Tires for OEM 19s : The end-all thread
Old Jul 28, 2009 | 05:22 PM
  #316
LightsOut's Avatar
SIETESG
I could answer your questions, but I dont have the time right now....lol
about to clock out
but do a quick search on the thread I posted..
Old Jul 29, 2009 | 12:16 AM
  #317
Polishthrust's Avatar
about to clock out
Did a search and no one seems to be running this set up. Can someone chime in on this?
Old Jul 29, 2009 | 12:05 PM
  #318
LightsOut's Avatar
SIETESG
Originally Posted by Polishthrust
I wanna know this too. It seems like 245/40 and 255/40 are much closer in height than 245/35 and 255/40( 3.38/4.02 vs 3.86/4.02). 245/35 throws off the speedometer to read 65 at 68.23 where 245/40 reads 65 at 65.77 which seems more reasonable.
Also, i want to run spacers (im thinking 20/25mm all around) without lowering. Should i expect any rubbing issues with 245/40 & 255/40?
Thanks for educating a tire noob!
rubbing issues with 245-255--- you will not rub, BUT if you put spacers you will rub. only in the rear
Im have 20/25 spacers with 245/255 tires and no rubbing, but I have my fenders rolled. could even put a 25 up front if you wanted.
the way I would answer your first question will be that our G's get power to the rear wheels not the front so the front wheels have to be within the same size range of the factory tire to not throw off the VDC. So the speedo shouldnt really matter. So saying that 255/40 is close enough to 245/40 in the speedo and tire size and not throwing off the the VDC also.
Old Jul 29, 2009 | 12:17 PM
  #319
Grevving6's Avatar
Originally Posted by Beebo
i have stock 19's with 245/40/19 TOYO T1R's front and rear and im fine
Can you rotate them?
Old Jul 29, 2009 | 12:19 PM
  #320
redlude97's Avatar
245/35/19 is a closer match to the OEM 225/40/19 size than a 245/40/19. The oem tire setup has a height stagger from front to rear and the car's suspension and VDC is setup for this height stagger. Going with 245/40/19 in the front will raise the front of the car up and could potentially cause VDC issues. 245/35/19 is a much better choice in the front
Old Jul 29, 2009 | 12:23 PM
  #321
LightsOut's Avatar
SIETESG
forgot to mention that...
your so smart...lol
  #322
Thanks for the response.
Is there something wrong with running 245/40 in front? People on this thread seem to think that 245/35 is ideal.
Old Jul 29, 2009 | 12:25 PM
  #323
LightsOut's Avatar
SIETESG
question was answered perfectly by redlude
Old Jul 29, 2009 | 01:52 PM
  #324
Makes perfect sense...
Thanks again guys!
Old Jul 29, 2009 | 04:27 PM
  #325
LR-G's Avatar
what would be some problems running 275/35/19 on stock oem rims.?
Old Jul 29, 2009 | 04:30 PM
  #326
LightsOut's Avatar
SIETESG
oems are not wide enough.
Old Jul 29, 2009 | 04:33 PM
  #327
LR-G's Avatar
thanks ^
Old Jul 29, 2009 | 04:35 PM
  #328
LightsOut's Avatar
SIETESG
other option I was thinking of doing is
g37 oem wheels with 255/35 and 275/35 along with 30mm spacers all around. (fenders rolled)
Old Jul 29, 2009 | 08:39 PM
  #329
LR-G's Avatar
would 245/40/19 all round fit?
Old Jul 29, 2009 | 08:46 PM
  #330
LightsOut's Avatar
SIETESG
some have posted that they are running that tire size all around without any issues.
rotating tires doesnt save the life of your tires much..
