TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Infiniti Rev-Up Oil Consumption TSB
Old Mar 28, 2012 | 02:18 PM
  #1771
trulegend's Avatar
hello guys,
i have a 05 6mt coupe with 96k miles, no oil consumption issues, *knock on wood*
Can the oil consumption issue come up later in the car's life? or is it safe to say i wont have this issue.
thx
Old Mar 28, 2012 | 04:50 PM
  #1772
Texasscout's Avatar
I have 110K on mine with not problems yet.
Old Mar 28, 2012 | 05:20 PM
  #1773
kasher_khan's Avatar
picked up car today after short block replacement
Had the G37 sedan for almost two weeks. As good a car that is I really missed my coupe. I only drove it from dealership to office so far. Feels smoother Don't know if thats in my head (probably cause of the oil change and what not - always feel nicer after new oil change). I had some what of a knock in my engine so I'll check. Set my tach to 3000 rev light. I didn't realize our cars had so much low end torqe. I always like to rev it higher to hear the sweet exhaust anways. Will follow the break in and keep it low for the next 1000 miles.
Anyways I am wondering if there is anything I should be on the look out for...
Old Mar 29, 2012 | 02:03 PM
  #1774
Unhappy rattling noise in cabin after engine swap
So got bad news. I drove the car yesterday and it seemed fine till I hit the highway. It seems there is a rattle in the car in 6th geat at 65mph. It feels like it is comming from the dash. Also I noticed that the ashtray holder doesn't line-up perfectly.
Do they have to open the center console\dash to do the engine swap??? It seems something wasn't put back together?
Old Mar 29, 2012 | 02:31 PM
  #1775
DGrantG's Avatar
They have to pull the transmission out so if the have to undo a bracket or something for the shifter then theyd have to pull the center console apart.
I just left the dealer where my car is and it was in a million pieces!
I'm looking forward to getting in back tomorrow afternoon bc it's gonna be like brand new! New clutch, spark plugs, diff fluid. He's installing my test pipes and going to fix my exhaust where the mufflers don't line up right too!!! Woo hoo!!!!
Old Mar 29, 2012 | 05:23 PM
  #1776
buzzking's Avatar
Originally Posted by NGK
i'll try! but if you've had it since LAST december (10, or 11?) over a year, i wouldnt worry too much...however this past december - its worth checking....
one easy way is to drop the plastic cover on the bottom of car (bunch of 10mm bolts) and look for any oil spots on the cover, and also on the bottom of the block
What parts of the engine do you need pictures of.
Looks like there is a little bit of oil leaking, all that oil is since the last week of Dec/2011
Old Apr 3, 2012 | 06:54 PM
  #1777
NGK's Avatar
NGK
that is all you needed a pic of.....any oil is cause for a return to dealer IMHO
NGK
Old Apr 4, 2012 | 09:10 AM
  #1778
DGrantG's Avatar
^I'm with you on this one. I would take it back to the dealer asap for any kind of fluid leak.
The tech that did the work on my car did a great job and went above and beyond by hooking me up with some free services. Last night on my way home from work, my gravel guard flipped down and got messed up on the interstate and I had just gotten it like 2 months ago. If it wasn't for the Infiniti tech taking such good care of me, I would be taking it back to the dealer for them to replace it but he's going to get me one ordered at cost.
Old Apr 14, 2012 | 05:35 PM
  #1779
Max_Powers's Avatar
I just found out that my 06 coupe failed the OC test. My dealer informed me that they have started the process to approval for the new engine. The lady told me that its probably gonna be a long block but after reading everything here I'd be surprised if that's the case.
I'm sort of bummed out cuz of all the problems people have reported with the replacements. For the people who got replacements within the last year or so, how does the engine feel after the break-in period?
Old Apr 14, 2012 | 06:28 PM
  #1780
DGrantG's Avatar
Should be a short block and it took about a week for them to order my motor.
Mine feels nice and strong but it's in been about 200 miles since it was replaced.
Old Apr 14, 2012 | 07:02 PM
  #1781
buzzking's Avatar
NGK
They checked it out, they said no leak...
Old Apr 14, 2012 | 07:03 PM
  #1782
buzzking's Avatar
Engine feels great.
When I failed OC test they told me I'd get a longblock.
Then when I came back in for the labor once the parts came in, they told me then that I'll be getting a short block since that's what it says to give me on the TSB.
Old Apr 14, 2012 | 07:07 PM
  #1783
Shanes_G's Avatar
do you have to have a warranty to get your engine replaced?
Old Apr 15, 2012 | 10:24 PM
  #1784
Max_Powers's Avatar
Thanks DGrantG and buzzking for the replies. Yea I'm expecting a short block regardless of what they say. Its good to hear that the rebuilt engines are doing well. The odometer reading won't change after the replacement right?
The Powertrain warranty covers the engine, which is 6 years from the date of the original purchase or 70k miles, whichever comes first; unless you have extended warranty.
Old Apr 15, 2012 | 10:26 PM
  #1785
DGrantG's Avatar
Naw the odometer doesn't change.
As for the warranty, they told me it was 6/60 for the power train.
You have already rated this thread Rating: Thread Rating: 4 votes, 3.75 average.
