Dynoing out the myth of Intake mods: The Results
Old Mar 25, 2011 | 06:01 PM
  #121
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by Jeff92se
CAI is definately not worth the risk of hydrolock. You're just adding risk w/o any benefit IMHO.
^Risk of hydrolock is a moot point for me. I had no business anywhere near the puddle I drove through. It was way tooooo deep and I very very nearly got stuck, but still didn't have any issues with HL.
If I never go through a puddle that deep (and trust me, I'll be avoiding that mess at all cost) it will never be an issue.
That being said, if you pay attention to my posts both in this thread and others, I don't even remotely delude myself into thinking that the G gained any power at all from a CAI. In fact I wouldn't be surprised if it lost a couple.
The thing is, it sounds absolutely siiiiiick. Forget z-tubes/jwt/short-ram/whatever else... a really long intake pipe on a VQ sounds awesome.
And that's my only reason for leaving it on... well, that and it looks good.
Look at my mod list... I got the more-power bug out of my system already. Owning two Trans-Ams with modded engines, and then putting one of them sideways into the woods will kinda do that to ya
Old May 1, 2011 | 04:03 PM
  #122
dEnbOy.GFM's Avatar
So if I am reading this right... Are some of the aftermarket intakes completely nullifying the plenum mods?
According to the dyno sheets, all of the intakes were tested on Rob's upper and lower + 5/8'' spacer amirite?
Or are the test comments on the dyno sheets lying? That or I'm just dumb and don't understand what's going on.... Probably the latter.
It would make much more sense if the plenums mods were NOT on during tests 8-15...
Old May 1, 2011 | 07:24 PM
  #123
sexyrob's Avatar
yes some intakes nullified plenum mods.
my methodology was to give the intakes a free flowing plenum in order to isolate the best possible chance for a power gain on the intakes. basically less restrictions behind the intake.
Old May 2, 2011 | 12:31 AM
  #124
dEnbOy.GFM's Avatar
Wow. To spend $1000 on MD plenum+spacer and an intake to gain absolutely nothing (untuned)....... Glad I decided against an intake and stick with my z-tube + K&N...
EDIT: on that bombshell, thanks so much for doing this test... You just saved me $250+ dollars lol.
Old May 8, 2011 | 01:12 AM
  #125
gabe3d's Avatar
Rob, just saw this. Great contribution to the community as always with your threads. I should call you Saint Rob from now on. Hope to see and hear more from you on here and my350z.
PS: sent you a little donation for your work
Old May 8, 2011 | 09:08 AM
  #126
sexyrob's Avatar
thanks gabe, that means a lot coming from you!
now just send me those SG LTH since you are not using them
Old May 31, 2011 | 11:22 AM
  #127
walshtj's Avatar
Great write up and thanks for all the time, effort, and money it took to complete this test!
Old Jun 5, 2011 | 10:22 PM
  #128
RCL's Avatar
RCL
great info to know!
Old Jun 20, 2011 | 01:33 AM
  #129
_G35_'s Avatar
nice report, glad to know that some shops in my area actually know what they are talking about for once
Old Jun 26, 2011 | 04:25 PM
  #130
JaE35's Avatar
Moderator
G35 Sedan
the sound clips should make good text msg notifications haha, ordered me a ztube and revup air box
Old Jul 7, 2011 | 03:58 PM
  #131
KingCobra's Avatar
^ Good choice, make sure to get a new Apexi or K&N filter with that
Old Jul 15, 2011 | 12:45 PM
  #132
OCG35's Avatar
OP, do you switch between intakes? One for show, one for go?... you just posted this one:
fwiw, you can have show & go in one intake (my whole car was designed around the "show" and "go" concept )
Old Jul 15, 2011 | 01:34 PM
  #133
sexyrob's Avatar
thats correct.
although I'm still interested to try to get my car tuned with this intake on since its 2.85" D instead of stock 2.75" D... I know the 3" maf was making gainst on NA builds, and since I have cams and every other bolt on it would be interesting to see if tuning would make this intake perform better over stock.
the only thing I see as a issue is the heat soak. this pipe does get pretty hot and retain engine heat which will keep IATs up for a longer period of time compared to the stock box. I still plan on using stock box at auto-x and track events.
Old Jul 15, 2011 | 02:21 PM
  #134
OCG35's Avatar
it's not just the pipe you should be worried about... that unshielded filter is sucking hot air...
I know people like the looks of that style setup - but for me, it's not worth sacrificing performance for looks... like I said, you can have both.
I'm not suggesting you should change it - it's your car... I just thought is was ironic that you have this thread and you run that intake.
Old Jul 15, 2011 | 02:23 PM
  #135
sexyrob's Avatar
yeah it's on my car for shows and such... I still put the stock one in when it matters. I did feel kinda weird about putting it back in knowing what I know, but my car is getting a little showy and it looks weird having the stock box in there.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
