Nissan Power Pup Bullydog - First Impressions
Old Oct 2, 2009 | 11:32 AM
  #871
Austin713's Avatar
Originally Posted by mishmosh
Hey Austin. Where do you mount your Passport? I have a 9500ix and it went off as soon as I turned the car on. I used Mike's Mount which attaches underneath the rearview mirror. I found out that the Nav screen is what sets off the laser on mine. I mounted it more forward on the windshield using suction cups and it is fine in that position.
Really??? that is strange. i am just mounting it in the center of the windshield directly above the Nav screen.
Old Oct 3, 2009 | 10:05 AM
  #872
3volved's Avatar
I'm off to Sublime for dyno time in an hour...wish me luck.
Old Oct 3, 2009 | 10:08 AM
  #873
Scooby24's Avatar
Good luck, don't leave us hanging!
Old Oct 3, 2009 | 11:11 AM
  #874
MojoKidd's Avatar
Originally Posted by Ball.Saxbury
Well, guys, the numbers are in. I have video of the whole dyno event and all the printouts, which I will post shortly.
But here is the short version: after the Bully Dog tune, the car runs leaner and makes less horsepower.
Damn it.
We did two runs before and after and got A/F readings from exhaust probes. Stock: At 5,000 RPM, for example, the car makes 161.1 horsepower (remember that I'm at over 5,000 feet altitude) and runs at 11.7 A/F ratio, and after being tuned, it makes 156.7 horsepower at the same RPM and runs at 12.2 A/F.
I should also note that we ran the car about 10-12 miles at varying speeds on the dyno to let it acclimate to the tune.
I am going to upload the paperwork with all of this soon. There is also a chart that plots stock vs. tuned, and you can see that after the tune there is less power, torque, and the car runs leaner.
So my conclusion is ... anybody want to buy a slightly used Bully Dog Nissan Power Pup?
Did I miss something here? Where is the video and the dyno graphs?
Old Oct 3, 2009 | 12:27 PM
  #875
G35Now!'s Avatar
Moderation-free
Good deal - if this doesn't work out, may buzz down to Houston Performance and have them do some runs next week. The agreed approach was:
  • Install BD premium tune and timing advance, and drive for a couple of days to make sure the ECU is adjusted
  • Do at least a couple of runs with BD
  • Remove BD (back to stock tune), but keep timing advance (why not?)
  • Do at least two more runs
Right?
EDIT:>> BTW, my prediction is positive result, but <5 HP gain and only towards the upper end of rpm range.
Old Oct 3, 2009 | 12:35 PM
  #876
Greekboy115's Avatar
Good luck man we will all be anxiously waiting for the results when you return.
Old Oct 3, 2009 | 01:29 PM
  #877
3volved's Avatar
Here's the info:
Dyno'd on a Mustang Dynamometer (www.mustangdyne.com)
Engine mods I have installed are z-tube and Stillen intake box with cone filter.
Baseline run - stock tune:
221tq/269hp
AFR ranged from 11.8 to 14.2 - pretty lean
Just the premium tune:
226tq/276hp
AFR dramatically stabilized ranging from 12.8 to 13.5
Premium tune with 2 degree timing:
we saw a decrease in performance with engine knock - 269.2hp
FINAL
Premium tune with 1 degree timing:
227tq/281hp, AFR's ranged from 12.8 to 13.5
All together we ran about 8 pulls, took an hour and a half and paid $125. If anyone's curious, the shop I went to is Sublime Speed Technology (http://www.sstracing.com/). All-in-all, I'm pretty happy seeing the AFR's level out and the Bullydog itself couldn't have been easier to use. I'll post back again after a few days to see if there's any more of a noticeable performance increase from the driver's seat.
Also, Brandon402 stopped by while we were finishing up and can backup these numbers for all the haters.
Graphs to come shortly...NOW:
+1 Degree timing advance (HP & AFR)
+1 Degree timing (HP & TQ)
Baseline (HP & AFR)
Baseline (HP & TQ)
Old Oct 3, 2009 | 01:50 PM
  #878
G35Now!'s Avatar
Moderation-free
3volved, did you dyno an a 2nd gen (VQ-HR), or your '05 coupe (VQ)? I'm confused by your sig, but can't see how you made 269 HP in a coupe so am thinking your sig just isn't updated...?
If it was an HR, great! If it was a 1st gen coupe, unfortunately us 2nd gen owners still don't have proof
Thanks for going either way
Old Oct 3, 2009 | 01:53 PM
  #879
Q8y_drifter's Avatar
those are great gains! how did you do it? I mean, back to back? did you reset the ECU before the baseline run?
Old Oct 3, 2009 | 02:03 PM
  #880
3volved's Avatar
My 05 6MT is a HiRev.
Basically the baseline was a learned stock ECU tune with supporting mods (ztube and stillen intake). We ran 2 of those. Then I uploaded the premium bullydog tune. 2 runs with that. I advanced timing by 2 degrees. 2 runs there. Then, after we saw the knock with 2 degrees timing, we changed the timing back down to 1 degree advance. 2 runs there. The last time the ECU was reset was about a week ago when I installed the stillen intake.
Old Oct 3, 2009 | 02:21 PM
  #881
What fuel octane were you running with the +2 timing?
Old Oct 3, 2009 | 02:22 PM
  #882
3volved's Avatar
Sorry, running 91 octane through the process. Should have included that.
Old Oct 3, 2009 | 02:25 PM
  #883
G35Now!'s Avatar
Moderation-free
Okay - great results, good news for you. And further proof that the BD does work on other vehicles.
But unfortunately we can't call this proof that it works on a VQ-HR, and thus 2nd gen sedans
Just reinstalled the premium tune on my G, will try and get to the dyno this week.
Old Oct 3, 2009 | 02:30 PM
  #884
please do so. the DE's are usually even worse when it comes to tuning/modification so these graphs are very promising. I'm using 93 octane here, so knock shouldn't be an issue.
Old Oct 3, 2009 | 02:34 PM
  #885
G35Now!'s Avatar
Moderation-free
Dude, you're in Kuwait - you can probably get them to home brew any octane you want, never mind 93
