Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Mar 5, 2010 | 03:31 PM
  #661
OCG35's Avatar
Originally Posted by 4DGS
Rays wheels say Rays on them, the 18"s don't.
lots of Rays wheels dont say Rays...
Do the OEM Enkeis say Enkei?
Old Mar 5, 2010 | 04:16 PM
  #662
LightsOut's Avatar
SIETESG
Originally Posted by autobot
I am a total newb at this. I am looking at some wheels that are 19X8.5 fronts and 19X9.5 in the rear both have a 35mm offset. I am also looking at doing a 1.5 inch drop all around. What size tire would you recommend and would i need spacers or anyhting else to make it work and look decent?
coupe or sedan?
thos are more of sedan offsets and sizes
Old Mar 6, 2010 | 12:21 AM
  #663
TwilightSedan's Avatar
What OEM Enkeis, which OEM's are made by Enkei?
Old Mar 6, 2010 | 12:36 AM
  #664
4DGS's Avatar
^ G37 and 07/08 Sedan wheels.
Old Mar 6, 2010 | 01:20 AM
  #665
OCG35's Avatar
^^^ yep
Old Mar 6, 2010 | 11:00 AM
  #666
TurTLe*'s Avatar
enkei makes a lot of random OE wheels. They do a lot of toyota's they aren't fancy or anything and are not the enkeis you have in mind.
wheel wheel wheels. I have 18x8.5 +33 thats going to be on the sedan, ideally i wanted RE760 in 245/45/18 but thats about $600-700. A local guy i know is selling Re960 the all-season set with 80% for $400 but they are 245/40/18. Which should i roll with, these are my summer tire setup. I dont race or anything. Go to the drag strip once a year maybe. Do a lot of highway cruising.
Old Mar 6, 2010 | 10:13 PM
  #667
DyslexicG35's Avatar
I asked about tires for my new wheels weeks ago. LightsOut answered a few posts later saying they would be "Sunken in" and to buy spacers if I was gonna keep them.
I've checked several calcs and DTD and Neal @ Tire Rack all say it will actually stick out.
Essentially. Stock wheels are 18x8 +30 (I had thought this was +33), New ones are 19x8.5 +20
I assume at this point LightsOut was wrong and there have been no other responses. The question still remains about tire sizes and add another questions about adding Tein H tech springs to the mix, any fitment/rubbing issues?
Thanks in advance.
Old Mar 6, 2010 | 10:17 PM
  #668
O HELLA OEM's Avatar
Originally Posted by LightsOut
Front--- pull some camber with 25mm spacer. to play it safe do 20mm front
if you slam your ride, a fender pull will be needed.
Rear ---- deff. need a fender roll.
are you going with the strectch look? is that why you have a 265 tire.
i didnt put these tire sizes on my nismo. They are the Oem Potenzas factory tires that came with the rims. So i should have bought 20mm spacers all around instead of 25mm.
Old Mar 6, 2010 | 10:36 PM
  #669
dvsmeth0dz's Avatar
Are the toe bolts important to install when installing the camber kit? I bought mines used and they never came with them.
Old Mar 7, 2010 | 12:28 PM
  #670
Jimballs26's Avatar
I have 245/35/19 ET20 (f) and 275/35/19 ET20 (r). I want to know what size spacer I could go without rubbing and I plan on dropping 1.2 front and .9 back. Also, I was recommended H&R would that be a good one or is something better.
Old Mar 7, 2010 | 12:57 PM
  #671
Texasscout's Avatar
"out of toe" will wear out a tire MUCH faster than just about anything. If you are not "in spec", yes, you need them.
Old Mar 8, 2010 | 01:41 AM
  #672
mtv39's Avatar
Question about these wheels
Was messing around and found these for sale. I really like them but am not too sure if they will fit. I have a 2003.5 sedan and am about to put the pro-kit on soon. If someone could tell me if these will fit or not and if so what, if any modifications, will need to be made to make them fit? Thanks, Matt
http://www.elementwheels.com/proddet...085bsm5212015b
Old Mar 8, 2010 | 01:48 AM
  #673
dvsmeth0dz's Avatar
Thanks, I guess I'll be buying toe bolts before I do my camber install Anyone got some laying around? Haha
Old Mar 8, 2010 | 02:22 AM
  #674
OCG35's Avatar
the front will be okay but the rear will be about 10mm past the fender edge... with Pro kit that not gonna create a problem (just wont look that good imo)... if you go lower you will need quite a bit of camber (and fender roll) to clear.
Old Mar 8, 2010 | 08:58 AM
  #675
coreydee's Avatar
Sir, could you help me with my selection?
S5:F
19"x9.5J +35 offset front
19"x10.5J +22 offset rear
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
