Factory iPod Integration Successful...
Old Jan 22, 2007 | 11:24 AM
  #136
dan61177's Avatar
PM sent
Old Jan 22, 2007 | 03:33 PM
  #137
fx57's Avatar
I've tried the PAC and am currently using the USA spec interface, but this one looks very good.
A few questions to those who have theirs set up already...
Can you fast forward/rewind songs from the radio controls? (mainly for those 1 hour podcasts)
Does it pause the iPod when you turn off the ignition or radio and automatically resume when you turn the ignition back on?
When you leave a playlist does it remember what song you were at and when you go back to the playlist and resume from where you left off?
What does the up/down steering control do when you press it briefly (less than 3 seconds)?
Old Jan 22, 2007 | 04:35 PM
  #138
Skaterbasist's Avatar
Retired SuperMod
I wish I was as technical as some very good members here
Old Jan 22, 2007 | 07:27 PM
  #139
Glycerine's Avatar
FX...
No fast forward that i've seen... haven't tried it with the bookmarkable podcasts however.
Yes it remembers where you were and auto starts that same song back. Almost instantly. I'd hear the ipod after starting quicker than i'd hear the FM
If you're talking about going to a playlist, playing a song, then selecting a song by artist to play, then going back to that playlist and expecting it to resume from where you left it... no, it doesn't do that.
On the switches... i want to say it does nothing. Haven't tried it in a while....
Old Jan 22, 2007 | 07:52 PM
  #140
bikinilust's Avatar
Hey guys, what do you think about this http://cgi.ebay.com/PAC-AAI-NIS2-Aux-Input-2006-Infiniti-G35-FX-35-45-QX56_W0QQcmdZViewItemQQcategoryZ60208QQihZ007QQitemZ170071652439QQrdZ1QQsspagenameZWDVW Is this the same kit? I dont have SAT in my '04 coupe, so i really dont need that big long cord from the trunk forward...
Old Jan 22, 2007 | 08:06 PM
  #141
bikinilust's Avatar
Now that i really look into it, it sounds a little skeptical
Old Jan 22, 2007 | 08:12 PM
  #142
bikinilust's Avatar
Hey Jtesensky, I have an "04 coupe w/the sat button but i dont have the sat feature in my car. Which kit do i need and do i need to find out if im "prewired", or just by having the button means im prewired? Also, i have the nano and i want to custom install the ipod wiring to the ashtray (i already tested it, it fits), will the cord that you provide w the kit be enough length? Because i dont have to go through the trunk, because i dont have SAT, right???
Old Jan 22, 2007 | 08:25 PM
  #143
Glycerine's Avatar
bikinilust,
If you are an 04, you are prewired. Look for the white plug connected to nothing underneath the plastic shroud on the driver's side of your trunk.
If you want to mount the the ipod control box up front, there's sufficient length to do so using the length of the thicker sat harness cable. I just coiled mine up and left in the trunk. You can stretch yours out so that it runs under the seat or in the center console. If you did that, you *might* have enough length on the ipod cable from the box to make it to the ashtray.
The install would be a little trickier as you have to route a larger cable into the cabin and find a grounding point for the ipod box (I can show you some ideas if you mount it inside the center console). I'd also hope you're pretty handy with a dremel to do the fab work required to mount the nano in the ashtray up front.
Old Jan 22, 2007 | 08:56 PM
  #144
BlueBOB's Avatar
I'm so confused about this whole length issue. Where is the problem exactly? When you view the marketing documentation about the G35 and the iPod connectivity, they generally show the wire coming out of the arm rest area. Is the SAT wire long enough, but the iPod part isn't and people don't want to run the SAT wire into the car?
Old Jan 22, 2007 | 09:11 PM
  #145
upthepool's Avatar
Hi Everyone,
The kit works great. No need for worries. I have not found a fast forward/rewind feature yet.
The biggest problem is not having access to second level scrolling. Playlists are a must if you have a big catalog and are like me and don't want to give in to all the anti-album people. The problem with the playlist feature is that the display only shows ten characters. So, if you want your playlists to mimic your albums and begin with the artist's name you have to be creative. For example, instead of Frank Zappa-200 Motels, you may have to settle for FZ-200 Mots.
All that said, the system works great and is worth it. These are just consequences of being 3-4 years ahead of everyone else.
Shawn
Old Jan 22, 2007 | 10:05 PM
  #146
Glycerine's Avatar
Bluebob,
You got it. Plus the box acts as a passthrough if you have sat, requiring you to run another thick cable back to the trunk from the ipod box to the sat.
Old Jan 24, 2007 | 01:28 PM
  #147
Glycerine's Avatar
FX, i partially retract my previous statement... If you're playing a playlist, then go off somewhere else (turn off ignition, go to a track by artist, whatever), and go back to the playlist, i was correct in saying that it would not automagically go to where in the playlist you left off. However, i was wrong in saying that it did not resume. Did the exact sequence above, picked my playlist and the first song started playing. When i got to the podcast i cut out on, it picked it up right where i left off. So bottom line, it will remember where in the song you were, but it's up to you to seek to that song on the playlist.
Old Jan 28, 2007 | 09:08 AM
  #148
erok's Avatar
any news on the longer ipod cable?
Old Jan 28, 2007 | 11:06 AM
  #149
Rphillips6487's Avatar
nice job installing that, im sure it was a pita
Old Jan 29, 2007 | 09:48 PM
  #150
Jellysick's Avatar
Any more updates on the 10' cable? I'm interested in ordering the parts necessary, but I'm wondering on if/when the extended cable will be available. Nice install too!
