Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
#1231
Thanks for the link to the ASWC directions - those were not included with the one I received. I'm all set with this now.
Thanks again for all the help!
#1232
I have an 06 sedan with Bose (no nav).
I have a AVH-p8400bh waiting to be installed as my other parts come in the mail.
Parts on order are:
Parking Brake Override Bypass Fully Automatic Video in Motion Pioneer Custom for AVH-P8400BH
Axxess Metra ASWC-1 Universal Steering Wheel Control Interface with New Micro B Connector
Metra 40-NI10 Nissan Antenna Adapter
PAC ROEMNIS2 Factory Premium Sound Interface Headunit Replacement, For Select Nissan
JDM DD dual AC no navi trim kit
The Harness is where I have the question. I plan on keeping the Bose amp. Do I need the Metra 70-7551 Amplifier Integration Harness and the PAC ROEMNIS2, or just the PAC ROEMNIS2?
I don't want to hack any connections from the car harness so I want it to be all plug and play connectors. Then from the connectors I will solder the wires to the deck.
Thanks for the help.
Parts on order are:
#1233
Parts on order are:
Parts on order are:
You're going to either cut wires or hack up the factory radio to get the harness plug out to connect the steering wheel harness.
If you're afraid of cutting and soldering wires, you shouldn't attempt this.
#1234
Cool,
That's what I thought I just needed to get a second opinion.
Not afraid to cut and solder, I just want to make it clean as possible.
This isn't my first radio install but it is the first with steering wheel controls, so that part is new to me.
I have my solder and heat shrink ready for this project. I just need to do a little more reading on the ASWC-1.
Thank you Wrathernaut for all your advice and this thread.
#1235
Today I spent a good couple hours reading posts in this thread and I'm surprised that no one else here seems to be confused like me about how to integrate all the wires that go to connector #3 (post # 1229) of the stock harness into the aftermarket head unit install. I read a few dozen posts where folks made successful installs and not one question about this.
I took a look at the PAC adapter that is recommended in the 1st post to see if maybe it had three connectors for the stock harness instead of just two like on my Scosche adapter. Here's a pic of the PAC adapter and to me it looks identical to the one I have - a little nicer (and more expensive) but functionally the same:
EDIT: Today I called Crutchfield with my question about connector #3 and they told me to forget about it, it does not get used to install the new head unit. He said the stock wiring harness probably had additional features incorporated into the wiring harness like the ability to add additional amps, a sub-woofer or a CD changer, etc. Does this sound correct? I wish someone who's made a successful install could tell me what they did with this connector.
#1236
So, it sounds like Crutchfield told you exactly what I did. I know there's a ton of posts in this thread, but that connector has been covered multiple times, it is not used.
#1237
Yeah, it's functionally the same, but if I recall, it's about the same price (or more expensive) and was tested by less users, so in the interest of keeping the shopping list as simple as possible, I don't include it.
On the PAC vs Scosche adapters the price in the amazon link of the first post of this thread has $30 listed for the PAC item, Crutchfield charged me $15 for the Scosche part.
Yeah, there are a ton of posts here - after two hours of reading I was burned out. Anyway alls well that ends well. I'm a moderator for a motorcycle forum and I know how it can be trying to help a *** with something that's very simple to you. So thanks again for following up with me on this, I'll feel a lot better now when I power up the system for the first time.
#1238
OK new problem
I think I may have shorted the switched 12V power to ground. When I first powered up to test the unit the CD player, amps and all speakers were fine but there was no radio reception. There was some talk about making sure the antenna amp/control lead was connected to switched power in the instructions so I removed some black electrical tape to check that connection. But then just as I finished removing the tape I remembered I forgot to plug in the antenna adapter and antenna lead into the headset, DOH!!! So I put the unit down and went to get the antenna adapter. All I can think of that may have happened is the soldered connection that I just exposed came in contact with the H/U mounting bracket which was grounded for the test. The switchable power was gone. I could only find one fuse under the hood labeled "radio" a 15 amp but it is still good. None of the fuses in the cabin are labeled with anything that makes me think they may have blown due to this. Any ideas what may happen if the switchable power of the stereo circuit get shorted to ground? Thanks.
EDIT: A guy on the NICO forum posted a link to the service manuals. Once I had the wiring diagram I was able to locate the fuse. It's #6 in the passenger cabin and it's labeled MIRROR. Everything's working great, sounds good, plenty of volume and nice clear FM reception. Now just to get it all back together without any more screw-ups.
#1239
Sorry, I guess I misunderstood your reply to my first post where I was looking to get confirmation that this connector is not used. You mentioned pre-wiring the satellite harness which made me assume that this connector was related to that.
#1240
#1241
Thanks for this guide!
I have a 2004 G35 coupe w/Bose and have used this fantastic post to order everything I need to add aftermarket head unit, except for the trim. I am looking for some feedback from anybody before buying the trim/AC controls...
My '04 G is black on black, and so I'd like have a silver console and trim since everything in the '04 is just black. My goal is this:
https://g35driver.com/forums/audio-v...-pictures.html
1) Where do people find the silver console (ashtray to upholders)?
2) Where do people find the silver lid for the non-nav compartment above the AC controls?
3) Are these extremely hard to come by now? Even worth trying to make the switch from black?
Thanks in advance for anybody's input.
#1242
Grubb's Infiniti should be able to hook you up with the parts. I don't know if the storage compartment is a separate piece, or if you'll have to order the entire storage compartment.
#1243
It was a trim combination available, so most people only are having to replace the ashtray-up trim.
#1244
Really, that makes sense then. I have seen some photos of G35's in various stages of swapping black to silver. Silver double din, black storage comparment, black console. Or silver double DIN and silver storage lid but still black console. I guess people are just finding trades or waiting patiently for used car parts. I've read (and have no doubt) that buying these pieces new from dealer would be $1000+. I can't really justify that so I guess I will stick with all black, thanks!
#1245
Here is my setup. I also have the gap around the face of my head unit and it is also a bit sunken in. I have someone that is good with customization and he told me to order a sheet of abs plastic and he'll trim it accordingly. My question is I'd like to know if theres a way to remove the dash piece where the head unit is without having to remove the piece where the shifter is and the black trim on the sides?
