Balancing
Old Jun 19, 2005 | 12:51 PM
johnnie2's Avatar
Balancing
I've tried three times to nbalance the HP R5 wheels and I'm close but no cigar !!!! It's still a little off and was wondering if ANYONE has had the same problem with the wheels ??? The look good but I like no vibration at only 80 !!!!!
Old Jun 19, 2005 | 01:12 PM
IS300TOG35's Avatar
► Matt ◄
Did you try getting them hunter road force balanced? I had the same prob when I put my new wheels on, the car shook terrible at 80. I brought the car to a Nissan dealer with a hunter roadforce and they found one of my front tires wernt truly round, in other words defective. They balanced the other 3 and I was able to get another tire free from the place I got them from, I got it installed and roadforce balanced and NO more shaking at all. Give it a shot.
Matt
Old Jun 19, 2005 | 04:42 PM
kenchan's Avatar
matt- great to hear that your car turn out!
Old Jun 20, 2005 | 07:29 AM
Q45tech's Avatar
Important to know the exact imbalance of each wheel [without the tire] and to fix the wheels by grinding or glueing on fixed weights to bring the wheels into perfection.
Axial and radial runout measurements of the wheel are specified and a less than 2-3 gram flange error is achieveable.
Then you deal with the tires and how they are mounted.
All NEW tires change in the first 500 miles so a rebalance is required.
Old Jun 20, 2005 | 10:45 AM
jayayssohn's Avatar
sometimes if the wheel balancer keeps telling u to add weight on one side of the rim it might help if u popped the bead and rotate the tire bout 180 degrees see if that might help..
Old Jun 21, 2005 | 06:52 AM
johnnie2's Avatar
Thank You. Road Force balancing at the Infinity dealer Thursday at 8 am !!!!!!
Old Jun 21, 2005 | 01:08 PM
johnnie2's Avatar
Hey, got an appointment today and will advise.
Old Jun 22, 2005 | 03:03 AM
johnnie2's Avatar
Sad to say, the guy is saying that the wheels are fine just that the Nitto NT 555's are just low grade tires and that there will be a slight imbalance in the front and that by purchasing a set of Michelin Pilots would eliminate the problem all together !!!!!! With the road force balancing it got a little better but didn't solve the problem. I don't know, if I had bologna skins on I thought they would at least balance a little better as in no shake in the front. Opinions are welcomed !!!!!! Also, what do you all think of Nitto tires as I thought they were good. I would like a second opinion before I spend the $1,200 for the tires.
Old Jun 22, 2005 | 03:10 AM
sen_jen's Avatar
Meatshake Enterprise
it happens. there will always be a defect in some way when it comes to mass produced parts. unfortunately, it happens with Nitto's more often than you think. i hate to bash on products, but swap all 4 of your Nitto's for something else. Nitto's are not a very good tire. there are many lower priced brands that offer far more performance/comfort/satisfaction. if price is a factor, look into either Fuzion ZRi's. they're priced very attractively, and imo (i'm running them now) are very good.
Old Jun 22, 2005 | 10:16 PM
johnnie2's Avatar
Thanks !!!!
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
ScraggleRock
Sep 3, 2015 03:12 AM
andyg35c1
Aug 29, 2015 03:37 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
MyfistYourFace
Aug 8, 2015 11:58 AM
