Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Feb 5, 2019 | 07:09 PM
  #7651
Rob Wolford's Avatar
2006 G35 2 door coupe lowered, coil-overs, 1" spacers on wheels, SpecD tuning Cat Back, CAI
Have you tried https://www.willtheyfit.com/ ?
Old May 9, 2019 | 05:38 AM
  #7652
baicep's Avatar
blackness
Anyone ran 275/35/18 on a coupe 06 stock suspension? Trying to run 18x10.5 +22 all around.
Old May 24, 2019 | 02:47 AM
  #7653
terrasmak's Avatar
G Sedan
Looking at bringing an 06 sedan home and have to replace the dubs on it ASAP. Goal set are a fun daily, slight drop on Tie, keep the alignment around -1.5 camber front and rear. So I'm thinking 18x9.5 all around with 255/40-18 , just need to figure out the perfect offset for my goals.
I know everything about the 350z, nothing about sedan fitment
Old Oct 10, 2019 | 01:37 PM
  #7654
ADarkerBreed's Avatar
Infiniti G35
I'm looking into getting some 17" steelies for a winter tire setup, anyone know of any brake clearance issues on an 06' G35 coupe?
For some more context this is what I'm looking at for steelies
https://www.summitracing.com/parts/c...7714/overview/
Old Mar 3, 2020 | 09:25 PM
  #7655
baicep's Avatar
blackness
I just want yall to know yeah 18x10.5 +22 fits all around. Stock suspension stock camber. Federal RS-Pro 265/35 (they run wide).
Old Mar 3, 2020 | 10:37 PM
  #7656
Scorpi0's Avatar
Thats some major fender gap broski. U gonna drop it??
Old Apr 7, 2020 | 10:55 PM
  #7657
baicep's Avatar
blackness
Nah too lazy dont wanna spend right now lol. This is me taking a pic squatting angle so this sure do show the gap. I wouldnt even drop more than an inch anyways. Thinking bout changing the tire sizing tho. 265/40 RS-pro rear so I wont be squared set up. Anyone ran 265/35f, 265/40r set up?
Old Apr 16, 2020 | 05:34 PM
  #7658
Rainy's Avatar
2005 G35 Coupe loaded but bone stock!
+15mm or +22mm offset?
Hey guys I'm about to pull the trigger finally on a new set of rims. Car is a 05 G35 Coupe RWD, stock ride height but I have Tein Coilovers that may go on after the wheels if i think the car sits too high.
I decided against 19s and am going 18" Aodhan DS01 In chrome, deep dish lip.
18x9.5 front - 245/40/zr18 tire
18x10.5 rear - 275/40/zr18 tire
My only question now is on offset - they only come in +15mm or +22mm.
Will +15mm all around stick out too far? I'm not going full stanceboy but I like them near flush.
Help me so I can finally pull the trigger on these!
Tyvm
Old Jun 13, 2020 | 07:10 PM
  #7659
fredrik94087's Avatar
Tyvm
my rears are 19x9.5 +20 285/35/19.
Fenders were rolled and it os at the limit.
I suggest +22 for you.
Old Aug 16, 2020 | 06:55 PM
  #7660
Siknin's Avatar
04 TB G35 coupe 6mt w' Brembos
Offset And tire question on 04 G35 Coupe
My car is 04 G35 Coupe with Brembos Also running Tein Flex Z coilovers. roll fenders to fit front 19x9.5 et25 and 19x11 et18 rear? I don’t want to use spacers. And for tire size not sure on that yet. Front 245s or 255 and rear 275 35
Ideas?
Old Aug 17, 2020 | 01:02 AM
  #7661
lonewolf99's Avatar
can someone recommend tires and offset for a G35 coupe; looking to run Work VSXX 19x9.5 in front, 19x10.5 in rear.
The car is currently on 18s with HKS coilovers and akebono front&rear brake setup.
I don't know whether I should be looking at Work VSXX Step-lip or R or T-disk. in order to make sure the brakes have clearance.
Old Mar 29, 2022 | 03:03 PM
  #7662
mcfadden5's Avatar
g35 Coupe
wanting to add wider lips to my wheels and was wondering if these specs would fit okay . currently lowered about 1 inch
Front: 19x9.5 +10
Rear: 19x10 -2
Old Mar 29, 2022 | 03:18 PM
  #7663
mcfadden5's Avatar
g35 Coupe
Front: 19x9.5 +10
Rear: 19x10 -2
Old May 21, 2022 | 05:21 AM
  #7664
GigaMonkey's Avatar
Nissan Skyline 350gt 2005
Tire and rim fitment on V35 2005
My 2005 model is currently stock
Its currently running
225/45 18 x 8 and 30+ offset / Front wheels
245/45 18 x 8 and 30+ offset / Rear wheels
on stock suspension
and I'm looking to go to
225/40 18 x 9.5 and ? offset /Front wheels
245/40 18 x 10.5 and ? offset / Rear wheels
i would like to know if a decrease in offset will force my wheels to extend outwards from the wheel well, and what offset would be recommended for a flush fitment also being on a 1 inch to 1.5 inch drop all the way around?
would this setup rub?
i am also very prepared to roll fenders
Old Aug 15, 2022 | 05:31 PM
  #7665
Nmccabe17's Avatar
Infiniti G37S sedan 2011
Brakes Stuck on whether these alloys will fit!
Hi guys,
New to the forum and generally quite new to modifying cars (still learning)! Just have a quick question about potential fitment/clearance issues for a set of alloys I am wanting to buy.
I have searched a number of forums and sites about different offsets and widths as well as speaking to vendors directly but still not much clearer sadly
So I have a 2011 Infiniti G37 sport sedan RWD (with the akebono brakes) and wanting to know whether this setup would be possible to clear brakes but not cause rubbing/need fenders rolling/adjustment of camber or toe:
Japan racing JR15s Front 19x8.5J ET20-40, with rears 19x10J ET35
Japan racing JR10s Front 19x8.5J ET20-35, with rears 19x9.5J ET20-35.
I am able to run spacers if needed, and have considered also adding in lowering springs (unsure of brand yet) but do not want to go crazy with fender rolling, stretching tyres or drastically lowering the stance. I would like the ride quality to not be sacrificed too much either.
Would hugely appreciate some advice,
thanks, Nick.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
