Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Apr 8, 2011 | 01:43 PM
  #1711
4DGS's Avatar
Always roll your fenders if you plan to buy coils. Just a rule of thumb.
Did you already order the wheels? Because if not and you want to go stretched, order the 0 offsets.
Even if you order the 0 and then run 245 and 265, you'll be fine.
Old Apr 8, 2011 | 03:37 PM
  #1712
KCJ's Avatar
KCJ
i'm running a 20x10 +11 up front and a 20x11 +7 in the rear. i have the rear fenders cut..how do you think adding a 15mm hubcentric spacer to both the front and rears would look?
Old Apr 8, 2011 | 08:52 PM
  #1713
4DGS's Avatar
What size tires? You're gonna need a stretch.
How low are you? You're gonna need some camber.
And you're going to need to figure out that cut fender, it's only going to make your rubbing bad.
Old Apr 9, 2011 | 12:48 AM
  #1714
smiLee.'s Avatar
will a 245/40/19 fit on front 19 oem's? I found some cheap tires on craigslist and was wondering if they could fit since my Stock potenza's are about to go out.
Thanks!
Old Apr 9, 2011 | 02:11 AM
  #1715
KCJ's Avatar
KCJ
running stretched 235/35/20 and 255/35/20 atm
camber kit install is happening some time this week, ill obviously need negative camber, as far as low, https://g35driver.com/forums/picture...oss-black.html
Old Apr 10, 2011 | 06:21 PM
  #1716
adrenaline rush's Avatar
Thanks!
Width wise, they're fine. However, diameter wise, that size is what you would put on the rear wheel.
What do run for rear tires?
Old Apr 10, 2011 | 07:11 PM
  #1717
Raiderpolo15's Avatar
HELP EMERGENCY will stock oem 6 spoke rims from an 03 sedan fit an 04 coupe with brembo brakes???? thank you very much for the help
Old Apr 11, 2011 | 01:19 AM
  #1718
4DGS's Avatar
Thanks!
Yea you're fine, go for it. The front is a little oversized but it's all good.
Just go natural camber (-3) run some 10mm spacers and roll the fenders totally flat. Which might be an issue since you cut them.
No.
Old Apr 11, 2011 | 05:49 AM
  #1719
thanks
thanks man...
here is my new dilemma i have 4 18X7.5 for my 04 coupe tire specs 245 40 18.. the backs fit good but i have a brembos in the front and there is a little rubbing in the front thinking of getting 3mm or 5 mm spacers... i'm guessing 3mm will be enough. Also is it ok to run non staggered wheels on a coupe? should i also get matching spacers for the rears or leave them? or get larger spacers?
Old Apr 11, 2011 | 05:14 PM
  #1720
P10 WRC's Avatar
anyone know if all g35's had tpms? I put my aftermarket wheels on and did not swap any sensors but i DO NOT have a dash light on that says tmps or any indication of an issue. Does this mean my car does not have tpms?
Old Apr 11, 2011 | 06:08 PM
  #1721
4DGS's Avatar
thanks man...
IMO, buy new wheels. Those wheels are thinner than stock wheels and the offsets are probably higher.
You can run non staggered it doesn't matter. You can run up to a 5mm spacer without swapping out the OEM studs for extended studs. Any larger you need extended studs.
No not all the Gs had them I can't remember exactly which had them or which did not but I am pretty sure base model Gs never had them up to 05. AKA, if you only have sport package and no premium packages.
Old Apr 11, 2011 | 06:10 PM
  #1722
P10 WRC's Avatar
i have an 06 sport with premium package and 6mt. i guess i should just read the manual
Old Apr 12, 2011 | 12:41 AM
  #1723
VincenzG35's Avatar
I kno nobody is going to like the set up in question but can some one help me figure out what size wheels to buy
I like the XXR006 (weak offset ect I know) I bought new tires recently in the stock 215-55-17 and I want to know what 17" xxr 006 will fit
Old Apr 12, 2011 | 12:56 AM
  #1724
JBF's Avatar
JBF
coupe or sedan?
Old Apr 12, 2011 | 01:08 AM
  #1725
VincenzG35's Avatar
Sedan
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
