Hello all from Tire Rack
Mar 15, 2012 | 02:29 PM
  #706
Quote: Are they Oem sensors, any online link anywhere you can provide to the site with the sensors so I can have a look Thanks Neil
Same ones as oe. Unfortunately I do not have pix of them.
Quote: I have an 06 Coupe w/ "Sport-tuned suspension" and TR pretty much doesn't have anything listed for brakes. I've always bought Akebono ProAct pads for previous cars, I would assume they make them for the G. If not, do you guys sell Hawk pads? Currently NO pads are listed on the TR site.
Also would like to see Centric rotors listed, only Brembo blanks are available.
I went through this with our FX35 and someone was able to update the database since the parts were in stock, just listed under other vehicles.
I just went through the hassle of trying to find two Conti DWS in that size. Apparently the all-seasons are discontinued.
Let me check with my guys here.
Reply 0
Mar 16, 2012 | 11:38 AM
  #707
Quote: I have an 06 Coupe w/ "Sport-tuned suspension" and TR pretty much doesn't have anything listed for brakes. Do you guys sell Hawk pads? Currently NO pads are listed on the TR site.
We found an application for the car in our system. It will be updated online shortly. Thanks!
Reply 0
Mar 19, 2012 | 02:30 PM
  #708
Quote: We found an application for the car in our system. It will be updated online shortly. Thanks!
Stupid question, for the 06 Coupe, aren't the brakes all the same? On a whim, I search for "Base Model" and see on the site all the "New" listings. Still nothing listed if I pick "w/ Sport Tuned Suspension" that's saved to my garage.
Reply 0
Mar 21, 2012 | 01:36 PM
  #709
Should be showing online now.
Reply 0
Apr 10, 2012 | 05:51 PM
  #710
The guy who sold me my 2004 g35 coupe put on American Racing - AR337 Burn wheels, they look alright for now but the only problem is he put 20"s in the back and 18" in the front and told me that 20" apparently wouldn't fit in the front. This is obviously not true considering many G35 owners have 20" wheels. I am looking to balance out the setup and am curious what size/fitment wheels should I get. I found them on this site here http://www.wheelplususa.com/wheels/A...ack+Chrome+Lip
I really do not know what to get so if you could give me the exact specs of what to get for a set of those rims to fit on the FRONT it would be greatly appreciated!
Reply 0
Apr 11, 2012 | 03:07 PM
  #711
Only front fitment 20" tire I show is a 245/30-20. That will fit wheels 8-9" wide.
Reply 0
Apr 11, 2012 | 03:34 PM
  #712
Quote: Only front fitment 20" tire I show is a 245/30-20. That will fit wheels 8-9" wide.
Do you have any recommendations for a brand for a tire that size? And if I were to get the AR337 Burn wheels (2 of them for the front) I would get 20x8.5, and bolt pattern 5x114.3 and 30 offset correct?
Reply 0
Apr 12, 2012 | 12:10 PM
  #713
Neal,
i recently switched from yoko s.drive to v12 evo and have been pretty satisfied. next i was thinking of stepping up to either pilot super sport or advan neova ad08. i also notice the release of the new g-force sport comp-2, which look's pretty comparable to my last few setups. do you think i should just pull the trigger and jump up to max summers or are the sport comp-2s worth a try? if the comp-2s are better than the v12s & s.drives, i think i may try them out. thoughts?
Reply 0
Apr 13, 2012 | 05:24 PM
  #714
Quote: Do you have any recommendations for a brand for a tire that size? And if I were to get the AR337 Burn wheels (2 of them for the front) I would get 20x8.5, and bolt pattern 5x114.3 and 30 offset correct?
Assuming there's a 275 being used out back, I would check Hankook's Ventus V12 on the summer side or the Conti DWS as an all season tire.
The BFG just came out this month so there's not enough data right now for us to know how well it's going to work. I do know they run super wide compared to others in the same size, so that's something to consider when it comes to fitment.
The Michelin SS is probably the best tire out right now. Anything from G's to Porsches are using them. Treadlife warranty, excellent dry, great wet, good ride, etc makes it a great option.
Reply 0
Apr 18, 2012 | 11:52 AM
  #715
2 quick questions. I currently have 255/35/20 all the way around on my awd X. Would switching to 245 improve handling/steering? Also is it possible to run 245/35 front and 255/35 on the rear? The two fronts are worn and the two rears are almost new. Rims are 8.5 wide btw.
Reply 0
Apr 18, 2012 | 08:13 PM
  #716
i have an 03 sedan
i wanted to go with 19" TSW rims heres the specs:
front - 19x8.0 +40mm
rear - 19x9.5 +40mm
questions:
1) is the offset to high? if so what would be better?
2) what tire size is recommended for this set up?
cheers
Ash
Reply 0
Apr 18, 2012 | 09:19 PM
  #717
Question...
https://g35driver.com/forums/wheels-...-03-tires.html
Reply 0
Apr 19, 2012 | 02:25 PM
  #718
Quote: 2 quick questions. I currently have 255/35/20 all the way around on my awd X. Would switching to 245 improve handling/steering? Also is it possible to run 245/35 front and 255/35 on the rear? The two fronts are worn and the two rears are almost new. Rims are 8.5 wide btw.
The difference in handling/response between those two will be minimal. Only talking 1/4" on either side your losing by using a 245. Wet traction and snow (if an all season tire) will slightly increase with a narrower footprint though. Due to the difference in outer diameter, I would not mix/match the sizes on an X.
rear - 19x9.5 +40mm
questions:
cheers
Ash
Honestly do not carry that line of wheel so it's hard for me to say. However, the offset on those rears does seem a bit low compared to other 8.0/9.5 combos we do carry. Checking with a TSW retailer will answer that for sure.
Replied!
Reply 0
Apr 19, 2012 | 04:55 PM
  #719
So Neal can you get a better price on tires than what I see on line from the Tire Rack? In a couple months I'm going to need 2 new Michelin PS2s 245/35X19 for my front end and I want them dated this year. Is that possible for less than the Racks $400 each + shipping price from you?
Gary
Reply 0
Apr 20, 2012 | 02:45 PM
  #720
Best I can do is same price listed online. Owners set lowest price possible so everyone gets the same great deal. Call me direct or mention my name on your order and I'll expedite it for you.
Reply 0
