Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Feb 1, 2010 | 09:17 PM
  #571
GAU-8's Avatar
Well they don't show on that site the size that fits the G. 5X114.3. The only ones I saw were 5X100 and 5X112.
Old Feb 1, 2010 | 11:20 PM
  #572
g3fly's Avatar
what the hell is A-disk O-disk ...ect? IM hella confused
Old Feb 3, 2010 | 01:22 AM
  #573
HXS's Avatar
HXS
^ it's how high the pad is for brake clearance.
work wheels goes by disks: R, A, and O.
Old Feb 3, 2010 | 01:41 AM
  #574
g3fly's Avatar
what has the most hight? R?
Old Feb 3, 2010 | 04:26 PM
  #575
HXS's Avatar
HXS
^ R and T for BBK clearance.
Old Feb 3, 2010 | 04:33 PM
  #576
GreenGoblin's Avatar
The goblin resurrection
Got the clearance Clarance?
Old Feb 3, 2010 | 04:53 PM
  #577
WILLIE BEANS's Avatar
Originally Posted by LightsOut
17" 6 spoke (Sedan std)
Front & Rear: 17"x7" (+45mm)
is that the correct offset for these wheels all around ??
Old Feb 3, 2010 | 05:12 PM
  #578
OCG35's Avatar
yes
Old Feb 11, 2010 | 10:24 AM
  #579
elperuano's Avatar
Hey Rob, what kinda spacers were u running in the fronts with the all black t1s that you had before? Tryna get em more flush but without scraping the sidewall :P
Old Feb 12, 2010 | 08:56 PM
  #580
Trust037's Avatar
Correct offset
Hi All,
I'm planning on getting some Stern ST7 wheels. Just wanted to know what kind of offset I should get to make it look somewhat flush.
Here's info so far: 2003 Coupe Sport non brembo lowered on 350z Tein H-techs
Wheels are: Stern ST7 19x8.5 front and 19x9.5 rear.
What kind of offset should I get?
20mm, 25mm, 35mm, 38mm?
I've searched here, 350z forums, and found tons of different answers but just want wheels that I don't have rubbing issues or have to do any kind of fender rolling. Thanks again and sorry if this has been asked a million times.
Old Feb 15, 2010 | 10:22 AM
  #581
DyslexicG35's Avatar
wheels that are 8.5 20 offset
I'd suggest take them back and get a refund. your wheels will be so sunken in, it wont look like you bought new wheels, more like upgraded oem wheels.
best set up since you already have the wheels.
245/35F
255/35or/40R
then add 20mm spacers all around front and rear
or local shop suggestion, since those size are oem 19 sizes
Hmm, from the calc's I've been playing with
"Package will stick out 28 mm (1.1'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset. "
http://www.wheelsmaster.com/rt_specs.jsp
So I'm not sure why you say it will be sunken in, please clarify.
"More like upgraded OEM wheels" is fine with me..
Old Feb 15, 2010 | 06:40 PM
  #582
856_reilly's Avatar
best fitment for most aggresive set up on 20 inch wheels
lookin for some opinions.. goin to to go for the aggresive streached tire set up and i am stuck on what to do about offsets. i'm goin with the weds kranze vishunu wheels doing a 20x10 front and 20x11 rear want to run the 35 series tire. im on stance lk coil overs now but want to go as low as poss. (within reason)on this set up.... can anybody help??? thinkin the singal digits for offsetbut dont want to over kill i can alway add spacers to make up but want to get as close as possible. of course rollin my fenders flat.....
Old Feb 17, 2010 | 12:47 AM
  #583
UrangeAve's Avatar
Anyone know of a place that I can get replacement barrels/hoops for a 2 piece Iforged wheel. I want a larger lip then I have now?
Old Feb 17, 2010 | 10:59 AM
  #584
856_reilly's Avatar
wheels and offsets
hey shane was wondering if you can give me a heads up on this im planning to run a 20x10 0 in the front and a 20x11 -5 in the rear. i want aggresive but was wondering if its to much to go with i understand that when i drop my car ill have to do a roll and a pull but is it a major pull? and the camber will b in the neg. and i need to aline it correctly but after all is said and done will there still be big neg. camber to where ill go through tires lk crazy. please let me know if possible thanks bro
Old Feb 18, 2010 | 01:13 PM
  #585
elperuano's Avatar
Ok need some help with some clearance for a BBK kit.
On stock brakes right now and if i brake at high speeds wheel shakes and me no likey that. Looking for a slight upgrade, like akeebono's or sumthin. Tryna figure out which BBK i can run (i hope i can run em) that'll clear my wheels.
Current wheel set-up is work t1s 225/35/20 9.5 +7 R disc in the fronts and 255/35/20 10.5 +0 O disc in the rear. Can i run Akeebono's and not have any clearance issues? Tryna run any kinda upgraded brake kit. Brembo's or whatever.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
