Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Apr 29, 2012 | 04:43 AM
  #3316
Drew113's Avatar
Ban Hammer Expert
+1 on everything Drew Drew said....and with the whole chains thing umm i don't know how well thats really gonna work especially if you ever lower and also with how much extra room you have after you decide on your tire thickness and your offsets...
Old Apr 29, 2012 | 05:30 AM
  #3317
05 sedan's Avatar
I have some volk sf challenge Front 19x8.5 +34 offset and Rear 19x9.5 +36 the tires i have on now are Front 245/35/19 rear 255/40/19 but i don't like the way they look I am lowered on eibach prokit but will be in coilovers in 2 weeks. I like the stretch tire look but not sure what sizes would be good with out going extreme. Any help would be good thanks
Old Apr 29, 2012 | 06:02 AM
  #3318
G35DuMp's Avatar
question.. will a 20x10.5 with a -5 offset and a 235/30 tire fit on the front of a sedan
Old Apr 29, 2012 | 06:55 AM
  #3319
Drew113's Avatar
Ban Hammer Expert
on a coupe or sedan?
Old Apr 29, 2012 | 07:20 AM
  #3320
05 sedan's Avatar
Sedan
Old Apr 29, 2012 | 08:03 AM
  #3321
Drew113's Avatar
Ban Hammer Expert
my bad should have seen your screenname...i'll let 4DGS chime in because he is better with sedan fitment
Old Apr 29, 2012 | 11:38 AM
  #3322
Adrian Ibarra's Avatar
Which is why I figure'd i'd ask. I figure if I went with a coil-over setup I would just keep it raised to factory height during the snowy seasons in case I needed them and bring them back down afterwards.
Something like:
Amazon Amazon
Which would require minimal clearance between the tire and the well. What do you think?
Old Apr 29, 2012 | 06:36 PM
  #3323
kei's Avatar
kei
Originally Posted by 4DGS
Adding a spacer will definitely fix it. and you'll have room for one up to about a 15mm spacer. You should be fine with that set up.
The second set up also works but again, since they are smaller you'll want a spacer just to make them look right.
You also have room for a larger tire out back if you wanted.
Thanks. I went with the second setup for now and I'll buy spacers after I see how much room I have.
Old Apr 29, 2012 | 08:31 PM
  #3324
DrewDrew's Avatar
lol no. well you could, but you'd need a serious pull and a lot of camber. I'll let blain elaborate on that some more.
Adrian - you could do that, and get two sets of tires. one stretched set for summer stance and then a winter/snow tire.
Old Apr 30, 2012 | 01:35 AM
  #3325
TORETTO's Avatar
Anyone recommend a spacer size for my fronts? I know you can't tell much from this pic. But i've measured it, and it's about 1" (or just a tad bit less) from the end of the rim to being flush with fender. (with the current camber)
The tires are barely stretched in the front, so I won't be able to get it as aggressive as the rears. But I don't mind switching tires.
Specs are 18x9.5 +25
The rears are 18x13 -6.
I will relip the fronts another inch when the time comes. But for now, I just want to space it out. I was thinking maybe a 25MM to make it flush with the fender? Or should I go with a 30 for a little more poke and stretch more. I think with 25s I can keep the tires as is.
(This pic was during installation of coilovers, the fronts weren't dropped yet lol)
Old Apr 30, 2012 | 01:48 AM
  #3326
DrewDrew's Avatar
current camber and tire? looks like a 235/40, no?
Old Apr 30, 2012 | 01:50 AM
  #3327
TORETTO's Avatar
natural camber up front. dont know what its at
the tires are 245/35
Old Apr 30, 2012 | 02:05 AM
  #3328
TORETTO's Avatar
measurement pic
Old Apr 30, 2012 | 02:32 AM
  #3329
DrewDrew's Avatar
245/35, really? must be a really small running tire. if the rim is exactly 1" or 22mm, I would I expect a 20mm would be the most to be safe without rubbing. 25 would be pushing it (without an ever so slight pull or smaller tire). I would do a smaller tire and a 25mm.
Old Apr 30, 2012 | 02:36 AM
  #3330
TORETTO's Avatar
I forgot to double check the tires while I was down in the garage. lol. I have the wheels up for sale though and the ad says those specs. So I think they're right.
I'll check tomorrow. too lazy. plus its dark downstairs and shitload of monsters downthere nomsayin aww shiit
anyway. wouldnt a 20mm still be tucked? since I believe 25mm =~ 1 inch?
i mean I could always swap out the tires. They are brand new in the front (like 900 miles). I'd just get a skinnier tire without spending a cent so I don't care about having to get a new tire. I just want the wheel to be at least close to the aggressiveness of the rear.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
