Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Old Jan 2, 2011 | 03:06 PM
  #121
numbers1thru9's Avatar
Its not that Im afraid to cut wires, I just dont like to :-P Ive installed many headunits before, but this is the first one Ive done with a factory amp, especially Bose. Just wanted to be clear on everything before all my parts arrived this week and I ripped the dash apart again. I bought
this this
for the steering controls rather than the one you suggested. Figured Id give it a shot and see how it works.
Old Jan 2, 2011 | 04:01 PM
  #122
Wrathernaut's Avatar
Gentle Manne of Leisure
Actually, as of a few weeks ago, that is the one I've suggested for steering wheel controls, for all but very few headunits.
Old Jan 3, 2011 | 01:27 AM
  #123
ATL_Red_G35's Avatar
Hi, can you please post the connection and pins to the NAV voice mod again? I'm redoing in mine and would like to verify the Voltages, relay types, etc. Hopefully it will help the rest of the members on the forums.
Thanks,
Kev
Edit: Found it on the other thread, will try and it and see
Old Jan 3, 2011 | 05:38 AM
  #124
Thanks,
Kev
Be sure to take pictures and video of it working.
Old Jan 6, 2011 | 07:20 PM
  #125
TheG35Dude's Avatar
My shopping list for a 2003 G35 Coupe with nav,
I got
- PIONEER AVH-P3200BT BLUETOOTH NAV READY 5.8" RECEIVER
- PAC ROEM-NIS2 Nissan/Bose Radio Replacement Interface 1
- METRA AXXESS ASWC UNIVERSAL OEM STEERING WHEEL CONTROL
- JDM INFINITI G35 DOUBLE DIN AC CONVERSION KIT 03-04 DVD
It would really be upsetting to not have everything ready before I rip the dash apart, did I miss anything?
Thanks
Old Jan 6, 2011 | 10:13 PM
  #126
The scosche trim ring.
Amazon Amazon
Old Jan 7, 2011 | 11:25 AM
  #127
MikeDG's Avatar
I got
Thanks
You will also need a radio antenna adapter (Metra 40-NI10).
Amazon Amazon
Old Jan 7, 2011 | 12:49 PM
  #128
^ good catch.
Depending on where you buy the stereo, they'll include the antenna adapter for free - crutchfield.com and sonicelectronix.com both do this. I'm not sure what others do.
Old Jan 7, 2011 | 01:18 PM
  #129
MarkDC's Avatar
Parking brake wire?
Great thread, thanks for posting, Wrathernaut!
I plan on installing the Pioneer AVIC-U310BT I got for Christmas (once the weather warms up a bit). I did a quick reading of the install instructions that came with the unit and noticed that I have a wire that needs to tap into the parking brake circuit or some of the nav functions won't work. I have a 2004 G35 Coupe with auto trans. Any advice on making this connection? Thanks.
Old Jan 7, 2011 | 08:56 PM
  #130
TheG35Dude's Avatar
I just ordered them also. Thank you!
Old Jan 8, 2011 | 11:16 AM
  #131
Well I got all my parts and finally got the unit installed. Had some trouble as it seemed the ground from the factory harness was faulty so I just made a new one. Had a little bit of trouble trying to decipher the Axxess ASWC book but I found a post by a previous user that you commented on with the documentation I was trying to find on their website and got that working. While installing and testing I lost power for some reason and that took me forever as I was testing the fuse labeled "Battery Audio 15A" on the driver side, I finally figured out that it was under the hood, forgot that box was there as Ive never had to change fuses in this particular car. Once I realized that fuse was blown, replaced it and like magic I had power again. Finally got the ASWC programmed, all the wires in place, and shoved into a nice spot in the dash and everything reassembled. Attached is an image of my installation. Thanks for your help when I needed it! Great thread!
Attached Thumbnails Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List-imag0061.jpg
Old Jan 8, 2011 | 12:56 PM
  #132
I'd recommend bypassing that part so that passengers can add destinations as you go. avic411.com has the info on how to do it.
That unit though... it's kind of a mixed bag. It boots fast, bluetooth is good, and nav is good, but the POIs in its database is pathetic, so unless you get add-on POIs, you won't even know where to find food or gas with it.
Old Jan 9, 2011 | 05:41 PM
  #133
MarkDC's Avatar
Thanks for the web site. Really helpful. Seems like there is an update to the POIs, so I'll see what version I have after the install and see if I need the update. Thanks again! I'll probably have more questions as I do the install. You rock!
Old Jan 13, 2011 | 05:26 AM
  #134
Eva G's Avatar
so do I need the "Scosche universal double din trim ring" if I have a pioneer avh 3200bt? its a double din not single din. or i it a trim that goes behind?
also any suggestions for a rearview camera? if not thats ok thanks!
Old Jan 13, 2011 | 01:34 PM
  #135
Yes, you need the trim ring if you're doing JDM.
You have already rated this thread Rating: Thread Rating: 31 votes, 5.00 average.
