Light in Glove BoX!!
SOLUTION:
It IS normal. Buy some self-adhering foam weather stripping tape that you'd use on your storm door at home. Choose a density that you believe will be sufficient to better seal the opening and cut to size (there are dozens of thicknesses).
I had to do this for my glove box because my seat is all the way back and the light peeks from inside just enough to annoy me. A 0.50"x0.50" foam piece the length of the width of the glovebox solved the problem in 30 seconds. Peel of the backing and stick it in place...and it looks factory, and its graphite colored too so it seamlessly blends in
Where's the ingenuity in this forum?! Hit Home Depot or Lowe's and fix it!
