Factory iPod Integration Successful...
Old Mar 5, 2007 | 09:40 AM
  #226
g35rcr's Avatar
even with an aftermarket stereo setup, you have to controll the ipod through the stereo...you can't have it both ways
Old Mar 5, 2007 | 12:22 PM
  #227
oscottio's Avatar
Originally Posted by mach330i
well..as you know with the ipod. it can only charge around ~400 times or so which is why i try to avoid charging it until i have to. does anyone know if you can disable the charging feature?
i haven't driven my car for almost a month now and when i looked at the ipod, the battery was almost drained. so i guess it doesn't charge when the car is off but charges only when ur driving.
Old Mar 5, 2007 | 06:59 PM
  #228
Dave E H's Avatar
This is weird? I have the kit in, but removed my iPod. Now I can't figure out how to use the regular radio w/o the ipod in? When I hit radio, it keeps trying to go to satellite? Any ideas?
I just went back to my car - put the ipod in, and I was able to get FM/AM no problem. remove the ipod, and then the radio just tries to keep searching for it and I get the "no ipod" message - and can't get to FM stations.
Old Mar 11, 2007 | 09:35 PM
  #229
SmoothieG35's Avatar
What are my other options for getting an iPod connected in my car? I'd like to be able to charge it, display text on the stock HU, be able to control it from the steering wheel as well as the iPod directly.
Is there anything out there that meets these requirements? What about the kit from mp3yourcar.com?
Old Mar 11, 2007 | 11:51 PM
  #230
BeerViper's Avatar
USA Spec PA11-NIS ... search on it, I just ordered one off eBay for $119 shipped. It does everything the factory unit does plus gives you the option of having direct iPod control. The downside is that you must connect it to the back of the stock radio instead of using the SAT pre-wire in the trunk.
Old Mar 12, 2007 | 06:56 AM
  #231
^^ I didn't think the USA spec gave you the text display of folders and song titles like the factory unit one does?
Old Mar 12, 2007 | 10:00 AM
  #232
BeerViper's Avatar
The USA Spec has a "direct" mode and "playlist" mode where the playlist mode, from what I have seen, will give you the same functionality as the factory unit (but not allow direct iPod input). The direct mode provides direct ipod input while still giving minor functionality through the radio and steering wheel controls.
Old Mar 20, 2007 | 09:08 PM
  #233
nomi3000's Avatar
non prewired setup question
Has any one try this setup on non pr wired car? Will the harness go behind the HU or will it still go in the trunk. It is lot of work to put in behind the HU. I want to add this to my car but want to see what I am up against before I do it. Any help will be greatly appreciated
Old Mar 20, 2007 | 09:16 PM
  #234
mach330i's Avatar
wut do u mean by prewired? i just did my gf's car n it's pretty easy to install behind the radio.
Old Mar 20, 2007 | 09:42 PM
  #235
nomi3000's Avatar
Prewired cars apparently have a plug in the trunk that you can just plug this thing into but I don’t have this plug in the trunk so I think I will have to install this behind the HU which is lot more work than in the trunk
Old Mar 28, 2007 | 09:37 AM
  #236
orangenblue's Avatar
Ipod Linux?
Anyone know if this unit will recognize an ipod running ipod linux?
Old Mar 28, 2007 | 11:29 AM
  #237
dan61177's Avatar
If we are prewired, can we still wire in behind the head unit?
Old Mar 28, 2007 | 06:37 PM
  #238
Glycerine's Avatar
If the plug behind the head unit is the same, i'd imagine so as the trunk cable is just an extension, afaik. Just be sure you have a good grounding point up there.
Old Mar 28, 2007 | 06:40 PM
  #239
Glycerine's Avatar
I've been wondering that myself. I've got a dead 4g here, if i can resurrect i was going to put that on for kicks. Let me know if you try it.
Side note: War Eagle?
Old Mar 28, 2007 | 11:24 PM
  #240
paul8088's Avatar
So does someone still have these for sale? Joe?
