avatar
Art pipe help pleaaseee
I installed my ART pipes on my 6MT Coupe in December and it sounded great. Recently about 2 weeks ago there has been this sound that sounds like rasp but i do not think it is. It kind of sounnds like my pipes are rattling. It only happens below 1.3k rpm and above 3.2k rpm i usually shift at 2.8 rpm. So my question is, will this go away and/or what do i need to do to get rid of this. Its annoying me. Thanks for any help and suggestions.
Old Mar 14, 2013 | 01:01 PM
  #1093
Blue Dream's Avatar
I drove ttrank's car solo
Thanks
Make sure you did the above tip.
Old Mar 14, 2013 | 07:00 PM
  #1094
I dont think i did that. Thankss
Old Mar 19, 2013 | 04:09 PM
  #1095
KingCobra's Avatar
Looking to buy these this weekend
Is everyone having issues with the latest ART pipes? I'm looking to install these on my stock exhaust and don't want any rasp or noise at certain RPMs like other test pipes.
Also will I need to tune my car after installing these?
I sent a message to Hydrazine but it seems like he hasn't logged into the site for a couple of weeks...
