Idle RPM drop??
Old Oct 22, 2009 | 02:30 PM
  #106
pfarmer's Avatar
Originally Posted by G35s-Dude
Notice that everyone is from GCC area having the same problem, and i wonder if all of them own a 2008 model.
I think with something like what may seem like a common problem that it would be beneficial to post year, model, and any mods regardless of how benign they may seem.
Old Oct 22, 2009 | 08:45 PM
  #107
xo4ox's Avatar
I have the same problem and my car is 2009 coupe and I'm from Saudi Arabia
Old Oct 23, 2009 | 05:22 AM
  #108
Q8y_drifter's Avatar
08 Sedan, Kuwait (GCC Spec)
Old Oct 24, 2009 | 11:04 AM
  #109
Iori Yagami's Avatar
Same thing.
08 sedan, Saudi Arabia
Old Oct 26, 2009 | 04:10 AM
  #110
Bahg35's Avatar
Same Issue (FIXED),
08 SEDAN GCC SPEC, Bahrain
Old Nov 8, 2009 | 05:47 PM
  #111
Glover997's Avatar
same here . .
08 G sedan GCC SPEC, Oman .
Old Mar 19, 2010 | 07:17 PM
  #112
baileyt35's Avatar
O.k. so I have no engine mods and after the reflash am having the same idle issue. I've taken it twice to the dealer only to leave and have the same issue. I have another appointment this Thursday, I intend to leave it until it is fixed. This is beginning to really work my nerves. I guess I could recommend them cleaning the TB. Anyone get a fix from their dealer?
Old Mar 20, 2010 | 01:31 AM
  #113
What reflash do you have? Someone here took his car to the dealer and the fix was cleaning the TB's too.
Old Mar 20, 2010 | 04:34 AM
  #114
Defratos's Avatar
You're Despicable
Well here's my contribution to the GCC spec cars:
I don't have idle fluctuating problems, only on start up it'll rav slightly high but after like 15 secs it'll drop to like 700-800 and it'll hold the idle well.
The problem I am having is that the car hesitates when I'm at a light and I WOT it'll hesitate and then jump.....I'm going to be doing my TB cleaning and see if that helps.
One more thing that hasn't been really mentioned in this thread, has anyone cleaned their MAF? I had to clean my previous Audi MAF a lot to get it to idle stable. Just something to think about especially for those with aftermarket filters.
Old Mar 20, 2010 | 05:53 AM
  #115
The hesitation sounds like your O2 sensors are damaged. Did the hesitation start after installing the HFC's?
Old Mar 20, 2010 | 06:49 AM
  #116
Defratos's Avatar
You're Despicable
no it only started like 2 weeks ago, I've just cleaned my TBs so I'll see if that was the cause
Old Mar 20, 2010 | 09:10 AM
  #117
baileyt35's Avatar
They did TSB 08-017A and the idling issue started immediately afterwards. I'm at 49k
Old Mar 20, 2010 | 03:16 PM
  #118
CalsonicVQ's Avatar
Clean your TBs. You might be surprised. My idle problems started after getting an ECU update, too, but all the problems went away after the TB cleaning. Who knew?
Old Mar 24, 2010 | 11:40 AM
  #119
enjoyincubusg35's Avatar
so I take my car to the stealership this morning to get the TB cleaned. i didn't know this wasn't covered by the warranty. is this true? btw, they're charging me like $120 to get it cleaned.
Old Mar 24, 2010 | 11:44 AM
  #120
DIY man, it's easy and doesn't take much time.
