Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#4428
quick question guys, what is the stock hub size of our wheels? I purchased some Work VS-XX wheels, but they came with Lexus wheels hub rings. I need to order some new adapters. Also, is there anywhere that makes them or do I have to order directly from Work?
#4429
Lexus IIRC is 56.1.
You won't be ordering hub rings from work though, your local tire shop or ebay is your best bet. 90% chance the works have a 72mm bore. But that's not 100% positive as they can be ordered with customs bore sizes. Just make sure they are at least 66.1 or else you will need to have them bored out to fit on the car.
#4433
#4434
#4435
http://www.1010tires.com/WheelOffsetCalculator.asp
It will clearly state the difference in offsets for whatever you type in. But to answer your question, +30 will stick out more than the +35. You will not need to roll the fenders with that size wheel, either offset
#4436
Alright so I need your help guys.
I'm planning on getting 19x9.5 +22 wheels with 255/35/19 in the front and 19x11 +25 wheels with 285/35/19 in the rear. Will these tires be stretched will they fit "normal". I'm not really into the stretched look.
Also what is a good brand of tire to get and which model?
I have a daily driven G coupe and the weather here is mostly rain and for 3 or 4 months there is sun. Good ol' Canada![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
I would really appreciate your help guys
#4437
Axis angle 20s
Just got a brand new set of rims for a really good price. Im pretty positive they will fit well on my 05 coupe, but just to make sure I wanted to get some opinions from someone with more experience in the whole wheel and tire fitment area. I got 20' axis angle wheels 9in wide in the front with a +20 offset, and 10in wide in the rear with a +25 offset. How close will these be to a flush look? and also what size tires would you recommend in order to not have any rubbing issues?
Thanks in advance!
Thanks in advance!
#4439
