Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Sep 24, 2014 | 09:13 PM
  #7126
BowWizzel's Avatar
Just look for a tire with a high tread wear rating or high tread wear warranty
Old Sep 24, 2014 | 09:16 PM
  #7127
ScraggleRock's Avatar
X2
A lot of tires for cars like ours are a softer compound. Look for a treadware rating of 400 or over.
Old Sep 29, 2014 | 02:40 PM
  #7128
Conissah's Avatar
I'm thinking of getting some Varrstoen ES6's. I am stuck with offsets, I want it flush, but I don't want to have to pull or use lots of camber to get them to fit. I have Brembo brakes, and according the site Option 2 won't work because they don't clear the calipers, but maybe they would if I used spacers? It also says that Option 1 will require camber to fit. I am kinda lost here, someone guide me. Sizes I'm debating are:
Option 1 (Preference)
F: 19 x 9.5 +12
R: 19 x 11 +15
Option 2 (Apparently won't clear Brembo Calipers)
F: 19 x 9.5 +22
R: 19 x 11 +25
I have 255/35/19 tires for front, and 285/35/19 for the rear. Just any advice for which offset would be better, I want them to be as flush as possible but I don't want to run crazy camber and I don't want them to be poking.
Old Sep 29, 2014 | 03:40 PM
  #7129
CARMA_626's Avatar
40 series on a 9.5" / 10.5" wheel?
Hello, I really need help from the tire guru's on here. I searched around but the set up I would like to go with is not popular at all, info is hard to find.
I have 9.5" fronts, offset is +18 (I think), rears are 10.5", offset is +25 (I think).
Currently running 245/35/19 Fronts, and 275/30/19 Rears.
The set up I want would be 255/40/19 front and 285/40/19 rears
Tired of the harsh ride, I have a family now so I need something more comfortable. The thicker, the better - a 40 series would be ideal.
I raised my car on 350z springs, so clearance shouldn't be an issue. My main concern is VDC.
I've read the various fitment lists and tire calculators, but can't seem to get a definite answer - any help would be great!
Old Sep 29, 2014 | 04:32 PM
  #7130
thegreatkwijibo's Avatar
^get 18's.
Old Oct 4, 2014 | 11:48 PM
  #7131
Conissah's Avatar
F: 19 x 9.5 +12
R: 19 x 11 +15
F: 19 x 9.5 +22
R: 19 x 11 +25
Still looking for an answer for this.
Old Oct 5, 2014 | 12:06 AM
  #7132
izzueeek's Avatar
F: 19 x 9.5 +12
R: 19 x 11 +15
F: 19 x 9.5 +22
R: 19 x 11 +25
First of all, (i always ask this first) what are u lowered on?
You want it flush and dont want camber to get it fit, well you should not slam it then and leave it at a functional height.
I would go with option one, it should clear the brembos no problem, and maybe 245/35, 275/35
Old Oct 5, 2014 | 12:10 AM
  #7133
izzueeek's Avatar
Originally Posted by Kicknshift
Hey guys I'm currently running some varrstoen es2's 19x9.5 front and 10.5 rear.
Tire sizes are 235/35/19 f and 255/35/19 rear, the rears are stretched a lot more than the front so I was thinking of matching it with a 275/35/19 rear set I have sitting in my garage.
Would this be too big for the rear to have?
Any problems I might run into?
Are u going for the stretch look? If not 245/35, 275/35 imo
Old Oct 5, 2014 | 09:27 AM
  #7134
Conissah's Avatar
I am lowered on HKS Hipermax III. Its at a very functional height. I don't plan on slamming my car because I actually drive it and the roads are crap here. But you can look at my other posts and see my stance. I'm highly considering either set, and I feel more comfortable with Option 2 because I don't want the wheels sticking out too far. I have a set of 5mm spacers I can run. You think that if I went with Option 2 but used my 5mm spacers they would clear the calipers?
Old Oct 8, 2014 | 11:37 AM
  #7135
izzueeek's Avatar
Option 1 will give u more room to play with. Tbh +15, +12 offset arent that aggressive. Before I ran es 2 with 19x10, 19x11 +15 allround.
Old Oct 8, 2014 | 02:56 PM
  #7136
Conissah's Avatar
How low were you and how much camber did you run? I have camber kits front and rear, but for drivability purposes I would prefer to keep the camber as "stock" as possible. Also, how much poke was there?
Old Oct 8, 2014 | 03:22 PM
  #7137
izzueeek's Avatar
Low, ran -2.9 FR -3.1 RR. I was running 245/35, 275/30 though.
Old Oct 25, 2014 | 01:11 AM
  #7138
Herbbie Hablib's Avatar
Looking for info on running a 19x10.5 +30 with a 265/35 on a V35 Sedan. Possible with just a roll?
Thanks
Old Oct 30, 2014 | 02:42 AM
  #7139
ILoveMyG35&DC5's Avatar
Need help with Wheel offset
Im looking to buy some STR wheels for my G35. Im going to go with 19x8.5 in the front and 19x10 in the rear. I want a flush look so need help with the offset. can you guys post pics of the wheel offset you guys are running?
Old Oct 30, 2014 | 03:54 AM
  #7140
scottvt's Avatar
EDIT since this thread got moved: In reply to ILoveMyG35&DC5....
I'm running 19x9" +26 in the front and 19x10.5" +22 in the rear with 16 mm spacers all around.
I haven't had an alignment yet, so I can't tell you my camber specs. If you are set on those widths, I would say +4 in the front, and 0 offset in the rear with no spacers at all SHOULD get you roughly where I am at as far as "flush" whether or not this is what your going for, or the Hellaflush look. I am no wheel expert, but it's math, so I think I am pretty damn close.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
