Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Mar 7, 2013 | 07:30 PM
  #5311
daily_stanced's Avatar
hey guys i need some help i am upgrading to brembos and i have a
ssr sp1 sitting at 9.5/19 6.5 outer barrel and 3 inner barrel and not sure on the disks but -25
what spacer do it need to clear bbk the back clears just need help figuring out what i need to clear front bbk
Old Mar 7, 2013 | 10:14 PM
  #5312
TGMcCoy's Avatar
You are going to need to know the pad size-- it's kinda hard to tell by offset. Do you have them? Take a picture of the pad. Also compare it to the rear wheels. If its the same, most likely it won't clear brembos. Depending in the wheel/spoke design, a spacer of 5mm-25mm may be needed.
Are these He-Man's old SP1?
Old Mar 8, 2013 | 07:05 PM
  #5313
ill work on the pad sizes and yeah there hemans lol he told me that the rear clears so just need to figure front
Old Mar 8, 2013 | 07:30 PM
  #5314
evan2k's Avatar
Noobie fitment question :(?
Im planning on getting varrstoen es1
Front 19x9.5 +12 offset
Rear 19x11 +22 offset
i was wondering if this will work on my car without fender roll or rubbing on stock suspension. i have the inven body kit if that helps... and what tire sizes would work best with these rims? thanks guys
Old Mar 9, 2013 | 11:03 AM
  #5315
chalyse's Avatar
Tire Size Suggestions
So I got a pair of 255/35/19 that I want to put on my coupe rear 19inch Rays.What would be the best size to pair up with for the front.
Old Mar 9, 2013 | 12:33 PM
  #5316
ItsA..Gthing's Avatar
Getting ES1...19x11 et 15 rear....will they clear BREMBOS without spacer ...Dropped 1 inch...was going to run 275/35...Will I rub in rear? Tnx...
Old Mar 9, 2013 | 06:27 PM
  #5317
LelandKing's Avatar
New wheels & tires
What y'all think? Lower it?
Old Mar 10, 2013 | 12:55 AM
  #5318
rdavis's Avatar
Old Mar 10, 2013 | 03:42 AM
  #5319
herrschaft's Avatar
235/245x35
Old Mar 10, 2013 | 05:28 AM
  #5320
TGMcCoy's Avatar
I hope you are ready for some serious work. I can't wait to see these fit properly!!! Super negative camber arms front and back + super fender work + super stretch... Make us proud!
Old Mar 10, 2013 | 05:24 PM
  #5321
Plur's Avatar
Hey will I run into any problems running 255/35/19 instead of 245/255 on 11's all around on a coupe?
Old Mar 10, 2013 | 05:25 PM
  #5322
Plur's Avatar
so basically not running staggered tires.
Old Mar 10, 2013 | 05:35 PM
  #5323
4DGS's Avatar
No not really, you need to roll the fenders and you need to lower the car.
255/35 and 285/35
225/40
No way to tell, ask Varrstoen.
Na you don't have to stagger, as long as you have room you'll be fine. But keep in mind, bumping to a 255 will be a slightly larger sidewall, won't be able to roll as low up front.
Old Mar 10, 2013 | 05:47 PM
  #5324
Plur's Avatar
Is there any differences with stretching 255/35/19 vs 265/30/19 on an 11? Would one look better or ride lower?
Old Mar 10, 2013 | 09:19 PM
  #5325
4DGS's Avatar
265/30 is smaller so you'll be able to get lower.
Look is up to you.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
