Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Apr 10, 2012 | 01:37 PM
  #3166
wussupb0o's Avatar
Originally Posted by DrewDrew
no idea to to do the math on that one - has to do with what disk the face has and the offsets. I'd guess somewhere 5-15mm. if you were able to get him to ship, you'd then have to try to get him to test fit on one of the other so cal guys' cars who have brembos.
like a said, ordering a custom set for ~$4100 is out of the picture?
Yeah 4100 is kinda out of the picture... 4100 + shipping to canada + duties/taxes/brokerage + tires would make the price way too much aha. But if i wanted i could ask my friend to order it to avoid extra taxes... we'll see if i can find a used set in a couple days.
Old Apr 10, 2012 | 06:48 PM
  #3167
DrewDrew's Avatar
Originally Posted by Pepper
Current camber is at -4 with a 19x10.5 ET -7. Going to run a 19x11 ET -4 w/245/35/19. #1: is that too much of a stretch to be a reliable tire? #2: Am I going to need a pull? 1/4"?
11 -4 is the same rear spec as jbf's old dpe set. he pulled almost a full inch, and ran a 245/35, you're fine with the tire. I asked shane who did john's pull, he said somewhere between 5/8 and a full inch. I already said this last night regarding the guy's question above me. might as well say it again, he ran -2.3* in the rear with the pull and a 245.
Old Apr 10, 2012 | 08:06 PM
  #3168
GAU-8's Avatar
Ok - tire selection. Please let me know if this could be better answered in another thread. Going with an 18X8.5 +30 wheel. 4DGS suggested 245/40/18 for all around fitment. I've done some looking and narrowed down the designs to:
Hankook Ventus V4
Nitto NeoGen
Toyo Proxes 4
Yokohama S.Drive
I have used Toyos in the past. Otherwise never used any of these brands. I live in a desert so summer grip should be great. Since I see little rain, I need these to also perform well when wet because roads here can hold water more since the ground doesn't absorb it so well. I prefer a quiet tire. I have Bridgestone Turanzas on right now. The concrete freeway sections are VERY NOISY!!! with this tire. So if any of these are quieter, I'd be ecstatic. Any help or insight on the best bang for the buck? 1010tires.com has all of these ranging from $179-$219.
Old Apr 10, 2012 | 08:22 PM
  #3169
susu510's Avatar
Talking
I'm running 19x10 +9 with a 225/40/19 and a 19x11 +13 245/40/19, lowered as much as possible on my BC Racing coilovers, have my fenders rolled, and very slightly pulled with what looks like a good amount of room left for more tire and some spacers for a slight poke, I didn't want to run such an extreme stretch but that's how the wheels came, I plan on throwing the 245/40/19 from the rears on the front and getting either 265 or 275 on the rear just because I rather have more tire since I drive my car a lot but with the current set up it seems alright so far, ride is smooth, will let you know soon as I get some spacers and/or bigger tires. Still trying to figure out between 10mm or 15mm spacers in the front and back before I get bigger tires. Hope I was able to help a little!
Suel
Old Apr 10, 2012 | 08:30 PM
  #3170
Pepper's Avatar
After some calculating everything, I only need 5/16" pull. So hopefully I can avoid doing a crazy pull.
Old Apr 10, 2012 | 08:38 PM
  #3171
Pitbull0001's Avatar
Would this fit 04 coupe with small brakes and how would it look? Found a good deal on rim and tire set, just not sure about the fitment.
19" x8.5" +35 Front
Tires 265/30ZR19 93Y
19" x10" +40 rear
Tires 235/35Z/R19
Old Apr 10, 2012 | 09:22 PM
  #3172
4DGS's Avatar
Originally Posted by muhtish
As a matter of fact, yes, there was some front passenger side damage.
Took drivers side 25mm spacer off and left the passenger side on, and there is only 5-7mm difference between the two now....what could it be?
Here is alignment spec that I got...have no idea what I am looking at here exactly.
~Pete~
The camber from left to right is off a little but that equates to literally a 1mm difference...
I'm going to blame this issue on the damage they may have been done. If the rails were realigned they may have been shifted over to one side a little to even out the twist. What year was the car repaired?
One other thing to check is that both fenders have equal gaps along the hood, you may have an OEM fender and an aftermarket fender that didn't fit the same way and was squished or pulled to fit better.
Originally Posted by shawndon
I need some clarification from the experienced. I'm getting new tires and the tires I chose actually run large. So the rears I'm getting are 245/35/20. Does running large mean the side walls are larger? Maybe a large 245/35 need to be a 235/35? Just want to be sure before I order.
The terms running large/true/small are more so when your stretch, are you stretching these tires?
It's relates to how the tire looks when mounted, take for example Nitto Invos, a large running tire and nankangs NS-II a small running tire.
A 275/35 invo will appear larger due to a bulkier sidewall, but it is no larger than the Nankang.
Originally Posted by usingthejohn
4DGS
I have a sedan.
about -3.5 or so.
You said 9.5 +43? with a 20mm spacer? please quote your questions. Spring is here and everybody is confused haha.
Originally Posted by FullOutPwr
How agressive am I looking?
20x8.5 +20 offset, 245/35/20
Rear:
20x10 +25 offset 275/30/20
I looked on the stretch/poke guide and im cutting it close. Its an 03 sedan no suspension mods.
You definitely can't run those tires in the rear and even the front is cutting it close. You will need suspension mods to make those fit.
If you want those wheels go with 225/35 and 245/35, buy coilovers and lower the car about 2.5" maybe 3" and get the camber to about -3ish.
