Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old May 2, 2011 | 11:28 PM
  #1861
Nightcrawler's Avatar
Here is one running 11 +15 at the rear - but it is running HEAPS of rear camber to keep it flush with the guard. He would chew through the inside of his rears tyres very, very quickly.
Old May 2, 2011 | 11:57 PM
  #1862
qbanboy's Avatar
by the way can you give me a quick explanation what is a camber and what it does for you? I seen that a lot around here.
Old May 3, 2011 | 12:36 AM
  #1863
4D05G35's Avatar
Its hard to tell by the pic, but that rear camber looks less than 3 degree.
Old May 3, 2011 | 12:41 AM
  #1864
^^^ bollocks .... look at the difference in wheel angle from vertical from the front to the rears. Given the front should have around one degree of camber already, the difference is huge.
qbanboy:
http://autorepair.about.com/od/gloss...def_camber.htm
Old May 3, 2011 | 12:43 AM
  #1865
4D05G35's Avatar
Camber is when the tire angles in (neg camber) or out (pos camber). A little negative camber is desired and designed per factory specs. Usually it's at or below 1 degree.
Excessive Negative camber happens when you lower your vehicle, the tops of the wheels tilt inword.
Example being...| | are the wheels left and right side.
| | = 0 camber. / \ represents negative camber.
Old May 3, 2011 | 12:45 AM
  #1866
qbanboy's Avatar
Thanks man again, so 20x9 +20 and 20x10.5 +30 lowering the car you think i can have a camber kit that actually make my car to "0" degree i dont want to chew my tires in 3 months...
Old May 3, 2011 | 12:47 AM
  #1867
qbanboy's Avatar
Got it so i would actually need like 1-2 negative camber after i lower my car and everything right?
Old May 3, 2011 | 12:54 AM
  #1868
4D05G35's Avatar
qbanboy:
Calm down bro, I know what wheel camber is no need to post the link..
Like I said, "but that rear camber looks less than 3 degree" .
Here is my rear wheel at 3.0 degree of camber (just finished dialing in my new wheels and had an alignment done on thursday of past week to set specs)
Attached Thumbnails Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::-photo.jpg
Old May 3, 2011 | 01:00 AM
  #1869
4D05G35's Avatar
I think OEM up front is up to .8 degree and similar for the rear ( I have a rear camber arm + toe bolt so they set it where I ask).
2 degree front and rear is nothing to sweat, make sure the toe is in spec and you will be ok. I just got my alignment done and told them to keep my camber (2.5F 3.0R) but to get my toe well witin spec....which they did. Liketime alignment rocks
Old May 3, 2011 | 01:01 AM
  #1870
qbanboy's Avatar
yeah but you dont have a 20x11 +15 wheels on that G bro so is different...it can be the same degree....
Old May 3, 2011 | 01:04 AM
  #1871
qbanboy's Avatar
i mean Can Not be the same degree you probably have a 20x10 max 10.5 the wider the wheel and the smaller the offset the higher the degree....20x11 +15 is a big wheel size
Old May 3, 2011 | 03:22 AM
  #1872
JBF's Avatar
JBF
I have a 20x11 -4 in the rear of mine and I only have -2.5 camber.
your +15 offset will allow for stock camber which is anywhere between -1.2 and -1.7
Just so as long as you roll your fenders.
Old May 3, 2011 | 03:51 AM
  #1873
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
No way in hell he's running that much negative camber to make those fit, especially at a +15 on an 11" wheel.
I know this first hand... and my camber is in spec, as well as others that I've seen in person.
Edit: Just realized that car is posted on rimtuck. Too bad this car is no more. Some dude from the east coast wrecked it after he bought it from Chris Beardon's brother. You wanna see some camber, then here you go. Shane's Car, that's camber.
Old May 3, 2011 | 12:04 PM
  #1874
qbanboy's Avatar
ok I guess everyone have a different opinion and different knowledge about this...
My question is with this wheels fit mine car with out that MEXICAN LOOK on the picture above? I will like it flush to the outer part to the fender MAX. I don't want my tire sticking out like this one....i would like my tire to be inside the fender even with the fenders roll...and using a camber kit that would allow my tires to last more than 11 months...
Please reply with some knowledge or maybe some experience!!! If you have pics PLS post them too so we know what are you base on.... Thanks
HERE IS THE WHEEL.....XXR 526 20x9 +15 FRONT 20x11 +15 REAR
Old May 3, 2011 | 12:09 PM
  #1875
XiN's Avatar
XiN
Itasha Coupe
You'll be fine with this set up. No need to run negative camber in order to just clear. You can run your standard tire sizes of 245/30/20 in the front or 275/30/20 in the rear. Just roll your rear fenders flat.
How do I know this? Because those are my wheel specs, except mine is a 9.5 in the front (instead of a 9) and a 10.5 in the back (instead of 11).
And if that doesn't make you comfortable with me telling you that my wheel specs are similar, but not exact, here's a picture of my buddy Mike's 19x11 in the rear with a +15 offset. All he has is a drop, flat fender roll, and rear camber arms with toe bolts. No camber, no stretch, 275/35/19 in the back.
And here's another one for you, Mauricio's 20x11 in the rear, 275/30/20 in the back.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
