DIY: Airbag Reset Instructions for 03-07 G35 Coupe
Old Jul 13, 2011 | 10:28 PM
  #106
majnounG35's Avatar
Thumbs up Airbag light flashing after paint job of bumpers
Originally Posted by SFLG35
this is a little easier
To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
Just repainted the front and rear bumpers because of a few scratches on my G35x sedan 2005. The airbag light start flashing.
Did the on - off 4 times -- Worked like a charm....
Thank you so much. Your a champ
Old Sep 7, 2011 | 04:10 PM
  #107
famiglia's Avatar
How diagnose, or get error code
If after resetting it comes back on, looks like you can get a code from the blink sequence specifying the error. See
Mine just did not come back. I am assuming it just sometime falsely fires.
Old Sep 19, 2011 | 11:17 AM
  #108
YOUNG1TRAN's Avatar
It worked!!!! Thank you. If only this apply to the immobilizer......
Old Oct 4, 2011 | 01:35 AM
  #109
Canadiotica's Avatar
Very weird In the summer I had to do this reset a few times. Now my light has not came on in over 3 months! *Fingers crossed. Does this mean the sensor is fixed or ? hah
Old Oct 9, 2011 | 04:13 PM
  #110
eDUBsG35's Avatar
Worked for me 06 coupe thanks.
Old Nov 2, 2011 | 12:59 PM
  #111
X-FactorWR87's Avatar
CLUB MODERATOR
this is good to know! thanks
Old Dec 11, 2011 | 04:17 AM
  #112
unlocknick's Avatar
SFLG35 was right about resetting airbag light
I have a 2003 G35 did what he said and the light went away. Big Thanks
Old Dec 13, 2011 | 09:07 PM
  #113
R6n350GT's Avatar
can you still do this if you ecu has been flashed ?
Old Jan 6, 2012 | 02:43 PM
  #114
ScottHyon's Avatar
Worked perfect! Thanks guys.
Old Jan 6, 2012 | 03:16 PM
  #115
flynmoto's Avatar
HEY HEY Worked for me Too!! Thanks!
Old Jan 12, 2012 | 10:08 PM
  #116
spddmn124's Avatar
I did this today after fixing my driver side seat squeak. It worked flawlessly.
Old Feb 3, 2012 | 11:27 PM
  #117
SilverGthang's Avatar
Paid $42 to get my 03 Sedan Airbag light reset and also stopped the driver seat from stuttering, but the srs airbag light came back on after a few days... I tried this and boom no more light... Thanks!!!
Old Feb 8, 2012 | 12:45 AM
  #118
SithSX's Avatar
BOSS!!
Worked like a stripper in Vegas!!
THANK YOU
Old Feb 9, 2012 | 08:23 PM
  #119
srini's Avatar
confused
I have this problem for a month now. I took my car to Beshoff Infiniti in San Jose last week. I was charged 155$ to diagnose the problem. The only explanation I get after spending 155$ is that I should replace one of my air bags. They have no clue as to what is wrong and what caused the failure. They told me it would take 600$ more (300$ for part + 300$ for labor) to fix it. Service Manager told me he was not sure if the problem will be fixed after replacing the airbag system. I called Infiniti customer care straightaway and told them how is it that one fine day my airbag stops working given that it was never deployed. They immediately got in touch with dealer and gathered all the information. They opened a case and asked me to wait for 2-3 days.
I got a call yesterday saying that Infiniti cannot help me this time and it was not covered under warranty. I made my point very clear. Everything on the car is factory. I never touched anything. One fine day a light blinks and you ask me to pay 750$ to fix it without knowing who and what caused it. If I understand it correctly an airbag should last as long as the car lasts unless deployed. An electrical problem shouldn't cost me 750$ to fix it. I told them I am not satisfied with the response and I want to escalate the case.
I read this thread today and I cannot believe a simple routine can fix the problem. I ll try the routine today and check if the light stops blinking. I have lot of unanswered questions here
a) If the light stops blinking, why is it that the dealer didn't do this routine ?
b) If the light stops blinking, is it safe to assume that air bags are functional ?
Old Feb 19, 2012 | 01:51 AM
  #120
mysoda's Avatar
thank you very much
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