Oh, you'll also need rolled rear fenders.
Originally Posted by Geena
Please give me thoughts on my these wheel set up. i have a 07 g coupe base mod.
Im thinking about getting 20x8.5 +38 in the front and 20x10 +35 in the rears.
I have BC BR coilovers coming this week.
if i get those wheels what would be my best set up for tires. i want a flush look.
i dont want to use spaces or do a fender roll. i also heard about stretching the tires. would that kill the tires quicker? im on a budget and there don't got the extra $$$ for it. Please help me out with any suggestions. Thought about getting 19s too.
Pick different wheels, those will not be anywhere close to flush without spacers. Stretching will not kill tires but it is only used when running aggressive offsets in order to clear the fenders.
Look for some wheels that are more around the specs of 20x9.5 +15 20x10.5 +12-+22
Then run 255/35 and 275/30
Originally Posted by Techre5
I am considering upgrading my wheels. The bone-head who sold me my car put 20"s on the back and 18"s on the front and I think it looks pretty whack. I recently purchased function & form type 2 coilovers and I am curious what you all think might be good choice for a new set of wheels? I do not want to spend over 2000$ for rims and tires and am considering doing 20" in the front and back. Can anyone tell me the pro's and cons of putting 20's on? or just more general information I appear to be lacking? Thanks!
That is a very ****ed up set up lol
Only downside to 20s is ride comfort, they ride harsher than 18s or 19s.
As for the wheels, that's tough as I have no idea what style you're into. For $2000 you can probably pick up some high quality used wheels in our market place. (with tires too) if you want some opinions on styles show me a few cars you like and I can point you in the right direction!
Originally Posted by TGMcCoy
20x10.5 +0 front rims for a coupe, +15mm spacer for clearing Brembos= 20x10.5 -15, correct? What kind of work am I going to need for this fitment up front?
Thanks!
Probably a lot more than you want to.... you're looking about -4 degrees of camber or more, a decent pull and a solid stretch.
Hankook Ventus V4
Nitto NeoGen
Toyo Proxes 4
Yokohama S.Drive
I love the Yokos and Marcus (candlestickpark) can vouch for them as well. But the Toyos and Neogens aren't far behind. Off the top of my head price point would be Toyo, yoko, nitto right?
I'd go with the S. Drives. They have great reviews and I've never heard them be noisy. (however I have asphalt higways in canada)
Make a thread if you'd like some more opinions. Everything gets lost in here.
19" x8.5" +35 Front
19" x10" +40 rear
Tires 235/35Z/R19
I wouldn't recommend this set up, it will not be flush at all and you'll end up using like 30mm spacers to correct it.
Look for lower offsets in those width say around +15 or so.
Old Apr 10, 2012 | 09:37 PM
  #3173
DrewDrew's Avatar
oh. I see. you're just wanting to pull enough to run with the current camber you're running (-4*)? a 5/16" pull sounds about right for that, possibly just a tad more.
Old Apr 10, 2012 | 09:43 PM
  #3174
4DGS's Avatar
You guys need to switch to the metric side. Talking in inch increments when the offsets are in MMs lol
Old Apr 10, 2012 | 09:58 PM
  #3175
DrewDrew's Avatar
lol, I know right? It started when I asked shane how much he pulled john's fenders and he stuck with saying it in inches, and I just shared it over here.
pepper - this is how much john pulled with the same rear specs. ~20mm +/- 4mm, if you care to see at all.
Old Apr 10, 2012 | 10:03 PM
  #3176
Pepper's Avatar
Something like that lol. We'll test fit as we pull.
Old Apr 11, 2012 | 03:39 PM
  #3177
Techre5's Avatar
Checking In
Is this correct? I dont want to purchase the wrong thing. Will 20x8.5 AR337 Burn wheels (I would be getting 2 for the front), and bolt pattern 5x114.3 and 30 offset fit on my 2004 G35 Coupe? I was told to get 245/30-20 for tires, is that also correct?
The bone head who sold me my car put 18"s on the front and 20"s in the back because someone told him that 20" American Racing wheels do not fit on the front of G35 coupes. I am trying to make it balanced.
Old Apr 11, 2012 | 04:02 PM
  #3178
usingthejohn's Avatar
[QUOTE=4DGS;6406572]....
about -3.5 or so.
[\QUOTE]
4DGS,
Sorry, I'll repost my question:
2005 G35 Sedan
20x8.5 +40 up front, 20x9.5 +43 out back. Tire sizes are 245/35/20, 255/35/20. I have two sets of spacers: 20mm and 25mm NOT installed. I haven't installed them because I'm lazy to install my camber kit. But I Finally got around to installing rear camber arms, toe bolts and A-arms out front. If I plan on running the spacers, which set should I install where, and at what camber settings? Or would I be better off simply running 20mm spacers all around, thereby giving my wheels a new offset of +20 and +23?
Old Apr 11, 2012 | 09:07 PM
  #3179
TGMcCoy's Avatar
G35 Coupe w/ Brembos dropped on coils:
20X10.5 +10
20x11.5 +10
Fit well? Any problem with those widths? More importantly in the front? Will have nataural camber/fender roll in rear/stretched tires. Anything else needed?
Thanks, great thread!
Old Apr 11, 2012 | 10:54 PM
  #3180
GAU-8's Avatar
Thanks. I'll make a thread for opinions. Least expensive to most expensive, Hankook, Nitto, Toyo, Yoko. The Yoko's are $219 a pop! Ugh.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
