OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Feb 9, 2010 | 02:09 PM
  #181
The Stimulation's Avatar
Yeah...a body shop can do it. It won't be much of a pull I dont think...not to the point where it would result in the pinch welds showing. I'd PM 4dr. Madness. and see what he did...unless he chimes in here.
Old Feb 9, 2010 | 05:43 PM
  #182
STCLAIRWEST's Avatar
How much you think it runs and does it need to get repainted after after the pull?
I just decided im gonna buy them and make it work
Old Feb 9, 2010 | 06:21 PM
  #183
4drmadness's Avatar
yoo, ummm u will need around 3.5 or 4 degress negative camber, u dont really need a pull, but i would recommend it, as it will look better, also i suggest getting coilovers if you havent already. also get 235/35/19 for the rear, not 245.
Old Feb 9, 2010 | 06:24 PM
  #184
So without a pull it will fit with 4 degrees of camber? I plan on getting megan coilovers real soon just getting the rims first cause its a good deal.
Did you get a fender pull?
  #185
Na, no need for a repaint unless the person pullin the fenders doesn't heat it enough and if the paint cracks....for that pull I think you'd be cool. If you don't mind negative camber, dial in as much as you can and make sure you got toe bolts..if u need some rear camber arms lemme know.
As for how much the pull? I went through a forum member here and then for an extreme pull went a guy that hooks it up for me...from the forum member it was 70, but from the guy with the shop that I go to that hooked it up it was 50 bucks and my Jagermeister tap machine lmao
Old Feb 9, 2010 | 06:26 PM
  #186
There you go...4dr. Madness chimed in, haha...Vivek, post a pic of ur ride. I cant be on the forums too much at work
He didn't do a pull though, just rolled. Once you see the car you can tell with the car being a lil lower and a lil bit of a pull, it'll be money. Right now it looks good, but IMO it can look better, that's why he's gonna be doin the pull.
Old Feb 9, 2010 | 06:29 PM
  #187
So other then coilovers what else would i be needing for camber?
Sorry for all the noob questions
I will most likely do a pull later on but trying to get these rims to fit on a budget LOL
Old Feb 9, 2010 | 06:52 PM
  #188
4drmadness's Avatar
well if u get coils, then u should look into getting camber arms, and then alignment, pretty much it. I just sold my megan coils, and im going with bags.
Old Feb 9, 2010 | 06:54 PM
  #189
4drmadness's Avatar
  #190
Ghayes23's Avatar
^you need camber arms for the front and rear, and toe bolts or toe arms for the rear.
Old Feb 9, 2010 | 06:59 PM
  #191
What would happen if i didnt get camber arms? no fit?
Old Feb 9, 2010 | 07:04 PM
  #192
Ghayes23's Avatar
Depending on how much you drop and what you do with the fender roll/pull they might fit, but you wouldn't have as much adjustability to get them where you want them.
Old Feb 9, 2010 | 07:08 PM
  #193
Any recommendations on which kind are better? Im real clueless when it comes to this aggressive fitment movement, just really like the looks.
Old Feb 9, 2010 | 07:35 PM
  #194
Get_some35's Avatar
you wouldnt need that much pull. i had 19x10 +24 in the rear. i was just rolled flat and it looked like i had about 5mm of clearance with a 235/35 tire and no camber arms
Old Feb 9, 2010 | 08:04 PM
  #195
For the rear I recommend SPC or Battle Version. I stick to Battle Version just because I like them. SPC would do the job, so does Battle Version, but Battle Version arms allow you to swap the links for longer ones for more camber if need be...the others dont.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
