Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old May 9, 2011 | 09:53 PM
  #1966
4D05G35's Avatar
Originally Posted by qbanboy
OK TRODDER!!!!
With those offset and wheels with you won't need to roll your fenders because your wheels are going to be tuck in the fender....Now if you get some spacers then you will need to roll your fenders to get flush to the outer part of the fender...
In this cars you will will probably never need spacers to clear out the brakes, only if you got a really low offset....
Example:
i get a 20x9 with a 35 offset FRONT 20x10 REAR with a 40 offset i wont need to roll my fenders neither because the offset is so high that will tuck the wheels inside.....Now we always recommend to roll your fenders because is more safe and if you change your rim someday with a lower offset and to a higher width you already have them roll.....
Now something else, If you really like those wheels go with them but if you really want to go staggered i will recommend you to go 20x9 or 20x8.5 front and 20x10 or 20x10.5 rear it will look much better.....this cars look hot from the back with a wide tire.....
Do you have a sedan or coupe? Those offsets on a coupe will tuck in a bit, but on a sedan they will be a bit more flush. I ran 19x9.5 +40 in the rear with 255/35's and had to roll my fender slightly to keep the wheels from rubbing over bumps with rear passengers. He is looking to run a 275 rear so he has 10mm more to worry about. I also ran 19x10 +43 with a 275/35 and my rear tire was perfectly flush with my fender that was rolled flat. Look at post #1818 in this thread to get a visual of how my sedan sat with the 19x10's.
And I agree a wide tire does look sweet.
Old May 9, 2011 | 10:05 PM
  #1967
4D05G35's Avatar
Originally Posted by Christopher112
Thanks- I'm really not interested in rolling my fenders.. Am I better off just ordering all fronts? 19x8.5 +30 with 245.40.19 ? I love the idea of staggered wheels, but with the AWD I am a bit concerned (read a lot of mixed opinions), and I really don't want to have to worry about my fenders.
Rolling the fenders is a simple process and any competent shop can do it for about $75, something I wish I did instead of buying a roller and doing it myself.
You wont have any issues with running a staggered set-up on an X as long as the rolling diameter is close, which you have already figured out.
If you dont go the staggered route then yeah 245/40/19 on all four corners would work good. Do those wheels come in any other width?
Old May 9, 2011 | 10:11 PM
  #1968
Christopher112's Avatar
The two wheels I am considering are Miro 111 which I would need to get redrilled to 5x114.3 .. They come 19x9.5 ET33
The other set I like and am considering are Linea Corse LC818. They come 19x8.5 +30 / 19x10 +38. These don't need to be redrilled but come staggered unless I order all fronts. I'm not sure how soon I want to drop the car as I bought the car for the luxury and don't want to chip a tooth on a rough ride (I did that in my younger days). I just really want to enhance the factory look and upgrade my 17 inch stock rims..
Do you have a recommendations out of the two rim choices? I'm not sure if I am going to drop and I really don't want to roll the fender.
Thanks for the replies!
Old May 9, 2011 | 10:32 PM
  #1969
4D05G35's Avatar
Have you looked at the bottom ones (euro tek) they are similar in design and have sedan friendly offsets.
https://g35driver.com/forums/wheels-...todesigns.html
You can run a 225/40/19 front and 25/35/19 rear to keep the same overall diameter. If you go with OEM springs from a G35 coupe I belive that it will drop your x sedan 1" and still offer a stock ride (being stock springs). I know what you mean about chipping a tooth. My main concern was keeping a good ride quality when I lowered my car. I had oem 350z springs and oem g35 coupe springs for a while, the ride was slightly firmer, but still far from stiff lowering springs.
Old May 9, 2011 | 11:32 PM
  #1970
simin510's Avatar
Anyone know if I will have to roll my fenders if I get 25mm spacers in the rear?
on a G coupe, thats lowered about 1.5 inches
thanks
Old May 10, 2011 | 12:16 AM
  #1971
salamsg35's Avatar
Hello, I just ordered my wheels. And I have 2003 g35 coupe my question is----- is there any sensor that have to remov from my orignal wheels into the new wheel, and if so what is that sensor do??
Thank you guys.
Old May 10, 2011 | 01:12 AM
  #1972
4D05G35's Avatar
thanks
Maybe. What wheels do you have? Width and offset?
Old May 10, 2011 | 01:15 AM
  #1973
4D05G35's Avatar
Thank you guys.
TPMS if you have them. They monitor the tire pressue and illuminate a light on your dash if the pressure gets to low.
T ire P ressure M onitoring S ytem.
The are part of the valve stem and just unscrew from your OEM wheels.
Old May 10, 2011 | 02:07 AM
  #1974
salamsg35's Avatar
Thumbs up
thank you for the info, thats easy to remove, but i dont think they have them on my 03.
thank you..
Old May 10, 2011 | 02:23 AM
  #1975
4D05G35's Avatar
You're welcome. I dont think the 03's have them either, but just incase you did.
Old May 10, 2011 | 11:43 AM
  #1976
simin510's Avatar
Stock 19's
forgot to write that
Old May 10, 2011 | 11:56 AM
  #1977
qbanboy's Avatar
I have a coupe...yeah in the sedan is a little different
Old May 10, 2011 | 01:11 PM
  #1978
4DGS's Avatar
Stock 19's
You won't NEED too, but I would highly recommend it because your tire is going to be about 5mm or so from the fender lip.
If you're picking wheels in the 9/10 stagger of widths aim for your offsets to be in the mid to high teens or low 20s.
Old May 10, 2011 | 02:35 PM
  #1979
tpc303's Avatar
I have a sedan and just bought 19x9 (+41 front) and 19x10 (+37 rear) can someone help me figure out the best tire size to run? I need to keep fairly close rolling diameter as I am AWD.
Old May 10, 2011 | 02:43 PM
  #1980
Swiftyk6's Avatar
Alright heres another wheel spacer question... I got some 20 inch TSW Jarama for FREE!!! F-255-35-20 R-285-35-20 all wrapped in nitto n555 extremes. The question i have is the wheels are 5x112 and i know i need a wheel adapter for them they all come in 1 inch - 1.25 spacer. I want it flush but not too far poking out. I dont have my fenders rolled and i could get it done just want to know what set up i need to make this work so i dont buy the wrong stuff and do to the wheels being free!!!
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
