TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Infiniti Rev-Up Oil Consumption TSB
Old Dec 12, 2011 | 06:53 PM
  #1696
rhampsterwha2's Avatar
Personal experience says its a long and hard road but if theres no sludge or signs of improper care there could be a possibility
I have a 07. 5at with 40k and after 2 months without my G i got a new block
Old Dec 12, 2011 | 09:04 PM
  #1697
Calamity's Avatar
Well yours is still under the 5-year warranty isnt it? Mine being almost 8 years old I dunno if mine would be covered
Old Dec 12, 2011 | 09:43 PM
  #1698
TrixR4kidz's Avatar
Originally Posted by rhampsterwha2
this is what ive heard too and the new block i feel is soo much stronger like more low-end torque, my guy at pearson infiniti (who happens to be a 12+ year master tech) even said that it felt stronger and was the quickest he has drove that was stock, idk if hes just telling me that but my butt dyno agrees LMAO
i can say the same. it feels faster and i dont even have my ART pipes on.
Old Dec 13, 2011 | 09:45 AM
  #1699
Texasscout's Avatar
Originally Posted by VQ35 revv
Dont see the point of that if the oil pump suction cant reach the extra quart of oil?
The point is, there is MORE oil to keep things cool.
BTW, I think that is only a problem with the oil pan SPACER.
Old Dec 13, 2011 | 12:27 PM
  #1700
Calamity's Avatar
So does anyone know if i'd be able to get coverage? 2004 5at coupe, 59k miles with major consumption issues
Old Dec 13, 2011 | 12:48 PM
  #1701
TrixR4kidz's Avatar
1 miles till your power train runs out? i would take it to the dealer like TODAY
Old Dec 13, 2011 | 01:52 PM
  #1702
Its a long shot but you can take it to the dealership and get them to chnge your oil and start a OC test
Worst thing is they could tell you no then at least you know, best of luck you will need it
Old Dec 13, 2011 | 08:27 PM
  #1703
V35 Skyline GT's Avatar
6MT Coupe
Powertrain warranty is 6yrs/70K miles which ever comes first. A 2004 is out of warranty even if it only only had 30K miles on it.
Old Dec 14, 2011 | 12:20 AM
  #1704
Calamity's Avatar
So absolutely nothing will cover a swap?
Old Dec 14, 2011 | 12:32 AM
  #1705
alfhasg35's Avatar
2004 is SOL..
6yr 70k miles.. no ifs ands or butts....
unless u have an extended warranty..??
Old Dec 14, 2011 | 11:09 AM
  #1706
Black Acc's Avatar
You don't have a Rev-up motor so it might be harder to do so. However if you can afford extended warranty, get it through Courtney, they have the best deal! (link below)
https://g35driver.com/forums/g35-cou...-warranty.html
I'm getting the extended warranty and then taking my car in for the problem. I have a rev up motor though...
Good luck!
Old Dec 16, 2011 | 02:07 PM
  #1707
buzzking's Avatar
Getting new block
05 MT coupe with 69~70K miles.
Went back after 1K miles and oil dropped 18mm.
Getting new short block.
I requested Long block, but they will only do the short since that's what the TSB says.
They "say" they will look at the whole engine to replace other parts that might have been damaged but I don't trust KM Infiniti that they will do that.
The reason I requested a long block was because I recently found out about my oil consumption problem at my last oil change and about 2 weeks before my last oil change, my car must have been running on ZERO oil and my car kept heating up for 2 weeks and I couldn't figure out why until I went in to get my oil change. Now, even with the last oil change, my car over heats and when I went in for the oil change, they told me I had no oil in the car.
Is there anything I can do to get the whole engine replaced? I called Infiniti Consumer Affairs and they told me it is up to the dealership. Today they ordered the short block, but I don't trust my dealership when they "say" they will check out the whole engine...
Old Dec 16, 2011 | 08:51 PM
  #1708
Calamity's Avatar
Wish I had gotten that extended warranty instead of this useless scam from the used car dealer
Old Dec 29, 2011 | 11:12 AM
  #1709
N80's Avatar
N80
This is a loooong thread. And I'm sure, somewhere deep inside it this question has been answered. But I've got an 06 6MT coupe. I'm the third or fourth owner. Bought it at an Infiniti dealership. It has 89k miles on it. It is now burning oil. About a quart every 1500 miles.
It is out of warranty on time and miles.
So the question is, does Infiniti do anything for you if the warranty is gone?
Old Dec 29, 2011 | 11:57 AM
  #1710
syshs's Avatar
A quart every 1500 miles sounds normal.
No warranty, no work.
You have already rated this thread Rating: Thread Rating: 4 votes, 3.75 average.
