Reviews Reviews of specific modifications, posted by members
Motordyne Plenum Spacer, Discussion, Dyno Info
Old Feb 25, 2005 | 02:16 AM
  #166
Hydrazine's Avatar
Hi guys,
I got the raw data from the G35 dyno day entered into Excel. The plots are looking really good. Gains in HP and TQ all across the entire RPM range! Hi, Low, Mid, Everywhere! I will get it posted tomorrow. There are many plots!
Old Feb 25, 2005 | 04:29 PM
  #167
shawns1234's Avatar
Originally Posted by MOTOP
shawns1234,
I'm sorry that mod didn't work out for you.
Do you have any plans on upgrading you exhaust? If so, get just a y-pipe. Install it, get used to results and than install spacer again, just for the sake of experiment.
The only mods I had on my sedan prior to installing 3/8" spacer were y-pipe, z-tube and grounding kit. I'm really impressed with the spacer and my observations seem to be in line with what many other people reported. I think stock intake and exhaust are pretty well matched and when upgrading things it is important to try keep that balance.
Good luck.
Sounds like good advice. I really don't want to have to search for this, but does the Y Pipe remove the cats? I can't remember... I'm still thinking about what to do. I am really confused on why I had the experience I did, and everyone else is so happy with it. I really would like it to work on my car. 8 - 10 HP for $135 is a pretty good deal considering other options. I installed it correctly, and everything seemed to be perfect,,, I just didn't get the results you guys did. Maybe I'll try it again.. I don't know. Sorry to be a post Wh@#e
Old Feb 25, 2005 | 06:15 PM
  #168
jjellyneck's Avatar
You keep the cats on the car. The Y pipe attaches to the back of the cats and then to the muffler in back. A good aftermarket Y pipe will make the exhaust breathe better and will likely increase the effectiveness of a plenum mod.
Old Feb 25, 2005 | 07:15 PM
  #169
DaveB's Avatar
Originally Posted by Hydrazine
Hi guys,
Sweet deal. Thanks for doing all this.
Old Feb 26, 2005 | 12:12 AM
  #170
Hydrazine's Avatar
Dizz Dynos
These are the results of the recently performed dynos on a 1/2" Motordyne spacer. The spread would have been even higher if the dyno operator didn't cut the runs at 5900 rpm.
Attached Thumbnails Motordyne Plenum Spacer, Discussion, Dyno Info-plot-1.gif   Motordyne Plenum Spacer, Discussion, Dyno Info-plot-2.gif   Motordyne Plenum Spacer, Discussion, Dyno Info-plot-3.gif
Old Feb 26, 2005 | 12:13 AM
  #171
Hydrazine's Avatar
Dizz Dynos
more plots
Attached Thumbnails Motordyne Plenum Spacer, Discussion, Dyno Info-plot-4.gif   Motordyne Plenum Spacer, Discussion, Dyno Info-plot-5.gif   Motordyne Plenum Spacer, Discussion, Dyno Info-plot-6.gif
Old Feb 26, 2005 | 12:14 AM
  #172
Hydrazine's Avatar
Dizz Dynos
More stuff
Attached Thumbnails Motordyne Plenum Spacer, Discussion, Dyno Info-plot-7.gif   Motordyne Plenum Spacer, Discussion, Dyno Info-plot-8.gif   Motordyne Plenum Spacer, Discussion, Dyno Info-plot-9.gif
Old Feb 26, 2005 | 12:15 AM
  #173
Hydrazine's Avatar
Dizz Dynos
Final results at 5900 RPM.
Oh Yeah, I will also post the results for NUTTYPROFESSOR.
Attached Thumbnails Motordyne Plenum Spacer, Discussion, Dyno Info-plot-10.gif
Old Feb 26, 2005 | 11:44 PM
  #174
1Z TWO Z's Avatar
I was able to get the engine cover back on with the 1/2 inch plenum spacer.
I removed the gromets and the rubber washers from the top holes of the engine cover. I then inserted the gromets back into the holes from the bottom of the cover and slipped on the rubber washers onto the gromet from the top of the cover. I then placed the cover over the plenum and screwed it in. The hood won't drop shut, you must slam it down a bit or just push down slightly and the hood locks down.
Old Feb 26, 2005 | 11:58 PM
  #175
scoobybri's Avatar
My question is this...where do you order the spacer from? Can anyone give me a web address?
Old Feb 27, 2005 | 12:38 AM
  #176
KAHBOOM's Avatar
Looks like it's time for me to get on the stick.
Old Feb 27, 2005 | 08:43 AM
  #177
jjellyneck's Avatar
...from Hydrazine, a couple of posts above. PM him.
Old Feb 27, 2005 | 11:31 AM
  #178
Hydrazine's Avatar
Scobybri,
My web page designer said the web site should be up a little later today!
www.motordyneengineering.com
You can find all the ordering information there.
Tony Colette
Motordyne Engineering
Old Feb 27, 2005 | 12:52 PM
  #179
maxpower's Avatar
Scobybri,
Tony Colette
great news, looking forward to seeing the site up and running. will it have any hp and tq numbers for the 3/8" spacer? I have seen a lot of numbers from the 1/2" group, but nothing from the 3/8"
thanks
Old Feb 27, 2005 | 01:06 PM
  #180
tazdevl's Avatar
Tony, did you verify oil temps before running the dynos?
