Factory iPod Integration Successful...
Old Feb 22, 2007 | 04:32 PM
  #211
BlueBOB's Avatar
the custom part is the "installing it after you buy the car"
Old Feb 24, 2007 | 04:42 AM
  #212
BlackHamster's Avatar
Just got this unit installed here in Vegas. Mark at Ultimate Electronics (the one on Rainbow) was able to install it under the back seat and he ran the cable into the center console without needing the longer cable. He said it only took him about 45 min to do the total install. Works great and sounds excellent over the Diamond Audio system I already have. I changed out everything but the head unit and I have a Rockford Fosgate 360.2 as the interface/ sound processor. Allowed me to keep the system looking completely stock with audiophile level sound (at 1000 watts continuous...)
Old Feb 25, 2007 | 03:49 AM
  #213
Sponger's Avatar
6MT Brembo Coupe
^^sounds good. subscribing..
Old Feb 26, 2007 | 12:30 AM
  #214
BocaCoupe's Avatar
G's Up, Ho's Down
Can you still control the ipod itself? or is it just by steering wheel?
I would want the ipod on a proclip or similar....
Old Feb 26, 2007 | 09:16 AM
  #215
BlueBOB's Avatar
only through steering wheel and head unit... the iPod just shows a check mark saying it's connected
Old Feb 26, 2007 | 05:16 PM
  #216
mistsc's Avatar
Does stock 06 bluetooth still still work?
Old Feb 27, 2007 | 01:29 AM
  #217
allendoc's Avatar
The 07 BT still does.
Old Feb 27, 2007 | 04:17 PM
  #218
BeerViper's Avatar
I haven't seen these question asked yet:
1) Will this work with the iPod mini?
2) When you switch from the SAT input back to AM/FM or CD or Power Off is the iPod paused or does it continue playing?
Old Feb 27, 2007 | 04:35 PM
  #219
BlueBOB's Avatar
my thoughts would be if the thing has the iPod connector, then it should connect...
The iPod is in a connection mode (all you see is a check mark up front) so I don't think it would be "still playing" after you left the "iPod Mode" just like a CD.
My buddy has a Scion with the iPod connection, so I've seen this connectivity in action and everything I've heard so far from people that actually have it, it seems identical.
Old Feb 27, 2007 | 08:18 PM
  #220
mach330i's Avatar
one question...is it always charging or can you disable the charging feature? i don't want it charging my ipod all the time (battery life).
Old Feb 28, 2007 | 12:16 AM
  #221
04NismoV35's Avatar
It's not necessarily bad to constantly charge a Lithium Ion batt. unlike Ni-MH or Ni-Cad. They are like car batts, if left dead too long cells get damaged. If the charge is trickle then that's ok.
Old Feb 28, 2007 | 09:32 PM
  #222
SLEEPR's Avatar
Just got my kit. Went to the garage and pulled the spare tire, and there is no SAT wiring in the trunk of my '04 sedan. Guess I need to take everything and have it installed behind the dash...I dont want to install in the dash myself, Id be too afraid of wrecking/scratching something.
Old Mar 1, 2007 | 12:20 AM
  #223
mach330i's Avatar
well..as you know with the ipod. it can only charge around ~400 times or so which is why i try to avoid charging it until i have to. does anyone know if you can disable the charging feature?
Old Mar 1, 2007 | 12:22 AM
  #224
BlueBOB's Avatar
doubtful, and they fixed the charging problems they had with the Gen 1 and Gen 2 iPods
Old Mar 5, 2007 | 07:38 AM
  #225
Dave E H's Avatar
I just did this install - pretty easy (I never really do any work myself on my cars). I am leaving the ipod in the back for now - since I can't use the ipod's GUI, no point in routing the cable up front.
The only complaint I have it navigating w/ the head unit - I think I'm just getting too impatient and not waiting for the key presses to register. Going to play with it more later.
