Tires for OEM 19s : The end-all thread
Old Jul 17, 2010 | 09:21 PM
  #481
herrschaft's Avatar
Originally Posted by SacG35
does anyone have PICS of 245/35/19 on Rear 19s OEM Rays?
https://g35driver.com/forums/5233025-post7588.html The badge-less IP G has that setup.
Old Jul 19, 2010 | 04:02 AM
  #482
code2424's Avatar
Originally Posted by G35fromPA
What about:
235/40-19 F
255/40-19 F
Tire calculator shows each is 1.2% bigger than OEM sizes, so the total diameter difference front to rear (from OEM sizes) is zero. Should be fine with VDC, right? Will taller sidewalls lead to softer handling?
Those size shouldn't be a problem.
Old Jul 20, 2010 | 04:34 PM
  #483
RPWIII G35's Avatar
So I need new tires and it seems the ideal size would be 245/35 for the fronts and 255/40 for the rears for the oem 19s. Someone recommended I get nitto invos but I need more of an all season tire, rather than a summer tire. What are good performance all season tires that are best bang for the buck?
Old Jul 20, 2010 | 08:44 PM
  #484
Black Acc's Avatar
I need to replace my stock rear tires.
I found a real good set of used tires. Yokohama S-Drive.
The seller has 2 sets but I don't know if they will work for my rears.
2 tires=275/40/19
2 tires= 245/45/19
Which one of these sets would be a better bet for my rear rims?
Also does anyone of pics of their tires with those sizes?
Thanks!!
Old Jul 21, 2010 | 09:28 AM
  #485
LightsOut's Avatar
SIETESG
hint:
tire calculator and oem rear wheel is 8.5
Old Jul 21, 2010 | 11:22 PM
  #486
drikx's Avatar
woudl it be okay to put 255/40s on both front and rears with a eibach drop?
Old Jul 25, 2010 | 04:46 PM
  #487
LaserRedG35VS's Avatar
I have 255/40 on rear with eibach pro drop (its np)-- planning on doing 245front 275 rear with spacers- Im gonna have to roll fenders but anyone know if 275 will def. be fine??
Old Jul 25, 2010 | 04:58 PM
  #488
kennymo's Avatar
hey op look at the first page of this thread. there are a couple people using those sized. so i think it should be fine. only problems i see you running into is rubbing the tire
Old Jul 25, 2010 | 05:05 PM
  #489
Cool, thx a lot man. Well dont worry about the rubbing im def. gonna roll my fenders, trying to find someone in the area who can do it
Old Aug 5, 2010 | 10:20 PM
  #490
G35fromPA's Avatar
Just mounted the Hankook Ventus Evo V12's in OEM sizes on a set of 19" Rays and though I only tried a brief, 10 minute ride, initial impression is very positive with these. I switched from original Pilot Sports on my oem 18's (front and rear Michelins are actually pretty new) and I have to say these Hankooks in 19" ride as comfortably, if not more comfortably, than my 18" tires did. I suppose that's because of the lighter wheel and softer sidewalls of the Hankooks, but I am very pleased, and it doesn't seem to affect the turn-in or handling (at least yet). They seem to handle as crisply as my Pilot sports did. I have them set at 38 psi up front and 37 in the rear right now. Need to burn off the mold release over the next couple of weeks. Will report back more in a few hundred miles. So far I'm glad I chose these.
Old Aug 5, 2010 | 10:34 PM
  #491
herrschaft's Avatar
^Just mounted mine yesterday. I previously had Kumho ecsta's on(not sure which version), The V12's grip way better. Not a big fan of the softer side wall, but since my suspension is already stiff, this might help keep my tires planted on rough surfaces. I will test these out this weekend.
Old Aug 6, 2010 | 07:53 AM
  #492
idrive_MD's Avatar
What are your pressures? Most of us with the V12's run higher than normal pressures to alleviate the sidewall issues.
Old Aug 6, 2010 | 08:40 AM
  #493
vietboi817's Avatar
I've been running FK452, 245/35 Front and 275/35 Rear for about 5k miles now. No complaint so far. A tad bit rough but nothing intrusive.
Old Aug 6, 2010 | 09:18 AM
  #494
herrschaft's Avatar
Originally Posted by idrive_md
what are your pressures? Most of us with the v12's run higher than normal pressures to alleviate the sidewall issues.
38-40psi
I will try 43-45PSI and see how that works.
Old Aug 6, 2010 | 06:45 PM
  #495
idrive_MD's Avatar
38-40psi
go with 42 front and 40 rear
