LED under glove box/steering wheel help
Old Sep 2, 2007 | 06:05 PM
  #46
IvoryGT's Avatar
You can always use a volt-meter to test.
I wouldn't recommend people to simply tap into the power source for many things. It's not designed to carry that much current through the little wires. A relay should always be used if possible.
on a side note, I can't believe I didn't read about this earlier, this would work perfect for one of my projects.
Old Sep 5, 2007 | 12:14 PM
  #47
Pulp's Avatar
Just a question, how would you go about incorporating a relay into this installation?
Old Sep 5, 2007 | 12:17 PM
  #48
IvoryGT's Avatar
if you have a basic understanding of relays then simply tap off the power from above mentioned source to the relay as a switch, then use the relay to trigger the accessories you want to draw power directly from the battery. This way you can potentially run as many things as your relay can handle as well as your battery.
Old Sep 5, 2007 | 12:22 PM
  #49
Pulp's Avatar
Cool thanks for the info!
Old Sep 7, 2007 | 01:58 AM
  #50
2K6G35's Avatar
You guys did amazing interior mod to your car. Kuddo!!
I found these online. Which do you think will look good in our car?
CCFL 15" w/sound control or
Ultra-Slim 15" LED Strips
Thanks for the info!
Old Sep 7, 2007 | 02:29 AM
  #51
805g's Avatar
+1 on the second link i would love to know if anyone has used these, and how they wired them in. Thanks so much
Old Sep 7, 2007 | 06:46 AM
  #52
TurboDreamzG's Avatar
I think this is a nice little project i'm going to do this weekend. I'd love to get some CCFL tubes. Lookin at some on ebay right now but just alittle cautious of purchasing them.....dont wanna get some crappy ones and have them go out. Where did you guys get yours that have already done the install....any off internet or all from pepboys, ect?
Old Sep 7, 2007 | 03:41 PM
  #53
IvoryGT's Avatar
coolerguys.com
Old Sep 7, 2007 | 03:55 PM
  #54
redlude97's Avatar
i bought mine from svc.com
Old Sep 7, 2007 | 07:15 PM
  #55
2K6G35's Avatar
Yes, I like that slim one too. Easy to put them on to any surfaces.
I am just worry if the leds will not show as bright as ccfl one.
Does anyone use the slim LED on G? Thx!
Old Oct 11, 2007 | 07:27 PM
  #56
bythabay's Avatar
So I am thinking of doing this mod, however, I also want the foot area to be lit up when the dome light is lit up. Let me clarify...
currently, the way you guys have it wired is whenever the dome light is on, these foot lights come on (both of them). Now, suppose the doors are closed because your driving or doing something else... what if you just turn on the passenger's side light by clicking it.. or the driver's side. I would like the appropriate foot light to turn on. Where can I tap into that switch? Do I have to pull the headliner?
Old Oct 11, 2007 | 08:22 PM
  #57
DHCrocks's Avatar
to get that to work you would need to get power from the switches. you can remove the whole light assembly (sunglasses holder and all) it just snaps into place with tabs. from there you can wire it in, you don't need to remove the headliner which is a big job since you need to pull the rear pillar trim which requires the rear seats to be removed.
Old Oct 11, 2007 | 08:23 PM
  #58
bythabay's Avatar
but how do I run the wire down to the foot area? Won't it have to be hidden under the headliner?
Old Oct 11, 2007 | 08:56 PM
  #59
DHCrocks's Avatar
you can pull the a pillar covers, they are just held in by snap clips. to get to the dome light you can tuck the wire from the edge along the windshield, just push it up there and it'll hold by friction between the liner and the roof.
Old Oct 11, 2007 | 09:50 PM
  #60
bythabay's Avatar
sweeeet.. i'll post some pics when I do it
