Nissan Power Pup Bullydog - First Impressions
Old May 29, 2009 | 03:29 PM
  #331
AesonVirus's Avatar
I'll check mine out once I finally get my working update.
I know that my dealer offers an advance (+2*) but I'm not sure what the benefit of -2* is.
Old May 29, 2009 | 03:40 PM
  #332
soundmike's Avatar
Run on lower octane?
Old May 29, 2009 | 04:23 PM
  #333
REKKO's Avatar
How about some 1/4 mile runs from some of the people who have this installed? Even if you don't pull a good e.t. we can still figure out if this thing is really making power or not by comparing other times on here and seeing what MPH you get at the top end. Just a suggestion.
Old May 29, 2009 | 06:17 PM
  #334
PursuitofG's Avatar
Originally Posted by johnblaz2000
I installed the 1.2.2d Version and everything worked. Haven't had the chance to play due to the weather. I have to find a shop with a dyno. I can definitely feel a difference. The settings for the timing was retarded -2* and the speed limiter is set @ 163. the rev limit was at 7650 and now it is set @ 7750. The idle is set for 725 rpms. Oh! the tuning is set for premium. I don't know the whole theory for the -2* timing yet. Still researching.
If I remember correctly the setting for timing was at 0 after setting the tuning as premium. I manually adjusted the timing to +2
why yours was at -2
Old May 29, 2009 | 07:19 PM
  #335
johnblaz2000's Avatar
why yours was at -2
I don't know why it is set for -2*. I am not going to change anything until I speak to the Engineer who thinks this setting is proper for this tune. I have been reading up on the theory of proper tuning and the adverse effects. I have not witnessed any predetination or pinging sounds while I am at idle or while I am driving at higher speeds. Even when I rev the engine, I don't hear or feel any unusual sounds coming from the motor. This tune is definitely an improvement as for acceleration and response. I have logged 52K miles prior to making these changes to my car and I think I know what it feels like after doing these mods. I also found a dyno shop in oldbridge, N.J. I will be setting up an future appointment to get the gains from these mods.
Old May 29, 2009 | 07:43 PM
  #336
I forgot to add this good write up that I found. Enjoy and most definitely comment. Just read the whole article. It is long. I know. Lol.
http://www.superstreetonline.com/tec...tem/index.html
and one more,
http://www.fuelsaving.info/knock.htm
Old May 30, 2009 | 09:02 AM
  #337
Ant0n's Avatar
hey guys, could any1 who s got the power pup help me?
i have received my p.p. a few days ago and decided to install it today and now i have a prob installin it. (cz of the time difference its hard to fit in the time-frame when the tech support of the bullydog is online)
it might seem noob)) but when i install the update agent and it says plug your p.p in , I do that but then there is no action. I think normally, right after the installaion of the AGENT and when you plug the p.p inside , the software has to start upgrading automatically? but nothing happens ... i have tried a few computers just in case, but have the same effect. So maybe i miss some step? thanks a lot
Old May 30, 2009 | 12:12 PM
  #338
bat6wc's Avatar
i am currently installing this as we speak using 1.2.2c. It got me all the way to the 4th to last step where after going through all the settings, processing calibration and building file, Im now on "downloading." Its been saying Downloading....0% for 30min now. Does this mean, 1.2.2c isnt going to work, or does it normally take this long?
Let me know
UPDATE: I pulled the plug and downloaded version 1.2.2d. Tried installing it again and...SUCCESS!!!! Im going out for a joy ride in a little bit. As of right now all the settings are for PREMIUM and STOCK (stock timing, idle, rev limiter, speed limiter).
Old May 30, 2009 | 01:46 PM
  #339
kid4now's Avatar
I`ll be waiting for butt dyno and smile factor #`s.
Old May 30, 2009 | 02:15 PM
  #340
DrGeeMD's Avatar
me too!
Old May 30, 2009 | 02:54 PM
  #341
AesonVirus's Avatar
Me three
Old May 30, 2009 | 03:21 PM
  #342
Me Four.
Old May 31, 2009 | 09:46 AM
  #343
Defratos's Avatar
You're Despicable
Me five, C'mon I'm willing to transfer $10 (via paypall) to whoever decides to do a real Dyno first .
Of course a before and after graph and readout would be expected
Old May 31, 2009 | 09:48 AM
  #344
Q8y_drifter's Avatar
you can use paypal in KSA??
lol i never knew. stupid thing doesn't work here!
Old May 31, 2009 | 10:40 AM
  #345
Defratos's Avatar
You're Despicable
well yeah, I mean I can access the site and use paypal to pay for things or transfer money. BUT it is registered under my UK account and address, that's why it allows me. I think you can do the same but you'll need an account and address that is either in Europe or the states. (I'm not too sure which counties) but the UK works.
Half the time though when I pay for something through paypal they deliver the goods to my UK address as apposed to my delivery address (which is in KSA) but some companies don't mind sending it to a different address to the billing address.
Does that make sense?
