Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Apr 17, 2012 | 05:31 PM
  #3226
jookyshank's Avatar
I haz hugz to givez
Hey GURU's
Anyone know if I might have inner fender issues with Janik's wheels on my '05 X Sedan?
https://g35driver.com/forums/20-inch...l-w-tires.html
Danke!
Old Apr 17, 2012 | 06:18 PM
  #3227
4DGS's Avatar
Originally Posted by Condog
Already purchased
You're going to need to stretch to make these work, or you're going to need a tonne of camber and a hefty pull.
Pick weather you want to stretch or not.
And next time before you drop a tonne of cash on something, research it.
Originally Posted by soniic11
"I would like to start out by saying I'm new to this forum. There is ALOT of really good information here and I've done quite a bit of searching before becoming a member. I would like to know if anyone is running 1.1.2 Varrstoen in 19x11 +15 offset all around on their coupe. Any rubbing issues, fitment, etc.? What tires should i run if I'm looking for a flush stance for both front and rear? I will be getting these in a couple of weeks and I will be running these on megan street coil overs and megan front and rear camber arms. Your input is appreciated! Thanks!" -I posted this originally on "Who's running varrstoens thread"
Use the search, there is tonnes of info on running 11s in the front and the varrstoen set up.
As for the flush, you need to decide weather you want to stretch or be flush on beefy tires.
Originally Posted by jookyshank
Hey GURU's
Danke!
You want to run them spacerless?
You SHOULD be good. But you will need a hint of camber to clear the fenders.
Or you could go aggressive
Old Apr 17, 2012 | 07:14 PM
  #3228
Condog's Avatar
Thanks and what do you recommend as far as tire sizes?
Old Apr 17, 2012 | 07:46 PM
  #3229
LILShiraz's Avatar
Can I fit these on a 07 coupe?
18x9.5+11
18x10.5+16
Old Apr 17, 2012 | 08:35 PM
  #3230
jookyshank's Avatar
I haz hugz to givez
Thanks B,
Yea spacerless is the goal maybe I'll pull slightly cause I want to roll ~ 1 degree camber and you know me by now...I'm not that agressive...I'm a lover not a Hella. lols
Old Apr 18, 2012 | 01:05 PM
  #3231
luisp88's Avatar
would these specs fit a 2005 g35 sedan?
front:
19x8.5 +12 225/35/19
rear:
19x9.5 +20 235/35/19
TIA
-luis
Old Apr 18, 2012 | 01:31 PM
  #3232
jimmyboi860's Avatar
Fronts are good. Rears might need a roll.
Old Apr 18, 2012 | 02:05 PM
  #3233
crossphada's Avatar
wheel spacers size
need help have a 2003 g35 coupe just brought 20 inch rims staggered i
have 245/35/20 in the front and 275/40/20 in the rear woundering if i need wheel spacers and what sizes should i use in the front and back if needed at all thanks
Old Apr 18, 2012 | 03:31 PM
  #3234
Drew113's Avatar
Ban Hammer Expert
Need to know what offsets you have front and rear or at least a picture to show how much you still have to go to be flush
Old Apr 18, 2012 | 03:41 PM
  #3235
DrewDrew's Avatar
18x9.5+11
18x10.5+16
no problem. just roll the rears.
wtf?! what are your wheel specs?
Old Apr 18, 2012 | 06:05 PM
  #3236
4DGS's Avatar
You didn't answer my question but you're going to need to stretch either way. But like I said, you've gotten into something that you really should have researched. This isn't something you should ask about when you go with widths like 10.5 and 12.
1st off, I hope you have coilsovers as you will NEED them.
19x10.5 +19 in the front
19x12 + 12 in the rear
Front, 245/35
Rear, 275/35
Run a 15mm spacer up front at least.
Drop the car 2.5 inches or so. You'll be out of room for camber adjustment pretty quickly (you can maybe go -3 tops) then you're going to need to pull your fenders the rest of the way. I suggest finding someone who knows what they're doing for this. If you attempt it yourself you will most likely be spraying your 1/4s.
18x9.5+11
18x10.5+16
Yup, roll rear fenders remove fender liner bolts up front.
Thanks B,
Then yea you should be ok.
front:
rear:
TIA
-luis
Yea, roll the rear fenders and natural camber from a 2" drop should do the trick.
As everyone else said, no specs, no answers.
Old Apr 18, 2012 | 06:10 PM
  #3237
Drew113's Avatar
Ban Hammer Expert
Hey Drew I'm thinking of changing my name to DrewDrewDrew.....is that cool with you?? hahahaha
Old Apr 18, 2012 | 09:06 PM
  #3238
soniic11's Avatar
Found some good info, yusoslo's setup will be similar to what i want to do. Im going to be running stretched perhaps 245 35 for the fronts and 265 30 rear. What would be a mild stretch on 19x11 without much fender work,modification, etc.?
Old Apr 18, 2012 | 11:43 PM
  #3239
4DGS's Avatar
245/35 and 265/30 are almost identical stretches...
However both are aggressive as hell.
I'd go 255/35
Old Apr 19, 2012 | 10:33 AM
  #3240
vq35dedriver's Avatar
Is this a good setup, 19x9.5 +20 with 255/35r19 and 19x11 +29 with 295/30r19
Not as a aggressive as I would like but the price I couldn't pass up lol
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
