Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Oct 19, 2009 | 08:56 PM
  #361
HXS's Avatar
HXS
^ no prob with fitment, but not sure about brembos...
you probably have to do trial and error on brembo clearance.
Old Oct 22, 2009 | 05:39 PM
  #362
elperuano's Avatar
Question, 225 35 20 on 20 9.5 n 255 35 20 on 10.5.. When I align should i align to oem spec? And for toe, where should I get the toe set at for all 4 wheels? 0.03? Not looking for the flush look as i'd like the performance and idk if its the stretched look for my toe, rear toe is currently at 0.67 left rear n 0.87 right rear with camber at -1 on both sides but my ride seems to be REAL loose.. Like im on skates or sumthin.. Kinda scary, gonna re-align n re-balance these wheels. The toe i mentioned before was with my 19 oem forged setup.
Old Oct 22, 2009 | 09:10 PM
  #363
Skaterbasist's Avatar
Retired SuperMod
Anyone have a guestimate as to what the ideal offset range would be to run 305's on an 11 inch tire (with rolled fenders). Not too sunken, nor too flush (as in not to the point where it would rub on hard turns).
Old Oct 22, 2009 | 09:21 PM
  #364
HXS's Avatar
HXS
^ imma say +20 to +25.
Old Oct 26, 2009 | 10:57 AM
  #365
garnet_fire's Avatar
I need to know what range of offsets i can use on a 2005 g35x sedan?
i'm buying 17" winter rims and tires sized 225/50/17, and just want to know what offsets would work besides the stock 45?
Old Oct 27, 2009 | 04:47 AM
  #366
MST219's Avatar
Set up I'm looking at:
- 19x8 up front
- 19x9.5 on the rear
- NF210's with Tokico Blues all around, giving me a 1 inch drop in the front and .6 in the rear.
Questions:
- Will I need spacers to be flush? What size?
- Will I need to roll the fenders?
Thanks,
Matt
Old Oct 27, 2009 | 10:59 PM
  #367
will these fit a 2005 g35x?
looking at a set of winters
wheels are 17x8 i think with an et of 25 ... 5x114.3
tires mounted are 225/50/17
just wondering if i'll have any issues with fitment?
Old Oct 28, 2009 | 01:42 PM
  #368
golfinz's Avatar
I just picked up a 2006 IP G sedan and wanted to know will these wheels fit the car:
19" LMGT4s
Front Wheels: 19x8.5 +25 Front Tires: 245/35 Kuhmo Ecsta SPT
Rear Wheels: 19.9.5 +30 Rear Tires: 285/35 Kuhmo Ecsta SPT
Im worried about the rears. I dont have spacers and I am not lowered at the moment. Will I have issues with that wide of a rear tire?
Old Oct 28, 2009 | 02:00 PM
  #369
ShanesG's Avatar
^Pretty sure you'll need a rear fender roll!
Old Oct 28, 2009 | 02:14 PM
  #370
golfinz's Avatar
Thats fine! When I lower it and if I put spacers on it, need to roll them more I assueme...I just didnt want to spend 2300 and then have to buy new tires bc they were too wide
Thanks for the quick reply! Real 19" LMGT4s dont come around often and I hope they will look good on the sedan
Old Oct 28, 2009 | 02:17 PM
  #371
golfinz's Avatar
I know candlestick has the same wheels and he has 255s on the rear but he has spacers and is slammed. I dont plan on going that low but might do spacers later
Old Oct 28, 2009 | 02:42 PM
  #372
4DGS's Avatar
19" LMGT4s
If you're having those wheels offered to you, buy them ASAP. Very rare high quality wheels.
You will need to roll your fenders.
Old Oct 28, 2009 | 03:02 PM
  #373
golfinz's Avatar
Ya Ive got till Friday. Ive gotten mixed answers so far. All say the fronts will fit no problem. Some say the rears wont fit unless Im lowered at the offset is +45ish, other say just roll the fender and Ill be good. I do plan on lowering the car but with springs so I know I will need to roll anyways.
Old Oct 28, 2009 | 06:25 PM
  #374
4DGS's Avatar
Well if Shane has chimed in (which is has) then you know you'll be fine. He is the master of offsets.
But trust us, they will fit!
+45 is too high, whoever told you that is silly.
Old Oct 29, 2009 | 11:35 PM
  #375
blew are sicks's Avatar
I'm trying to figure out if 18x9.5 +12 FN01R-C on all 4 would be to aggressive on a G coupe with Brembos. I'm lowered on Greddy Type-S coilovers and I would also be running on 245/45/18 Dunlop DZ101s. I've searched and couldn't find anything. Please help.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
