DIY: Installing Sport paddles
Old Feb 15, 2010 | 03:06 AM
  #271
cmori's Avatar
Just FYI, I did this in my 2010 G37 Sedan Journey and the DYI remains accurate. It works perfectly.
Thanks!
Old Mar 11, 2010 | 01:58 PM
  #272
DocEck's Avatar
Completed on my 2010 G37x
Hey all. I took the plunge and bought a Graphite Shadow '10 G37x. My only regret is not splurging for the "S" package. With that said, found this thread to add paddle shifters. I received the shipment yesterday and installed them last night in about 1.5 hours. I encountered one problem. I got some of the red Loctite on the top trim piece resulting in turning the black piece yellow. It looks like someone took a yellow highlighter and dabbed on the plastic. My car is 3 weeks old and I am a bit peeved at my inattention to detail. Anyone have any thoughts on how to remove this yellowing of the graphite trim? I tried water with mild soap and a light dabbing of a "Mr. Clean Magic Eraser." Any thoughts or suggestions is much appreciated!
I do have another option, I can replace the top trim piece, but I cannot figure out how to remove the cloth (vinyl/plastic?) piece the attaches to the top trim piece covering the steering column. Any thoughts on this as well?
Old Apr 16, 2010 | 01:27 AM
  #273
justin h's Avatar
G35
Use Back to Black, it's for darkening exterior plastic when it gets grey. If that doesn't work, you could use a sharpie to blacken. Then, back to black could give it all an even shine/finish.
Old Apr 17, 2010 | 01:11 AM
  #274
kevil7's Avatar
My lease is up so I have a set for sale. Complete kit for a black interior.
PM me. Looking for $150 shipped. OBO
Old Apr 22, 2010 | 08:59 PM
  #275
JayDeePee's Avatar
Hey Kevil 7. I am interested. Do you have the complete kit? Email me @ dwnlow91@hotmail.com
Old May 8, 2010 | 10:18 PM
  #276
javisaman's Avatar
I tried this mod myself, but I was having a terrible time removing the first two screws (T30 tamper-proof bit) I stopped after noticing I was taking off some of the thread. Did anyone else have this problem with supertight screws?
Thanks
Old May 10, 2010 | 01:32 PM
  #277
2007BlueSlate's Avatar
Thanks
You need to go to store like Sears and buy the tamper proof bit for a couple of bucks. You cannot take off the screws without this little bit.
Old May 10, 2010 | 01:34 PM
  #278
javisaman's Avatar
I am using that bit though (essentially a torx bit with a hole in the center right?). I got a set from Autozone for $10
Old May 10, 2010 | 01:41 PM
  #279
Yea, sounds like you got the right one. The only thing that I can think of is that you don't have the right size, but other than that the screw should come out pretty easy.
Old May 10, 2010 | 01:43 PM
  #280
javisaman's Avatar
maybe a stupid question, but should I be twisting it clockwise or counter-clockwise then? I'm using t30 though I read another thread that said the bit should be t27. I might try some loctite too.
Old May 10, 2010 | 01:56 PM
  #281
Lefty = Loosy (counter cw), Righty = Tighty (cw). I used the T30 when installing mine.
Old May 10, 2010 | 05:29 PM
  #282
G-Man.usa's Avatar
This mod is awesome! This might be a silly question but which paddle switches up and which switches down? Are the cables long enough to connect to either paddle?
Old May 10, 2010 | 05:43 PM
  #283
I believe for all cars with paddles, the right one is upshift and the left one is downshift. If you wanted to switch this up the cables should be long enough to plug into the opposite plug, not really sure why you want to but to each their own.
Old May 11, 2010 | 10:31 AM
  #284
sameerg's Avatar
I recently installed paddles on my car - without removing the steering - i did not have the B@llz to remove the wheel. Took me 15 minutes total for the upgrade.
So, i did not need the tamper poof thing.
Old May 11, 2010 | 10:33 AM
  #285
javisaman's Avatar
Can you explain how you did that?
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
