Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Jan 15, 2013 | 06:12 PM
  #4996
4DGS's Avatar
Originally Posted by TGMcCoy
with this in mind, would a 225/40 front and a 245/35 have approx same sidewall height on rays also?
Just checking all options
Roughly yes. 225/40 and 255/35 are actually the best combo for that stagger IMO (I've run that set up many times)
Originally Posted by SkylineGTR2789
Question , buying a set of Stance SC5ive wheels for my coupe . Bad thing is the offsets are 20x10 +35 and 20x10.5 +27 . If I ran a 30mm spacer all around with a 235/35 and 245/35 tire. Would this get me a even stance ?
No, don't try and fix weak wheels with spacers. If you have the choice just buy the wheels right the first time.
Originally Posted by OH4G35
quick question how would this tire combo look?I know on a 10 i could run a 275/30 but I can get these for a steal they are nitto invo's
20x10 255/45/20
20x11 305/25/20
255/45/20 is a truck tire... Like literally 4" or so larger than OEM.
The rear could work though, as long as you have the correct offset to clear that width of tire.
Originally Posted by K.C
what tire size options would i have for a 08g35s sedan besides the 225/50/18 and 245/45/18 without compromising handling and performance?
On what width wheels?
Originally Posted by JaE35
235/35/19 up front and 255/35/19 in the rear play nice on a sedan?
Yea for the most part, a 225/40 up front would be better though.
Old Jan 15, 2013 | 06:50 PM
  #4997
dj714's Avatar
What size/offset 20" wheels would fit that description?
Old Jan 15, 2013 | 07:05 PM
  #4998
4DGS's Avatar
You're going for the aggressive and stretched tire look?
Around 20x10 20x11 +0
Old Jan 15, 2013 | 07:44 PM
  #4999
rhampsterwha2's Avatar
^ agree.... perfect size
Old Jan 16, 2013 | 10:39 AM
  #5000
KFeng's Avatar
Where's a good place to get some Nankangs? I'm located in Canada
Old Jan 16, 2013 | 03:02 PM
  #5001
famosobr's Avatar
been comtemplating wheels dimensions, looking at xxr 522 which set up would look better while not affecting handling
19x10 +20 rear 19x10 +42 front
or 19x8.5 +42 or +20 front and 19x10 +20 rear
Old Jan 16, 2013 | 03:44 PM
  #5002
squater's Avatar
Don't waste your money on nankang tires,had these on my coupe for approx 5000kms the road noise from these tires is unbearable and the ride quality sucks. Replaced with firestone firehawk wide oval, what a difference, spend your cash on quality rubber.
Old Jan 16, 2013 | 03:52 PM
  #5003
none of the will affect handeling as long as you put appropriate tire sizes based on your needs, out of the choices you listed I would do the 19x10 +20 all around because the other choices have weak offsets (assuming you have a coupe, sedan different story), are you lowered on spring or coilover? plan to have a stance or keep normal camber and do meaty tires?
Old Jan 16, 2013 | 06:38 PM
  #5004
4DGS's Avatar
Not sure for the west coast, send Adon a message (that's his name on here) he's BC based and will probably know someone who can get them.
Coupe or sedan?
Old Jan 16, 2013 | 11:54 PM
  #5005
KFeng's Avatar
I spoke to him before and he gets them at onlinetires.com but have to go across the border to pick it up. I was trying to see if there are any other options before I go ahead and do that.
Old Jan 17, 2013 | 12:12 AM
  #5006
4DGS's Avatar
I'll ask my Vancity drifter buddies lol gimmie a min.
Old Jan 17, 2013 | 01:28 AM
  #5007
KFeng's Avatar
lol ok onlinetires cost about $848.75 shipped for all 4 direct to me versus $585.24 shipped to WA
Old Jan 17, 2013 | 01:58 AM
  #5008
famosobr's Avatar
i have a coupe , lowered on springs, so 10 up front would work , was worried it be to big. I just dont want to do any fender rolling yet
would 19x10 +20 all around require rolling ?
Old Jan 17, 2013 | 02:04 AM
  #5009
famosobr's Avatar
Coupe or sedan?
coupe
Old Jan 17, 2013 | 02:10 AM
  #5010
4DGS's Avatar
19x10 +20 front and rear would be the best fit IMO.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
