Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Old Jan 9, 2012 | 01:03 PM
  #706
AARONHL's Avatar
I tried using the trim that came with the Pioneer. I was in a hurry, so didn't put much work into cutting the trim. I guess I could try again later on when I take it out to connect the USB cable. I would only need the trim to cover the top. The sides and bottom were a tight fit.
Old Jan 9, 2012 | 08:54 PM
  #707
SAMzG35's Avatar
G35
Excited to install mine this week! Hope it all goes smooth
Old Jan 13, 2012 | 12:45 PM
  #708
TastefullyDone's Avatar
Originally Posted by AARONHL
PAC Harness on bottom - Pioneer Harness on top...I think I got it...is this right??? Looks like I don't have to use the wires with the red stripes. And would it be okay to twist all the blue wires together?
okay so i'm about to sit down and do all of this. let me get it straight
the red striped wires at the end get taped off
all wires get matched to their appropriate color and soldered together, except the solid blue wire,
which gets soldered as part of a three way connection with the red wire from PAC and the red wire from the Pioneer yes?
Old Jan 13, 2012 | 01:01 PM
  #709
AARONHL's Avatar
the red striped wires at the end get taped off YES, THOSE ARE THE WIRES ON THE RIGHT SIDE OF THE PICTURE.
all wires get matched to their appropriate color and soldered together, except the solid blue wire, YES
which gets soldered as part of a three way connection with the red wire from PAC and the red wire from the Pioneer yes?YES, CONNECT THE BLUE/WHITE TO BLUE/WHITE, CONNECT BLUE TO THE RED CONNECTION MAKING THE 3 WAY.
Old Jan 13, 2012 | 01:13 PM
  #710
AARONHL's Avatar
Are you using the Bose amplifier?
Old Jan 13, 2012 | 03:37 PM
  #711
also, do the mute (yellow w/black and short), reverse gear (purple short), and emergency(lime green and long) stay unplugged when using 4300dvd and Metra Axxess ASWC?
Old Jan 13, 2012 | 03:38 PM
  #712
yes with bose amp
Old Jan 13, 2012 | 04:59 PM
  #713
AARONHL's Avatar
Don't connect the MUTE or REVERSE to anything. The mute button on the Pioneer 4300 will still work anyway.
The E-BRAKE wire will need to be connected to the e-brake switch on the actual e-brake. I found it easier to just buy a bypass on eBay.
Old Jan 14, 2012 | 01:32 AM
  #714
SAMzG35's Avatar
G35
Aaron do you have a picture of your install?
I'm trying to get a flush fit but its not working out so well
im lost between this
either this deep (using the JVC HU trim)
or this high (using the Scosche trim)
Old Jan 14, 2012 | 01:50 AM
  #715
SAMzG35's Avatar
G35
just connect the green wire to ground and you should be good, i did that on two HUs and it worked fine
Old Jan 14, 2012 | 01:59 AM
  #716
AARONHL's Avatar
I'll post pictures of my head unit later tomorrow (today).
If you ground it I don't think you will be able to watch movies while driving.
Old Jan 14, 2012 | 02:01 AM
  #717
SAMzG35's Avatar
G35
Not that i watch while driving or even when parked, but i thought it would be nice to have it by passed.
& yes you can, I did it on my clarion HU back in the days and i also did the same on my JVC that im installing now and it worked like a charm
Old Jan 14, 2012 | 05:24 AM
  #718
Wrathernaut's Avatar
Gentle Manne of Leisure
If pioneer are grounded on the e-brake wire when they start up, they act just like if there was no e-brake wire connected. They need the bypass relay to allow video to be played to the front screen while driving (I believe rear video output is unaffected either way).
As for making it flush, drill your own holes for the screws on the bracket to flush the face with the trim, then just cut pieces of the scosche trim to fill in the resulting gaps.
Old Jan 14, 2012 | 12:54 PM
  #719
AARONHL's Avatar
I don't think I'll ever watch DVDs in my car, but wanted to integrate the bypass into the big harness I made so I wouldn't have to touch it again. It's nice to know if a passenger wants to watch a DVD they can.
  #720
AARONHL's Avatar
I'm going to take my Pioneer out and re drill hole into the bracket. It sticks out too far and there is a big gap at the top.
You have already rated this thread Rating: Thread Rating: 31 votes, 5.00 average.
