DIY: Installing Sport paddles
Question about Installed paddle shifters.
when you have the factroy installed paddle shifters, you can use them even in D mode and do not have to change to the DS mode. And i think but i am not sure, when you use them in D mode, after a while it reverts back to the D mode from the gear number in the screen.
Do the installed paddle shifters perform the exact same way as the factory installed paddle shifters do?
Hey,
I haven't really posted here but really want to add paddle shift. I need your help, my wife wants to buy this as a gift for me, but not sure if it will work on my car (and need to know the color I need to buy).
Here is a snap of the interior:
so first, am I getting the Stone/Willow color or should I go for the Graphite / Black? I haven't seen pics on the differences. I don't want to spend $200 on the wrong one.
2nd - I want to make sure my car has the wiring without removing the steering wheel. I bought the car used (it is a 2007 G35) but don't have anything on paper that tells me the model number. I have to check my paperwork again. I think I have almost all the features with exception of it being AWD. It has the hard drive, XM, intelligent cruise control. I have read the Sport models do not have the wiring. How do I figure out what model I have? Thanks in advance!
Also - who is still selling the kit that I can be referred to? I see that guy Jason no longer works at the dealer everyone was buying from. I have this link saved in my bookmarks:
http://www.infiniti-parts.com/catalo...dle%20Shifters
The two options from this website is Graphite/Black and Stone/Willow. Which one do I need for my car?
grafite for sure!! talk to rick or tony @riversideinfiniti!! willow would stand out like a sore thumb!!! imo!
from what i understand all newer g's except some 09 g37 are pre-wired!
rick
@riversideinfinti
kodg man
rick
@riversideinfintikodg man
Originally Posted by kodg man
Grafite Black/your Steering Column/interior trim Is Grafite. (also your shift ****&leather wrap are grafite) They Come Grafite W/chrome Trim On Outer Edges. Their Is A Great Diy Posted On This Site For Install!! (w/step by step pictures)
Not Hard, Just Take Your Time & Get A Set Of tamper Proof Torch Wrenches Bits!!! auto Zone Or The Like W/carry Them. Search For The DIY Thread! If You can not FIND Thread Than Send Me Your E-mail I Might Still Have It Saved & Can Shoot It To You.
Very Easy Just Do Not Strip The Two Torch Screws Or Your Screwed!
Kodg Man
Kodg ManLast edited by kodg man; Dec 2, 2008 at 08:46 AM.
Wait drill them out? Are you talking about someone that stripped the bolds? Also, what is a Torch Wrench? Or did you mean a Torx screwdriver set???
drill them out & then use a re-tap tool in holes for new treads.
I used a torx bit on a power drill to unscrew the bolt, not to drill out the bolt. That sucker was on there super tight. Not sure if I could have broken it loose w/o power tools.
How much torque is on this thing? Is a cordless drill good enough or does it need more power???
He stripped it.....either careless or wrong bit.
try a reverse bit rather than drilling it out. Try not to damage the bore.
You don't need any power tools to do this project. If you don't know what a Torx bit is, don't do this.
Thanks for all your help.
I got it out with no problems wish I had done this on the first place. I tried all the reverse screw removers I could get my hands on, they just stripped the head of the bolt even more. I got it out by doing the steps.
First I used a bit that was small enough to fit inside the torx hole and removed the center pin and then I used a bit the was a little smaller then the top of the bolt and removed the whole top of the bolt.
Second I tapped the bolt threw the hole with a punch and small hammer. The mounting points of the air bag are just thin pieces of medal and can move.
Once I got the airbag out I was able to get the bolt out the rest of the way with a pair of pliers and did not damage the threads on the Air Bag. All of this took about 10min. I fallowed the rest of instructions and finally finished installing the paddle shifters.
