SFL G CLUB South Florida G35's + G37's
Help!! VDC, SLIP, & ABS light all on!
Old Mar 6, 2010 | 12:25 PM
wouda's Avatar
Hey folks,
So I'm having major car issues right now and need some help finding a local shop that can help me out..
Problem description:
So after getting my car washed, I notice my VDC off, ABS, and SLIP lights were on immediately after they gave my car back to me. The car was still driving okay but decided to pull over and see what the problem was. When I parked, I couldn't get the car out of park! After disconnecting the battery and starting it back up, I still couldn't get the car out of park w/o using the shift lock button and the back brake lights no longer working.
FYI: One thing I noticed was when the guy drove my car under the washing canopy he left the hand brake on and it made a screeching sound, but it was only 10 ft drive. Not sure if that could have caused this.
This morning I took the car to Sawgrass Infiniti, and guess what.. They didn't know what was wrong either... But said they needed at least 4 hours of diagnostic time ($$$) to figure it out.. After doing searches on this site it looked like it was the brake switch and asked them to change it. They reluctantly changed it but didn't seem to fix the problem. The technician put in a new brake switch but didn't install it completely. Just plugged it in and pressed the button the brake padel would hit to see if my brake lights would come on.. No dice.. So they ruled out the fuses and brake switch (I'm not completely sold on it not being the brake switch)..
Need some recommendations on where I could go in South Florida to get this fixed ASAP! Everything seems to be running fine mechanically. Brakes are a little sensitive, but working. HELP!!
Had a date tonight...
Old Mar 6, 2010 | 01:49 PM
thescreensavers's Avatar
Mr.202?
Check the brake fluid level.
Go to autozone or pepboys and use thier OBD reader and see if it tossed any codes. You may need one that can read ABS.
Read this as well
Good luck man, maybe you can get it fixed before tonight, you still got some time
Old Mar 8, 2010 | 09:54 AM
APSMike's Avatar
Brake fluid level ^+1 May be time for new brake pads.
Old Mar 8, 2010 | 11:27 PM
CarlosM's Avatar
Maybe the grounding ???
Old Mar 24, 2010 | 03:30 PM
R1ricer's Avatar
I had a similliar problem after changing a rack and pinion in the G35. It turned out to be the steering positions sensor.
Old Apr 9, 2010 | 05:43 AM
gck's Avatar
gck
you can try a nissan dealership(cheper than infiniti's).. :O
Old Apr 9, 2010 | 05:44 AM
gck's Avatar
gck
look up THROTTLE BODY
Old Jul 1, 2010 | 07:39 PM
stevenpiazza's Avatar
i have a similar problm and i dont know wher to go with it....my handbrake, vdc and slip lights come on....but my car is very driveable. last time i brought it to infiniti they told me i needed to change the rear brake pads, but im not very sold on that idea, as they are fine to me (4mm). Im wondering if its because i need an alignment....maybe it causes the lights to illuminate? any ideas?
Mry
Mar 3, 2023 01:03 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
03sedang35
Aug 29, 2015 07:56 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
