Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old May 15, 2014 | 02:29 PM
  #7021
SUMBLAKDUDE's Avatar
Originally Posted by JrSr2003
what do you mean by flush? Dont want to have to roll my fenders :-/
Meaning ur wheels are even or close to the edge of the fender wheel. Your offsets and how wide the wheel is determines that. The lower the offset and the wider the wheel the further it comes out. Front fenders are already rolled. Rear ones will need to be rolled depending on ur wheel specs. Not sure how much you are lowered but on stock height you won't have to rolled rear fenders with those specs. I'm at stock height and I'm fine with 9.5 inch wide wheel with a +20 offset. I can drop and inch maybe 1.5 and won't have to roll. Any lower and I would
Old May 15, 2014 | 03:40 PM
  #7022
JrSr2003's Avatar
awesome... so my only concern now is if they clear the calipers.. Hmmm...
Old May 15, 2014 | 05:51 PM
  #7023
With those offsets it should clear but will depend on wheel design for example if a concave design the spokes might not clear it
Old May 15, 2014 | 06:58 PM
  #7024
BenitesG35's Avatar
Would 19x9.5 +12 be flush in the front or would I need spacers I have an 05 g35 coupe
(no brembo) and coil overs
Old May 15, 2014 | 07:26 PM
  #7025
Yes you would be for sure and may even stick out lil past depending on what size tire you went with. I have a 8.5 +15 offset up front on 235/35 size tires. I wouldn't go lower than 245 size tire on a 9.5 wheel although there are plenty that do.
Old May 15, 2014 | 09:37 PM
  #7026
BenitesG35's Avatar
I most deff be going lower my tires I juss got are 225/35 and 245/35 with 19x10.5 +15 in the rear
Old May 15, 2014 | 09:40 PM
  #7027
They will be stretched but will work. I have 255/35 on rear 9.5 and it's slightly stretched. Will def have to get fenders rolled with that width for sure
Old May 17, 2014 | 09:28 PM
  #7028
Brooksy088's Avatar
Slammed on bc coilovers, around -3 camber in rear.
Slight rolling fenders and maybe a 8mm spacer for the front. 225 35 19 and 255 35 19
Should be find right?
http://www.ravspec.com/shop/work-gnosis-gs5-19x9-5-19x11-0-bru-finish
Old May 20, 2014 | 04:02 PM
  #7029
StepUpG35's Avatar
Sedan g35 06 wanting to get 18's for a daily driver UK roads suck _____ so with that said how hard would it be to work these two set ups:
F: 18×9.5 +27 R: 18x10.5 +30
F: 18×8.5 +30 R: 18x9.5 +27 or +40
Please feel free to reccomend tire sizes (meaty not rubber bands )
I'm not trying to hella flush/stance it or anything cool like that im honestly more after the meaty track set up look, fenders are not rolled but it does have coilovers and camber kit front and rear... thanks in advance
Old May 21, 2014 | 10:50 AM
  #7030
ChrisKG35's Avatar
Can anyone help me?
Fenders rolled, can I rock +0 offset in the back and +5 in the front?? I have coils with credit card gap.
Old May 21, 2014 | 10:22 PM
  #7031
Brooksy088's Avatar
Originally Posted by ChrisKG35
Can anyone help me?
What is the rim size and width. What size tires ?
Old May 21, 2014 | 11:56 PM
  #7032
WIGGY005's Avatar
I have 19x10-4 & 19x11-0 vs-xx . 3mm in the front to clear brembos on a 04 coupe. What tires size will I need? I was told to roll my rear fenders,. I'm willing to stretch
Old May 22, 2014 | 12:39 AM
  #7033
DrewDrew's Avatar
225/35 and 245/35.
Old May 22, 2014 | 02:23 AM
  #7034
WIGGY005's Avatar
Originally Posted by DrewDrew
225/35 and 245/35.
Thanks DrewDrew, appreciate it
Old May 23, 2014 | 01:35 PM
  #7035
mliu66's Avatar
Can anyone help look at my rim/tire selection?
Hi, guys
I am having 04 sedan with stock 17x7 +45mm offset rim and 225/55/R17 tire, front and rear
Now I want to switch to 19' rims and I have two options:
1. stock 19' rims of a coupe: Front: 19x8 +30mm offset Rear: 19x8.5" +33mm offset, tires are 225\40Z\R19, 245\40Z\R19
2. aftermarket 19' rims: 19x9.5 with a +35 offset, tires are 245/35/R19, 235/30/R19
Two questions I have:
1. I did some research but seems no definite answer if it is safe to switch to a rim with different offset. Can I use these rims?
2. I checked the tire size and diameter should be fine, but not sure about the clearance to the suspension. Should I roll fenders and/or add spacer?
Need to make a decision today or tomorrow. Thanks a million!
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
