Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old May 18, 2013 | 01:47 AM
  #5731
chris.paul's Avatar
well your car 2 years ago looked really nice. guessing it looks nicer now.
Also, i had a question. Will I need to get a new spare tire or will the current 17inch stock g35 rim work fine as a spare tire with these 18inch rims
Old May 18, 2013 | 01:48 AM
  #5732
Plur's Avatar
It'll be fine
Old May 18, 2013 | 08:24 AM
  #5733
OBsessed's Avatar
I know it's been asked and answered before but my memory sucks, forgive me.
What's the preferred type of silicone to use for re-sealing 3 piece wheels after a rebuild? I thought I had remembered it being RTV Black but the set I just broke down was using a clear 30yr silicone.
I'm sure either would be fine but what's the best / safest bet?
Old May 18, 2013 | 12:10 PM
  #5734
TORETTO's Avatar
I used that stuff from Home Depot made by GE. I think it's Silicone II
Old May 18, 2013 | 12:46 PM
  #5735
chris.paul's Avatar
What would the difference between 225/40R18 and 225/45R18 tires be. I was told to buy 225/40R18 for the 18 inch rims I purchased. I have a 2003 g35 sport sedan. Everything is stock if that helps. I was just asking because I can get 225/45R18 tires for cheap. Just wanted to know what the difference would be between these two tire sizes.
Old May 18, 2013 | 12:48 PM
  #5736
TORETTO's Avatar
45 has a thicker sidewall, so your rolling diameter would be bigger
Old May 18, 2013 | 01:00 PM
  #5737
Plur's Avatar
Just get the cheaper one.
Old May 19, 2013 | 01:40 AM
  #5738
ReStylin's Avatar
245/40R18 front
275/40R18 Back
rims = 18x9.5 (all around) G35
Will I have VDC problems?
Old May 19, 2013 | 03:19 AM
  #5739
TGMcCoy's Avatar
Anybody know where to chrome plastic? Like plastic wheel center caps? Mine are in rough condition...
Old May 20, 2013 | 12:22 PM
  #5740
Jay267's Avatar
Offset: 30
Rim Material: Alloy
Number of Bolts: 5
Rim Width: 9
Bolt Pattern: 5x114.3
Rim Diameter: 19
do you think a rim with those spec fit? If so, what kind of tires do you guys recommend..!
Old May 20, 2013 | 12:24 PM
  #5741
Jay267's Avatar
Will a offset of 30 and bolt patter 5x114.3 fit? Also has a diameter of 19inches! and width of 9
Old May 20, 2013 | 12:37 PM
  #5742
jookyshank's Avatar
I haz hugz to givez
Jay...
Coupe or sedan (either way, yes it will fit) just depends on how sunk it will look
Old May 20, 2013 | 12:53 PM
  #5743
Jay267's Avatar
Any recommendation for tire sizes for rims with offset of 30 and bolt patter 5x114.3,diameter of 19inches! and width of 9
Old May 20, 2013 | 01:55 PM
  #5744
mitsuman's Avatar
rims: 20x8.5 +40
tires: 245/35/20
on 03 sedan
would these look ok? cant find any pics.
Old May 20, 2013 | 02:18 PM
  #5745
North NJ G's Avatar
Need help
Thinking of running 19X8.5 FR and 19X9.5 RR...What woud be a good offset to run for a awd sedan??? Looking to achieve a flush look. Got about two & half inches inches of space from tire to fender all around, but will drop an inch
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
