Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Jan 29, 2013 | 08:29 PM
  #5101
AyyRyy's Avatar
Originally Posted by TGMcCoy
What wheels are you running? Any pics?
Hankook V12's ill post some pics later on heres the link to the wheels though https://g35driver.com/forums/19-inch...ggressive.html
Old Jan 29, 2013 | 09:00 PM
  #5102
4DGS's Avatar
What are the current specs...
Old Jan 29, 2013 | 09:01 PM
  #5103
AyyRyy's Avatar
Same specs as the link, i just got them about two weeks ago.
Old Jan 29, 2013 | 09:07 PM
  #5104
4DGS's Avatar
Originally Posted by AyyRyy
Gotcha, The thing is i already have tires on and my current set up is 10.5\30\275 front and 11.5\30\295
What are the specs on your current set up
Old Jan 29, 2013 | 09:09 PM
  #5105
AyyRyy's Avatar
Ohhh my bad I phrased that wrong.
Im on G37 wheels right now.
Old Jan 29, 2013 | 09:15 PM
  #5106
4DGS's Avatar
So you have not mounted the 10.5/11.5 Stagger what so ever...
This set up is not something you simply bolt on and go, it's going to look down right dumb with a 1.5" drop.
They need stretched tires and camber to tuck.
Old Jan 29, 2013 | 09:17 PM
  #5107
AyyRyy's Avatar
I knew they weren't bolt on and go I was just hoping to get coil-overs on after the wheels were mounted. And so your saying im not going to be able to run the tires I have on the wheels now?
Old Jan 29, 2013 | 11:16 PM
  #5108
4DGS's Avatar
You haven't said what tires you have on your wheels.
Old Jan 29, 2013 | 11:18 PM
  #5109
TORETTO's Avatar
rubber ones
Old Jan 29, 2013 | 11:30 PM
  #5110
AyyRyy's Avatar
19\30\275 front and 19\30\295 rear.
Old Jan 29, 2013 | 11:36 PM
  #5111
4DGS's Avatar
Ok, that is not a ****ing tire measurement.
Translated to SOP
275/30R19 and 295/30R19
Are you saying you have these on the stock 19" wheels? Those are the completely wrong tires for even your stock 19s. They're only 8.5 and 9" wide you're running 12" wide tires.
You need to new tires or those wheels will not be going on the car.
The 275s can be used on the rear, the front needs something more like a 255/30
Old Jan 29, 2013 | 11:40 PM
  #5112
AyyRyy's Avatar
Why are you getting so upset man? not that big of a deal..
But those are the tires on my VSXX, why would I put that on a stock wheel?
Old Jan 30, 2013 | 03:01 AM
  #5113
LxV Socal's Avatar
Sooo I won't have to start a thread...What is a decent set of front tires?
I was on 1010tires.com and looked around but it seemed like every tire I clicked on people complain about every tire I looked up.Just got my g35 as my first car and Im going to do my first tire change this weekend.I'm currently on Michilin pilot sport A-S Plus(225/45r18 FRONT 245/45r18 REAR),They seem to make a lot of noise but I saw on a thread (what do you hate about your g35) that noise is common for g35's.Anyways,someone get back at me asap! thanks! Looking to spend around 200$ or less per tire
Old Jan 30, 2013 | 01:44 PM
  #5114
P10 WRC's Avatar
Sup Yall,
I want to relip my front wheels and possibly my rears. current specs are
Work VS-XX
19x9.5+28 w/ 3.25 inch lip measured from the back of the face
19x10.5+29 w/ 5 inch lip measured from the back of the face
I want to get rid of my spacers up front and make them the same effective offset as the rear +/- 5mms but have some questions
1. how do i properly measure my lips? Do i put the tape measure at the back of my face where it meets the inner barrel or do i measure from the front of the face?
2. if i order from wheelflip.com can they match the factory polish on my lips i have now?
3. best place to order lips from?
4. If i order some lips that are .5" bigger up front, i will be at 10 + 20 correct?
5. what sizes are lips offered in? what increments, such as 1/4 inch increments? I would need something 1/2 inch to 1 inch bigger for the front. actually .75" more would be perfect.
Old Jan 30, 2013 | 07:12 PM
  #5115
4DGS's Avatar
You are asking questions without the correct information.
Figure out what you're talking about then come ask. I'm 100% down to help but when you're asking things that don't make sense it makes it very hard to understand what you're saying!
Tire reviews on sites are tough, a lot of those people are idiots lol
Michelin is always a great tire to stick with. If you can find Pilot Sports for the right price hope on those.
Some other options for you... these are listed from most expensive to least (in most scenarios at least)
Bridgestone Re760
Yokohama Avid Envigor
Hankook Ventus V12
Originally Posted by P10 WRC
Sup Yall,
Work VS-XX
Measure from the bead to the edge of the flange. So measure from the OUTSIDE of the lip and put the tape measure basically where the roller portion of the lip ENDs. The measure the distance from there to the flange.
Or, measure the whole width from edge to edge and then subtract a half inch. That's the regulation lip size.
Negative, your lips are clear anodized the wheels from wheel flip will be raw polished.
Wheel flip or VR are your best bet
Negative, If you relip the 9.5 +28 to a 10 you will be at 19x10 +22
Without going custom you're going to be moving in half inch increments. Anywhere from .5 to 6" are commonly stocked. Anything larger will usually be a special order.
Bolded with answers!
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
