Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Jul 21, 2010 | 11:21 AM
  #1066
gdrum's Avatar
question
Here is my new wheel setup, and I am having a tough time finding tires that will best fit this.
04 g35 coupe
My car is slammed on full coils, exhaust hits on speedbumps etc.
19x8.5 +15 19x10.5 +20
I got 235/35/19's for dirt cheap like 90% tread so I would like to use them but dont have to. These will work fine correct? Little stretch probably look good with the offset?
I was trying to find 275/35/19's used, but cant find any cheap....so now im thinking of going 265/35/19's..and my question is will this work? Am I even on track with the right tire sizes? Opinions please. Thanks
Old Jul 21, 2010 | 03:04 PM
  #1067
Brady.law's Avatar
Continental sport contact 2's or handcooks? Handcooks I didn't find good reviews, I'm on 19's on the back and its going to cost about 500$ installed for both back tires, is that reasonable? If not what are some good online places for tires? Please help.
Old Jul 21, 2010 | 06:21 PM
  #1068
the_sedan's Avatar
konxeptionz, those are the offsets WITH the spacers. original offsets are 20 and 25.
Old Jul 21, 2010 | 09:36 PM
  #1069
Pepper's Avatar
I finally got my wheels back from chroming the barrels. They are Volk GT-S 19x9.5 +2 (15mm spacer) 235/35/19 & 19x10.5 +3 (15mm spacer) 255/35/19 (Toyo T1R) . Im on Tein Flex and the rears are maxed out. I need another 1/2" - 3/4" lower. Should I cut the spring mount?? Suggestions?
Old Jul 22, 2010 | 02:46 AM
  #1070
or_G's Avatar
Good offset size for Te-37's and tire size to go with it?
Old Jul 22, 2010 | 02:47 AM
  #1071
4DGS's Avatar
^ lowered? you wanna poke or you wanna be track ready? lol
Old Jul 22, 2010 | 02:52 AM
  #1072
gsracerx98's Avatar
I was thinking about getting a set of work vs-fx (19x9.5 front/19x10.5 rear) for my 06 coupe. What disk/offset would you guys recommend? Currently I have stoptech bbk (6piston front/4piston rear) and lowered on tein s-tech springs.
http://www.workwheelsusa.com/media/w...3/VSFX_PDF.pdf
Old Jul 22, 2010 | 04:06 AM
  #1073
or_G's Avatar
slightly lowered. not for tracking
Old Jul 22, 2010 | 04:24 AM
  #1074
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Hah, ok now I understand. Lets try this again.
20x8.5 +5 (w/ 15mm spacers)
20x10 +10 (w/ 15mm spacers)
Normally, on an 8.5 wheel, you'd run a 245 size tire. For the front, 225/35 would clear. Its not a 9.5 wide wheel so you'll have some clearance from the fender.
As for the rear, a 245 / 35 stretch or a 255 / 35 stretch would be fine in order to clear.
Dial in a bit of negative camber and you should be ready to roll.
Old Jul 22, 2010 | 04:51 AM
  #1075
Dranom's Avatar
R-disk front for BBK
O-disk rear
the drop on S-techs are not that much so unless your staying with that or getting coils and lowering the car in the future
i suggest getting conservative offsets probably +12 Fr +17Rr?
take out the rings on the rears its will lower abit more
Old Jul 22, 2010 | 03:04 PM
  #1076
Pepper's Avatar
how much is "a bit"? 1"?
Old Jul 22, 2010 | 03:21 PM
  #1077
Dranom's Avatar
see for yourself? im not really sure how much
heres my friends car with basics with rings out
Old Jul 22, 2010 | 04:04 PM
  #1078
or_G's Avatar
Someone help me with picking my rim size!!
VOLK Te37's!
Old Jul 22, 2010 | 04:40 PM
  #1079
Dranom's Avatar
just get 19x9.5 +12 19x10.5 +12
its either +12 or +22 on TEs anyways
Old Jul 23, 2010 | 12:31 AM
  #1080
XiN's Avatar
XiN
Itasha Coupe
CookieMonster's old look is so effin nice. I loved his set up.
What was the tire set up that he had for his front on that setup, Dranom? Do you know?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
