i was looking at this on ebay.. is this good to buy? http://cgi.ebay.com/Pioneer-Bypass-Automatic-Hack-AVH-P3200BT-AVH-P3200DVD-/180568859238?pt=LH_DefaultDomain_0&hash=item2a0abe2266
Wrathernaut
Gentle Manne of Leisure
close
- Join DateNov 2008
- LocationPennsylvania
iTrader Positive Feedback100
iTrader Feedback Score(5)
Liked:1,050 Times in 618 Posts
No.
Search youtube, there's free bypasses that usually involve only moving a wire on most Pioneer units.
Otherwise, it's wiring up a relay, which involves just as much wiring at that thing you linked to.
Wrathernaut
close
- Join DateNov 2008
Updated 26 Dec.
Still getting some people with 05-07s getting poor quality audio with the Bose system and the 70-7551 harness, so I've changed it so that all years with Bose are recommended to use the PAC ROEM-NIS2.
ok so i plugged in the harness and everything.. video is ok but i'm not getting any sounds from the cd or radio.. am i missing something here? help!!
ps. i had a bose, now pioneer using pac roemnis2
Wrathernaut
close
- Join DateNov 2008
My guess is that you did not connect both the amp remote power signal and the antenna amp power signals to the single power signal wire coming from your headunit.Originally Posted by jayremix
ok so i plugged in the harness and everything.. video is ok but i'm not getting any sounds from the cd or radio.. am i missing something here? help!!ps. i had a bose, now pioneer using pac roemnis2
im almost done, the ASWC has a brown wire, I dont have a 3.5mm connector in the back of my headunit.. where should i wire the brown wire? I had the other wires wired in the factory harness. help out pls.
Wrathernaut
close
- Join DateNov 2008
Quote:
How old is this unit? I can't think of a modern pioneer unit that doesn't use the 3.5mm.Originally Posted by jayremix
Wrathernaut
close
- Join DateNov 2008
Quote:
Then it has a 3.5mm hole on it for wired (steering wheel) remote in addition to the 2.5?mm hole for the microphone.Originally Posted by jayremix
its brand new, pioneer avh-p3200bt
Wrathernaut
close
- Join DateNov 2008
Quote:
It's in the righthand side when looking at the back. Labeled remote. Originally Posted by Wrathernaut
I have an 05 coupe w/nav. is it possible to add a avic dd and make the factory pop up screen mirror the pioneer HU screen and also keep the fuel Econ/ trip computer. thx
Wrathernaut
close
- Join DateNov 2008
Quote:
https://g35driver.com/forums/audio-v...play-dvds.htmlOriginally Posted by jc63
Use the parts in there, hook the a/v input to the output from your avic.
OK, so Ive been looking through here and sorry if I missed this if it was answered already. I bought everything on your shopping list with one exception of the steering wheel controls. I purchased a Clarion unit (
) and the only thing I am a little fuzzy on is when it comes to wiring everything in, I know there are 4 connectors on the back of my stock unit, 2 of them for the bose, the main connector for the factory unit (im assuming) and the steering controls. (again assuming) and I know the PAC unit integrates with the bose amp which is what i want to do. My question is, I want to know if there is a harness I can get that will keep me from having to cut any wires for the main harness to the stereo? or will one of the other items on your shopping list take care of that? Does my question make sense? If it makes a diff, I have an 03 coupe
Wrathernaut
close
- Join DateNov 2008
You'll have to cut wires for the steering wheel controls in order to get a solid connection, all the others wires connect to the appropriate harness, no cutting required.
Also, if you're afraid to cut wires, you may want to re-think doing it yourself.
