Reviews Reviews of specific modifications, posted by members
Motordyne Plenum Spacer, Discussion, Dyno Info
Old Mar 12, 2005 | 07:44 PM
  #211
g35audioman's Avatar
Originally Posted by 1Z TWO Z
Here you go:
I was able to get the engine cover back on with the 1/2 inch plenum spacer.
I removed the gromets and the rubber washers from the top holes of the engine cover. I then inserted the gromets back into the holes from the bottom of the cover and slipped on the rubber washers onto the gromet from the top of the cover. I then placed the cover over the plenum and screwed it in. The hood won't drop shut, you must slam it down a bit or just push down slightly and the hood locks down.
Since it seems there is a bit of force used to actually close the hood, my concern would be the amount of pressure being placed on the locking mechanism of the hood. I wouldn't want to risk the possibility of the hood unlatching when i'm on the road. It would be a hassle if it did happen.
Old Mar 13, 2005 | 07:22 AM
  #212
paranormal's Avatar
wow.. i just read this whole post..hahaha.. good info. im buying mine this week.. werd to ya mother..!! this will work fine on a 05 correct?
Old Mar 14, 2005 | 11:41 PM
  #213
Hydrazine's Avatar
Works just fine on the Ohhh Five.
Old Mar 15, 2005 | 04:22 AM
  #214
Sukairain's Avatar
My concern with the 1/2" spacer is that - if you need to manually push down to close the hood, that means the engine cover and the hood thermoshield are actually pushing against each other when the hood is closed. So what would happen if you hit the throttle and the VQ35DE sways around in the engine bay? Sounds alittle dangerous to me.
Old Mar 15, 2005 | 06:03 AM
  #215
Yea. Then when you take it to the dealer for something, and they can't close the hood easily, they might get suspicious; thus defeating the whole "stealth" idea behind this modification...
Old Mar 15, 2005 | 09:46 AM
  #216
Hydrazine's Avatar
This is why don't recommend using the 1/2" spacer (with the engine cover) on the G35C.
It's either 3/8" with the cover or 1/2" without the cover.
Old Mar 16, 2005 | 12:26 AM
  #217
1Z TWO Z's Avatar
The 1/2" spacer with the cover has worked well so far. To close the hood cleanly I just push down with my finger tips as its dropping and it slams shut everytime. There is contact with the shield on the hood at two points on the right side but just barely. Its a simple adjustment with the gromets in the back of the cover to get it to fit. Its a matter of preference I quess. The engine bay looks good with or without the cover.
Old Mar 16, 2005 | 12:47 AM
  #218
Hydrazine's Avatar
That's cool. I just try to be conservative on fitment issues so everyone knows what to expect. Someone could glance at single post in the whole thread and assume it means one thing, try it and find it didn't work for them.
Thanks for the feedback and experimentation. You are the first I know of to try it. At least now we know it can be done sucessfully (with certaint provisos).
Albert did the first Crawford and 1/4" Spacer. (sucessfully)
Derick did the first Kinetix and 3/8" spacer. (sucessfully)
We'll never know untill its tried.
Tony
Old Mar 17, 2005 | 07:32 PM
  #219
roko's Avatar
Spacer
Installed 3/8 spacer today. Install was straight forward no surprises. Went for a ride after, sounds great and there's more power. Tony the service and packaging are great.
Thank you
Old Mar 19, 2005 | 04:46 AM
  #221
moto35's Avatar
i cannot believe i just finished reading 15 pages of this thread!! i am pretty convinced that the spacer will give a noticeable increase in hp/tq... i think i will be contacting tony shortly.
Old Mar 19, 2005 | 08:27 PM
  #223
scoobybri's Avatar
Finally, a good comparison. Now, we need someone with an 05 6MT to do the same thing. I want to see if the change in the lower plenum design make the spacer work better or worse. I'd hate to spend $200 just to find out that the '05 plenum and spacer only nets 1HP and 2lbs. of torque or sumpin' like that. Who's gonna take the plunge?
Old Mar 19, 2005 | 10:06 PM
  #224
DaveB's Avatar
The gains look great. Thanks for posting.
Old Mar 19, 2005 | 10:21 PM
  #225
realdieu's Avatar
Congratulations!
I must say that the plenum spacer has to be the product of the year! Brilliantly designed, simple, and unobtrusive. Those manufacturers trying to redesign the wheel must be scratching their heads right now…
